03-25-2021, 01:41 | #1 (permalink) |
No Life Poster Join Date: Apr 2011 Location: Bulgaria Age: 53
Member: 1559599 Status: Offline Thanks Meter: 222 | Octoplus Huawei 1.2.4 DUB-LX1 EDL NOT DETECT [Solved] DUB-LX1 problem flash [ Board Software ] Huawei Y7 2019 DUB-LX1 DUB-LX2 DUB-LX3 DUB-AL00 Dubai-AL00A-BD 1.0.0.59 Board Software general 8.0.0 r1 EMUI 8.2 05022NRB EDL NOT DETECT Octoplus FRP Tool EDL DETECT ok frp ok 2021-03-25 00:31:33.341 2021-03-25 00:31:33 GMT ------------------------------------------------- 2021-03-25 00:31:33.441 Starting Write Firmware(Factory mode) 2021-03-25 00:31:33.531 Selected phone model: DUB-LX1 2021-03-25 00:31:33.641 Please, before firmware write, disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Android-based devices). Dont run any other programs or attach new devices to your computer during the flashing procedure! Don?t turn off phone and don?t disconnect cable during firmware write. Please, follow these simple instructions to avoid phone damage 2021-03-25 00:31:33.741 Connecting to phone.. 2021-03-25 00:31:33.841 Please, reconnect battery, connect USB cable with attached Test Point on your phone! 2021-03-25 00:38:22.966 Canceling... Please be patient! 2021-03-25 00:38:23.732 Init start failed! 2021-03-25 00:38:23.838 2021-03-25 00:38:23.937 Write Firmware(Factory mode) failed. 2021-03-25 00:38:24.034 Performed by 1.2.4 Software version. |
03-25-2021, 01:49 | #2 (permalink) |
Member: 1559599 Status: Offline Thanks Meter: 222 | Found COM ports: 1: COM1 Communications Port 2: COM5 USB Serial Port 3: COM6 Qualcomm HS-USB QDLoader 9008 4: COM3 Intel(R) Active Management Technology - SOL Selected download file: C:/Users/Administrator/Desktop/Huawei Y7 (2019) DUB-LX1/[ Board Software ] Huawei Y7 2019 DUB-LX1 DUB-LX2 DUB-LX3 DUB-AL00 Dubai-AL00A-BD 1.0.0.59 Board Software general 8.0.0 r1 EMUI8.2 05022NRB [androidhost.ru]/Software/DUB-AL00-BD_1.0.0.59_Download.xml Selected rawprogram file: C:/Users/Administrator/Desktop/Huawei Y7 (2019) DUB-LX1/[ Board Software ] Huawei Y7 2019 DUB-LX1 DUB-LX2 DUB-LX3 DUB-AL00 Dubai-AL00A-BD 1.0.0.59 Board Software general 8.0.0 r1 EMUI8.2 05022NRB [androidhost.ru]/Software/bootloaderimage/rawprogram0.xml Selected patch file: C:/Users/Administrator/Desktop/Huawei Y7 (2019) DUB-LX1/[ Board Software ] Huawei Y7 2019 DUB-LX1 DUB-LX2 DUB-LX3 DUB-AL00 Dubai-AL00A-BD 1.0.0.59 Board Software general 8.0.0 r1 EMUI8.2 05022NRB [androidhost.ru]/Software/bootloaderimage/patch0.xml Selected User flashing mode! Job ID: 0000000000C8CFF6 2021-03-25 00:47:08 GMT ------------------------------------------------- Starting Write Firmware(Factory mode) Selected phone model: DUB-LX1 Warning: Please, before firmware write, disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Android-based devices). Dont run any other programs or attach new devices to your computer during the flashing procedure! Don’t turn off phone and don’t disconnect cable during firmware write. Please, follow these simple instructions to avoid phone damage Connecting to phone.. Please, reconnect battery, connect USB cable with attached Test Point on your phone! |
03-25-2021, 18:37 | #6 (permalink) |
Member: 1559599 Status: Offline Thanks Meter: 222 | 2021-03-25 17:14:18.931 Connected to log server. 2021-03-25 17:14:20.122 Job ID: 0000000000C9BF39 2021-03-25 17:14:20.282 2021-03-25 17:14:20 GMT ------------------------------------------------- 2021-03-25 17:14:20.362 Starting Connect 2021-03-25 17:14:20.442 Selected phone model: DUB-LX1 2021-03-25 17:14:20.593 Refreshing serial ports list 2021-03-25 17:14:20.712 Found COM ports: 2021-03-25 17:14:20.795 1: COM1 Communications Port 2021-03-25 17:14:20.870 2: COM5 USB Serial Port 2021-03-25 17:14:20.944 3: COM3 Intel(R) Active Management Technology - SOL 2021-03-25 17:14:21.019 4: COM12 Android Adapter PCUI 2021-03-25 17:14:21.093 5: COM13 DBAdapter Reserved Interface 2021-03-25 17:14:21.170 Detected DBAdapter Reserved Interface port 2021-03-25 17:14:21.250 Connecting to server... 2021-03-25 17:14:22.225 Check auth 0 2021-03-25 17:14:23.213 Authorization is successful 2021-03-25 17:14:23.874 Device Model: DUB-LX1 2021-03-25 17:14:23.955 Boot: Chipset-sdm450 8.2.0.33(00UW)_SBL1 2021-03-25 17:14:24.073 System: System 8.2.0.036(04A0) 2021-03-25 17:14:24.154 MEID: 00000000000000 2021-03-25 17:14:24.236 PESN: 00000000 2021-03-25 17:14:24.318 IMEI A: 86939002 2021-03-25 17:14:24.400 Bluetooth MAC: 20A:22:C0 2021-03-25 17:14:24.481 WiFi MAC: 20A:22:C0 2021-03-25 17:14:24.563 S/N: 4FF6R19 2021-03-25 17:14:24.646 Board S/N: 6R5PGV1979 2021-03-25 17:14:24.728 Vendor Code: hw 2021-03-25 17:14:24.810 Country Code: meafnaf 2021-03-25 17:14:24.894 2021-03-25 17:14:24.976 Connect done. 2021-03-25 17:14:25.058 Performed by 1.2.4 Software version. 2021-03-25 17:15:08.801 2021-03-25 17:15:08 GMT ------------------------------------------------- 2021-03-25 17:15:08.881 Starting Repair Info 2021-03-25 17:15:08.971 Selected phone model: DUB-LX1 2021-03-25 17:15:09.051 New IMEI A: 86939002 2021-03-25 17:15:09.141 New IMEI B: 8693900 2021-03-25 17:15:09.221 New SIM Card Mode: double 2021-03-25 17:15:09.709 Repairing IMEI A... 2021-03-25 17:15:09.787 Private enc 0 2021-03-25 17:15:10.189 Private enc 0 2021-03-25 17:15:10.671 Private enc 0 2021-03-25 17:15:11.278 Repairing IMEI B... 2021-03-25 17:15:11.362 Private enc 0 2021-03-25 17:15:11.845 Repairing Sim Card Mode... 2021-03-25 17:15:11.929 Private enc 0 2021-03-25 17:15:12.406 Resetting your device 2021-03-25 17:15:12.491 2021-03-25 17:15:12.575 Repair Info done. 2021-03-25 17:15:12.659 Performed by 1.2.4 Software version. OK SOLVED |
The Following User Says Thank You to svetoslakis For This Useful Post: |
05-20-2021, 07:19 | #7 (permalink) | |
Junior Member Join Date: Jun 2009
Member: 1054445 Status: Offline Thanks Meter: 0 | Quote:
