Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #16 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2008
Member: 720264 Status: Offline Sonork: 100.1649278 Thanks Meter: 190 | 2023-02-08 11:41:08 Starting Reset Huawei ID Selected phone model: ART-AL00X Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN710_V1... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found android device: HYJNW18A27001862 Detected Android Sooner Single ADB Interface port Reading basic data... Device Model: ART-L29 System: ARTH-L29 10.1.0.227(C185E2R2P1) Android Version: 10 Base Version: ART-LGRP2-OVS 10.1.0.227 Custom Version: ARTH-L29-CUST 10.1.0.2(C185) Preload Version: ARTH-L29-PRELOAD 10.1.0.1(C185R2) C_Version: C185 D_Version: D000 FB Lock State: LOCKED User Lock State: LOCKED Connecting to the credit server... Username: Default_user Checking balance... Your balance: 0 credits Sending device information... Sending firmware information... Removing firmware protection... Connecting to server... Waiting for a response from the server... FB Lock State: UNLOCKED User Lock State: LOCKED Device Model: ART-L29 System: ARTH-L29 10.1.0.227(C185E2R2P1) Resetting Huawei ID... Rebooting device... Warning: Please perform "Clear data" manually via Recovery Mode, if your device doesn`t start properly! Reset Huawei ID done. Performed by 1.3.3 Software version. |
The Following User Says Thank You to naveed ali For This Useful Post: |
![]() | #17 (permalink) |
Insane Poster ![]() ![]() ![]() Join Date: Dec 2016 Location: Pakistan
Member: 2665448 Status: Offline Sonork: innocentsoul008 Thanks Meter: 15 | I tried with both version 1.3.3 and 1.3.2 but facing same issue Welcome to Octoplus Huawei Software v.1.3.2 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 1: COM70 USB Serial Port Selected IMEI_A file: C:/Users/Taha/Desktop/cert/octo/tanveer shop/2/STK-L21_IMEI_SLOT_1_867485045704330.obf Selected IMEI_B file: C:/Users/Taha/Desktop/cert/octo/tanveer shop/2/STK-L21_IMEI_SLOT_1_867485045704330.obf Warning: Connecting to remote service failed 2023-02-15 11:52:17 Starting Write Cert Selected phone model: VOG-L29 Error: Please make sure your internet connection is stable and try to repeat the operation Write Cert failed. Performed by 1.3.2 Software version. Warning: Connecting to remote service failed 2023-02-15 11:53:21 Starting Write Cert Selected phone model: VOG-L29 Error: Please make sure your internet connection is stable and try to repeat the operation Write Cert failed. Performed by 1.3.2 Software version. Warning: Connecting to remote service failed 2023-02-15 11:53:25 Starting Write Cert Selected phone model: VOG-L29 Error: Please make sure your internet connection is stable and try to repeat the operation Write Cert failed. Performed by 1.3.2 Software version. Job ID: 0000000001AA6854 2023-02-15 11:55:06 Starting Write Cert Selected phone model: VOG-L29 Selected method: Write cert (EMUI12/Harmony) Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN980_V4... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Operation in progress. Please wait for instructions... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Error: Fastboot devices not found Write Cert failed. Performed by 1.3.2 Software version. Job ID: 0000000001D4B30D 2023-02-15 11:57:50 Starting Write Cert Selected phone model: VOG-L29 Selected method: Write cert (EMUI 11) Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN980_V3... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Operation in progress. Please wait for instructions... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found android device: 026CVY202S000651 Detected Android Sooner Single ADB Interface port Username: i******** Connecting to the credit server... Checking balance... Your balance: 100 credits Sending device information... Sending firmware information... To perform this operation you need to have: 0 credits. Write Cert failed. Performed by 1.3.2 Software version. |
![]() | #20 (permalink) | ||
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2011 Age: 57
Member: 1564612 Status: Offline Thanks Meter: 12,329 ![]() | Quote:
