Mrd-lx1f connect fail [Answered] Found COM ports: 1: COM23 USB Serial Port 2: COM1 Communications Port 3: COM20 Intel(R) Active Management Technology - SOL 4: COM3 Agere Systems HDA Modem 2019-08-27 12:09:57 GMT ------------------------------------------------- Starting Connect Selected phone model: MRD-LX1 Please Power off the phone and insert USB cable Error: Auto Boot Flash Tool Try to "Power ON" / "Power OFF" device and perform operation again Connect failed. Performed by 1.1.0.23 Software version. |
Hello. What exctky You are trying to do? |
this model not in list trying to reset frp and imei repair |
Is this device based on MTK CPU, if yes, then select MTK Android Device from the list and check for these methods: Reset FRP (MTK Loader) To perform Reset FRP operation over MTK Loader, do the next steps: Power phone OFF; Press "Reset FRP (MTK Loader)" button; Insert USB cable; Wait until operation ends; If the phone not connected, try to turn it ON and OFF. And then repeat operation once again. Back to main menu Reset FRP (MTK Test Point) To perform Reset FRP operation via Test point over MTK Loader, do the next steps: Make sure your device is fully charged; Power OFF the phone; Select proper model from the list; Press "Reset FRP (MTK Loader)" button; Attach Tesp point as shown on Test point image; Connect USB cable (battery must be plugged in); Wait until backup is done; Follow Software instructions; - In case if yout phone stuck on logo or erecovery mode, then try to reflash it and perform Factory Data Reset via recovery. |
yes this phone has mt6761 but still connect fail both tp or without tp |
please add these model mrd-lx1f or ksa-lx9 thanks |
thanks but after reconnect battery still connect failed with tp |
What devices are appear in Device manager when You connect this phone via TP, You should check COM port section of the Device manger?! |
