Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octoplus Huawei Tool
Old 12-31-2020, 12:12   #1 (permalink)
GSM786786's Avatar
Member: 2580629
Thanks Meter: 104
Thumbs up Huawei Y7P ART-L29 Huawei Id Done By Octoplus Huawei Tool
The Following 3 Users Say Thank You to GSM786786 For This Useful Post:
Old 01-02-2021, 11:33   #2 (permalink)
Octopus support's Avatar
Member: 2891705
Thanks Meter: 2,142
Hello.
Please post here full Software log of Reset Huawei ID operation, we will check it.
Old 01-02-2021, 13:12   #3 (permalink)
GSM786786's Avatar
Member: 2580629
Thanks Meter: 104
Originally Posted by Octopus support View Post
Hello.
Sir I say AllReady Done By Octpus
The Following 2 Users Say Thank You to GSM786786 For This Useful Post:
Old 05-22-2021, 08:39   #4 (permalink)
Member: 2985539
wich modle hw should sellect art-l29 is not in list
Old 05-22-2021, 09:42   #5 (permalink)
Member: 2891705
Thanks Meter: 2,142
Hello.
Please try to select in phone model list: ART-AL00X.
Old 05-23-2021, 18:44   #6 (permalink)
GSM786786's Avatar
Member: 2580629
Thanks Meter: 104
Hi'
Use ART-Al00X modal
it's same modal or cpu
The Following User Says Thank You to GSM786786 For This Useful Post:
Old 09-30-2021, 10:30   #7 (permalink)
Member: 2145475
Thanks Meter: 100
Huawei Y7P ART-L29 Huawei Id Remove Done By Octoplus Huawei Tool
Starting Reset Huawei ID
Selected phone model: ‪ART-AL00X‬
Searching HUAWEI USB COM 1.0 port...
Detected ‪HUAWEI USB COM 1.0‬ port
Writing bootloader KIRIN710_V1...
Initializing remote service connection...
Writing ‪XLOADER‬ partition...
Writing ‪UCE‬ partition...
Writing ‪FASTBOOT‬ partition...
Bootloader Update successfully
Rebooting to fastboot mode...
Searching Fastboot devices...
Found android device: DUJ6R20214012699
Detected ‪Android Sooner Single ADB Interface‬ port
Connecting to the credit server...
Username: rizwanahmad19
Checking balance...
Your balance: 100 credits
Sending device information...
Sending firmware information...
To perform this operation you need to have: 0 credits.
Removing firmware protection...
Connecting to server...
Waiting for a response from the server...
FB Lock State: ‪UNLOCKED‬
User Lock State: ‪LOCKED‬
Device Model: ‪ART-L29‬
System: ‪ARTH-L29 10.1.0.202(C185E2R2P1)‬
Resetting Huawei ID...
Formatting secure data...
Rebooting device...
Reset Huawei ID done.
Performed by ‪1.2.6‬ Software version.
The Following User Says Thank You to azaanali For This Useful Post:
Old 12-27-2021, 21:39   #8 (permalink)
Member: 2084910
Thanks Meter: 4
Job ID: 0000000002089A8B
2021-12-27 20:31:38 GMT -------------------------------------------------
Selected phone model: ‪ART-TL00X‬
Downloading additional resources...
Found android device: DUJ6R20228016495
Username: oup3iat
Checking balance...
Your balance: 80 credits
System: ‪ARTH-L29 10.1.0.219(C185E2R2P1)‬
Rebooting device...
The Following 4 Users Say Thank You to Kanzullah1870 For This Useful Post:
Old 01-23-2022, 11:36   #9 (permalink)
Member: 2647694
Thanks Meter: 10
Art-l29 Imei Repair Octopus World Fast Done
Welcome to Octoplus Huawei Software v.‪1.2.8‬
To enable 'Manufacture' mode dial
- for Qualcomm and Hisilicon based models: *#*#2846579#*#*
ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode
- for MTK based models: *#*#14789632#*#*
ProjectMenu > Background Settings > USB Port Settings > Debug Mode
To enable 'Fastboot' mode
1. Power off the phone. Remove SD and SIM cards
2. Press 'Vol-' and insert USB cable
3. Wait until phone enters 'Fastboot' mode
To enable 'Upgrade' mode
2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable
3. Wait until phone enters 'Upgrade mode'
Found COM ports:
1: COM112 HUAWEI USB COM 1.0
2: COM1 Communications Port
3: COM3 Intel(R) Active Management Technology - SOL
Job ID: 00000000022665EE
2022-01-23 10:24:16
Starting Read Cert
Found android device: HRX6R20*******
Device Model: ‪ART-L29N‬
System: ‪ARTH-L29N 10.1.0.206(C185E4R4P1)‬
Reading certificate files...