2) select right Bootloader in COM1 (USB SER) 3) device after com 1 must reboot in FASTBOOT, (also if for write Cert, can do in COM1) 4) You have Internet connection issue, try with other Connection and post result. Not is Drivers issue | ||
![]() | #24 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2012 Location: srilanka(pearl island)
Member: 1848453 Status: Offline Thanks Meter: 55 ![]() | ART-L28 HUAWEI ID REMOVE DONE BY SELECTING ART-AL00X Welcome to Octoplus Huawei Software v.1.3.3 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 1: COM7 USB Serial Port Job ID: 0000000001D8D2A7 2023-02-27 13:06:30 Starting Reset Huawei ID Selected phone model: ART-AL00X Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN710_V1... Initializing remote service connection... Downloading resource... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found android device: UCY6R20317003708 Detected Android Sooner Single ADB Interface port Reading basic data... Device Model: ART-L28 System: ARTH-L28 10.1.0.223(C636E2R2P1) Android Version: 10 Base Version: ART-LGRP2-OVS 10.1.0.223 Custom Version: ARTH-L28-CUST 10.1.0.2(C636) Preload Version: ARTH-L28-PRELOAD 10.1.0.1(C636R2) C_Version: C636 D_Version: D000 FB Lock State: LOCKED User Lock State: LOCKED Downloading resource... Connecting to the credit server... Username: Default_user Checking balance... Your balance: 0 credits Sending device information... Sending firmware information... Removing firmware protection... Reset Huawei ID failed. Performed by 1.3.3 Software version. Your balance: 47 credit(s) Your balance: 47 credit(s) Job ID: 0000000001D8D373 2023-02-27 13:11:04 Starting Reset Huawei ID Selected phone model: ART-AL00X Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Phone connect successfully Writing bootloader KIRIN710_V1... Initializing remote service connection... Writing XLOADER partition... Writing UCE partition... Writing FASTBOOT partition... Bootloader Update successfully Rebooting to fastboot mode... Searching Fastboot devices... Found android device: UCY6R20317003708 Detected Android Sooner Single ADB Interface port Reading basic data... Device Model: ART-L28 System: ARTH-L28 10.1.0.223(C636E2R2P1) Android Version: 10 Base Version: ART-LGRP2-OVS 10.1.0.223 Custom Version: ARTH-L28-CUST 10.1.0.2(C636) Preload Version: ARTH-L28-PRELOAD 10.1.0.1(C636R2) C_Version: C636 D_Version: D000 FB Lock State: LOCKED User Lock State: LOCKED Downloading resource... Connecting to the credit server... Username: barakath143 Checking balance... Your balance: 47 credits Sending device information... Sending firmware information... Removing firmware protection... Connecting to server... Waiting for a response from the server... FB Lock State: UNLOCKED User Lock State: LOCKED Device Model: ART-L28 System: ARTH-L28 10.1.0.223(C636E2R2P1) Resetting Huawei ID... Rebooting device... Warning: Please perform "Clear data" manually via Recovery Mode, if your device doesn`t start properly! Reset Huawei ID done. Performed by 1.3.3 Software version. |
The Following User Says Thank You to barakath For This Useful Post: |
![]() | #25 (permalink) |
Member: 1848453 Status: Offline Thanks Meter: 55 ![]() | sht-w09 unlock done by selecting sht-al09 (same testpoint) 2023-04-17 06:37:28.549 Loading application settings 2023-04-17 06:37:28.591 Refreshing serial ports list 2023-04-17 06:37:28.602 Found COM ports: 2023-04-17 06:37:28.603 1: COM3 USB Serial Port 2023-04-17 06:37:28.603 2: COM116 RIM Virtual Serial Port v2 2023-04-17 06:37:28.603 3: COM117 RIM Virtual Serial Port v2 2023-04-17 06:37:29.919 Welcome to Octoplus Huawei Software v.1.3.3 2023-04-17 06:37:29.920 2023-04-17 06:37:29.920 To enable 'Manufacture' mode dial 2023-04-17 06:37:29.921 - for Qualcomm and Hisilicon based models: *#*#2846579#*#* 2023-04-17 06:37:29.921 ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode 2023-04-17 06:37:29.922 - for MTK based models: *#*#14789632#*#* 2023-04-17 06:37:29.923 ProjectMenu > Background Settings > USB Port Settings > Debug Mode 2023-04-17 06:37:29.923 2023-04-17 06:37:29.924 To enable 'Fastboot' mode 2023-04-17 06:37:29.924 1. Power off the phone. Remove SD and SIM cards 2023-04-17 06:37:29.925 