Reading certificate for IMEI A...
Reading certificate for IMEI B...
Rebooting device...
Read Cert done.
Performed by ‪1.2.8‬ Software version.
Selected IMEI_A file: E:/Huawei Read Cert/1 STK-L21M 10.0.0.305(C185E6R2P2)‬02.10.2021/STK-L21_IMEI_SLOT_1_8630**********.obf
Selected IMEI_B file: E:/Huawei Read Cert/1 STK-L21M 10.0.0.305(C185E6R2P2)‬02.10.2021/STK-L21_IMEI_SLOT_2_86303**********7.obf
Job ID: 00000000022666E6
2022-01-23 10:28:00
Starting Write Cert
Username: safeunlocker81769
Found android device: HRX6R20C1**********
Checking balance...
Saving backup of MODEM_SECURE...
Saving backup of OEMINFO...
Reading secure data...
Writing certificate files...
Warning: Can`t find imei block!
Warning: The oeminfo partition may be corrupted. In case of imei was not changed properly, you need to restore oeminfo partition!
Rebooting device...
Write Cert done.
The Following User Says Thank You to Rajputgsm For This Useful Post:
Old 10-14-2022, 05:46   #10 (permalink)
Crazy Poster
Member: 1499575
Thanks Meter: 6
thank you Reset Huawei ID done.
The Following 2 Users Say Thank You to dr.chinezu For This Useful Post:
Old 12-04-2022, 14:20   #11 (permalink)
Member: 209146
Thanks Meter: 34
2022-12-04 13:06:59.557 Found android device: DUJ6R20310005395
2022-12-04 13:06:59.560 Detected Android Sooner Single ADB Interface port
2022-12-04 13:06:59.566 Reading basic data...
2022-12-04 13:06:59.618 Reading product model
2022-12-04 13:07:01.630 Reading build number
2022-12-04 13:07:03.642 Device Model: ART-L29
2022-12-04 13:07:03.645 System: ARTH-L29 10.1.0.260(C432E2R1P1)
2022-12-04 13:07:03.648 Android Version: 10
2022-12-04 13:07:03.651 Base Version: ART-LGRP2-OVS 10.1.0.260
2022-12-04 13:07:03.654 Custom Version: ARTH-L29-CUST 10.1.0.2(C432)
2022-12-04 13:07:03.658 Preload Version: ARTH-L29-PRELOAD 10.1.0.1(C432R1)
2022-12-04 13:07:03.663 C_Version: C432
2022-12-04 13:07:03.667 D_Version: D000
2022-12-04 13:07:03.670 FB Lock State: LOCKED
2022-12-04 13:07:03.673 User Lock State: LOCKED
2022-12-04 13:07:05.351 Downloading resource...
2022-12-04 13:07:06.054 Connecting to the credit server...
2022-12-04 13:07:06.059 Username:
2022-12-04 13:07:12.453 Reading product model
2022-12-04 13:07:14.469 Reading build number
2022-12-04 13:07:16.483 Checking balance...
2022-12-04 13:07:16.846 Your balance:
2022-12-04 13:07:18.321 Sending device information...
2022-12-04 13:07:19.178 Sending firmware information...
2022-12-04 13:07:19.939 Removing firmware protection...
2022-12-04 13:07:20.221 Connecting to server...
2022-12-04 13:07:21.282 Private enc 0
2022-12-04 13:07:23.133 Waiting for a response from the server...
2022-12-04 13:07:28.136 Writing sign buf data
2022-12-04 13:07:29.757 FB Lock State: UNLOCKED
2022-12-04 13:07:30.134 User Lock State: LOCKED
2022-12-04 13:07:30.138 Reading product model
2022-12-04 13:07:32.146 Reading build number
2022-12-04 13:07:34.156 Reading serial number
2022-12-04 13:07:34.170 Response contains FAIL!
2022-12-04 13:07:34.170 Reading serial number failed
2022-12-04 13:07:36.170 Device Model: ART-L29
2022-12-04 13:07:36.174 System: ARTH-L29 10.1.0.260(C432E2R1P1)
2022-12-04 13:07:36.945 Resetting Huawei ID...
2022-12-04 13:08:10.038 Rebooting device...
2022-12-04 13:08:10.072 Please perform "Clear data" manually via Recovery Mode, if your device doesn`t start properly!
2022-12-04 13:08:11.202 Reset Huawei ID done.
2022-12-04 13:08:11.207 Performed by 1.3.3 Software version.
Thank!!!!
The Following 3 Users Say Thank You to renren For This Useful Post:
Page generated in 0.20247 seconds with 8 queries