2. Press 'Vol-' and insert USB cable 2023-04-17 06:37:29.925 3. Wait until phone enters 'Fastboot' mode 2023-04-17 06:37:29.926 2023-04-17 06:37:29.927 To enable 'Upgrade' mode 2023-04-17 06:37:29.927 1. Power off the phone. Remove SD and SIM cards 2023-04-17 06:37:29.928 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 2023-04-17 06:37:29.928 3. Wait until phone enters 'Upgrade mode' 2023-04-17 06:37:32.417 Refreshing serial ports list 2023-04-17 06:37:32.423 Found COM ports: 2023-04-17 06:37:32.425 1: COM3 USB Serial Port 2023-04-17 06:37:32.425 2: COM116 RIM Virtual Serial Port v2 2023-04-17 06:37:32.426 3: COM117 RIM Virtual Serial Port v2 2023-04-17 06:37:32.571 Init finished 2023-04-17 06:38:09.522 Job ID: 0000000001E6CC6E 2023-04-17 06:38:10.564 2023-04-17 06:38:10 2023-04-17 06:38:10.577 Starting Reset FRP 2023-04-17 06:38:10.581 Selected phone model: SHT-AL09 2023-04-17 06:38:17.387 Searching HUAWEI USB COM 1.0 port... 2023-04-17 06:38:17.393 Detected HUAWEI USB COM 1.0 port 2023-04-17 06:38:17.410 Phone connect successfully 2023-04-17 06:38:20.409 Downloading resource... 2023-04-17 06:39:04.889 Writing XLOADER partition... 2023-04-17 06:39:06.202 Writing UCE partition... 2023-04-17 06:39:07.227 Failed write UCE partition 2023-04-17 06:39:10.309 Downloading resource... 2023-04-17 06:39:32.308 Writing XLOADER partition... 2023-04-17 06:39:33.625 Writing UCE partition... 2023-04-17 06:39:34.647 Failed write UCE partition 2023-04-17 06:40:13.363 Downloading resource... 2023-04-17 06:40:34.690 Writing XLOADER partition... 2023-04-17 06:40:36.168 Writing UCE partition... 2023-04-17 06:40:37.195 Writing FASTBOOT partition... 2023-04-17 06:40:52.301 Bootloader Update successfully 2023-04-17 06:40:52.311 Rebooting to fastboot mode... 2023-04-17 06:40:52.327 Searching Fastboot devices... 2023-04-17 06:40:56.379 Total interfaces: 1 2023-04-17 06:40:56.379 Interface 0 : flags: 1, name(79): \\?\usb#vid_18d1&pid_d00d#5&25b61ef1&0&3#{f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} 2023-04-17 06:40:56.393 Found android device: JJN6R18427000052 2023-04-17 06:40:56.403 Detected Android Sooner Single ADB Interface port 2023-04-17 06:40:56.423 Reading basic data... 2023-04-17 06:40:56.436 Response contains FAIL! 2023-04-17 06:40:56.436 oem oeminforead-BASE_VERSION fail 2023-04-17 06:40:56.454 Response contains FAIL! 2023-04-17 06:40:56.454 oem oeminforead-CUSTOM_VERSION fail 2023-04-17 06:40:56.472 Response contains FAIL! 2023-04-17 06:40:56.472 oem oeminforead-PRELOAD_VERSION fail 2023-04-17 06:40:56.489 Response contains FAIL! 2023-04-17 06:40:56.490 oem oeminforead-hotainfo fail 2023-04-17 06:40:56.490 Reading product model 2023-04-17 06:40:58.499 Reading build number 2023-04-17 06:41:00.496 Device Model: SHT-W09 2023-04-17 06:41:00.507 System: SHT-W09 9.1.0.360(C635E8R1P2) 2023-04-17 06:41:00.519 Android Version: 9 2023-04-17 06:41:00.530 FB Lock State: UNLOCKED 2023-04-17 06:41:00.541 User Lock State: LOCKED 2023-04-17 06:41:03.499 Downloading resource... 2023-04-17 06:41:05.732 Writing FRP partition.. 2023-04-17 06:41:05.896 Response contains FAIL! 2023-04-17 06:41:05.896 Writing 0xC0000 frp data failed! 2023-04-17 06:41:07.223 Reset FRP done. 2023-04-17 06:41:07.236 Performed by 1.3.3 Software version |
The Following 2 Users Say Thank You to barakath For This Useful Post: |
![]() | #26 (permalink) |
Major Poster ![]() ![]() Join Date: Jun 2011
Member: 1596130 Status: Offline Thanks Meter: 2 | hello i need help plz AQM-L21A : dead after wrong flash repair boot done downgrade done remove huawei id done restor imei from backup obf done now the big problem no network ..... phone was have network befor i start flashing any solution plz |
![]() | #28 (permalink) | |
Member: 1596130 Status: Offline Thanks Meter: 2 | Quote:
hello yes i did full backup but when i writ it phone give problem chip damaged when downgrade phone work and no network 8 days now and i did evrey thing in that phone hhhhh can't slove it all who i ask say u need *******,i have medusa pro full activation and i like it bcoz saved me many time won't bay new box ty. Last edited by Octopus support; 05-22-2023 at 12:23. | |
