10-28-2020, 18:09 | #1 (permalink) |
Freak Poster Join Date: May 2014 Location: italy
Member: 2188821 Status: Offline Sonork: TECHNOLOGYFORLIFE Thanks Meter: 60 | p20 lite ane-lx1 Not soft testpoint [Answered] Starting ON/OFF Factory Mode Selected phone model: ANE-LX1 To Enable Factory mode put the phone in Upgrade mode and connect USB cable! To Disable Factory mode connect the phone in Factory mode or Factory Fastboot mode! Checking the existence of the auto firmware file... Selected firmware file file: C:/Users/uli/Downloads/Huawei P20 Lite ( Nova 3e ) ANE-L21 ANE-L01 hw eu Anne-L21 9.1.0.370(C432E7R1P7T8) Firmware EMUI9.1.0 05014YXX [androidhost.ru]/Software/dload/update_sd/UPDATE.APP Performing ON Factory Mode operation... Checking firmware package type Searching device in Upgrade mode... Connecting to phone.. Phone connect successfully! Writing firmware partitions... Writing SHA256RSA partition... Writing CRC partition... Writing VERLIST partition... Writing CURVER partition... Writing PACKAGE_TYPE partition... Writing HISIUFS_GPT partition... Writing XLOADER partition... Error: Failed write XLOADER partition Warning: Switching your device to Factory Mode is not possible! Please, connect your device via Test Point and perform the desired operation. ON/OFF Factory Mode failed. Performed by 1.2.2.2 Software version. |
10-28-2020, 18:12 | #2 (permalink) |
Member: 2188821 Status: Offline Sonork: TECHNOLOGYFORLIFE Thanks Meter: 60 | 2020-10-27 16:57:40.960 2020-10-27 16:57:40 GMT ------------------------------------------------- 2020-10-27 16:57:40.963 Starting Read Info (Fastboot Mode) 2020-10-27 16:57:40.967 Searching Fastboot devices... 2020-10-27 16:57:41.968 Total interfaces: 1 2020-10-27 16:57:41.968 Interface 0 : flags: 1, name(81): \\?\usb#vid_18d1&pid_d00d#89u4c19118001182#{f72fe0 d4-cbcb-407d-8814-9ed673d0dd6b} 2020-10-27 16:57:41.969 Found a fastboot device: 89U4C19118001182 2020-10-27 16:57:42.569 Reading serial number failed 2020-10-27 16:57:45.369 Product Model: ANE-LX1 2020-10-27 16:57:45.373 Build Number: ANE-LX1 9.1.0.368(C432E6R1P7) 2020-10-27 16:57:45.376 Region Code: C432E6R1P7 2020-10-27 16:57:45.380 Android Version: 9 2020-10-27 16:57:45.383 Base Version: ANE-LGRP2-OVS 9.1.0.368 2020-10-27 16:57:45.386 Custom Version: ANE-LX1-CUST 9.1.0.6(C432) 2020-10-27 16:57:45.390 Preload Version: ANE-LX1-PRELOAD 9.1.0.7(C432R1) 2020-10-27 16:57:45.394 C_Version: C432 2020-10-27 16:57:45.398 D_Version: D000 2020-10-27 16:57:45.403 DeviceName: ANE-L01 2020-10-27 16:57:45.407 2020-10-27 16:57:45.411 Read Info (Fastboot Mode) done. 2020-10-27 16:57:45.415 Performed by 1.2.2 Software version. 2020-10-27 16:58:37.346 2020-10-27 16:58:37 GMT ------------------------------------------------- 2020-10-27 16:58:37.350 Starting Reset FRP (Fastboot Mode) 2020-10-27 16:58:37.366 Searching Fastboot devices... 2020-10-27 16:58:38.358 Total interfaces: 1 2020-10-27 16:58:38.358 Interface 0 : flags: 1, name(81): \\?\usb#vid_18d1&pid_d00d#89u4c19118001182#{f72fe0 d4-cbcb-407d-8814-9ed673d0dd6b} 2020-10-27 16:58:38.359 Found a fastboot device: 89U4C19118001182 2020-10-27 16:58:40.960 Reading serial number failed 2020-10-27 16:58:45.360 Device Model: ANE-LX1 2020-10-27 16:58:45.365 System: ANE-LX1 9.1.0.368(C432E6R1P7) 2020-10-27 16:58:45.760 Connecting to server... 2020-10-27 16:58:47.053 FRP unlock 2 2020-10-27 16:58:47.549 Writing sign buf data 2020-10-27 16:58:47.550 Failed to write download size 2020-10-27 16:58:47.556 Failed to read initial Reset FRP data 2020-10-27 16:58:47.556 2020-10-27 16:58:47.561 Reset FRP (Fastboot Mode) failed. 2020-10-27 16:58:47.567 Performed by 1.2.2 Software version. 2020-10-27 17:01:48.357 2020-10-27 17:01:48 GMT ------------------------------------------------- 2020-10-27 17:01:48.373 Starting ON/OFF Factory Mode 2020-10-27 17:01:48.401 Selected phone model: ANE-LX1 2020-10-27 17:01:48.408 To Enable Factory mode put the phone in Upgrade mode and connect USB cable! 2020-10-27 17:01:48.414 To Disable Factory mode put the phone in Factory or Fastboot mode and connect USB cable! 2020-10-27 17:01:50.747 Performing ON Factory Mode operation... 2020-10-27 17:01:50.751 Checking firmware package type 2020-10-27 17:01:50.756 Initializing remote service connection... 2020-10-27 17:01:50.760 Downloading patch files from server... 2020-10-27 17:01:53.755 Searching device in Upgrade mode... 2020-10-27 17:01:53.778 Connecting to phone.. 2020-10-27 17:01:53.793 Phone connect successfully! 2020-10-27 17:01:53.800 Writing firmware partitions... 2020-10-27 17:01:53.807 Writing SHA256RSA partition... 2020-10-27 17:01:54.981 Writing CRC partition... 2020-10-27 17:01:56.122 Writing VERLIST partition... 2020-10-27 17:01:56.662 Failed write VERLIST partition 2020-10-27 17:02:06.684 Switching your device to Factory Mode is not possible! Please, connect your device via Test Point and perform the desired operation. 2020-10-27 17:02:06.692 2020-10-27 17:02:06.700 ON/OFF Factory Mode failed. 2020-10-27 17:02:06.707 Performed by 1.2.2 Software version. |
10-28-2020, 18:12 | #3 (permalink) |
Member: 2188821 Status: Offline Sonork: TECHNOLOGYFORLIFE Thanks Meter: 60 | 2020-10-27 17:07:58.674 2020-10-27 17:07:58 GMT ------------------------------------------------- 2020-10-27 17:07:58.781 Starting ON/OFF Factory Mode 2020-10-27 17:07:58.895 Selected phone model: ANE-LX1 2020-10-27 17:07:59.020 To Enable Factory mode put the phone in Upgrade mode and connect USB cable! 2020-10-27 17:07:59.130 To Disable Factory mode connect the phone in Factory mode or Factory Fastboot mode! 2020-10-27 17:07:59.237 Checking the existence of the auto firmware file... 2020-10-27 17:08:01.763 Performing ON Factory Mode operation... 2020-10-27 17:08:01.869 Checking firmware package type 2020-10-27 17:08:01.977 Initializing remote service connection... 2020-10-27 17:08:02.086 Downloading patch files from the server... 2020-10-27 17:08:03.982 Searching device in Upgrade mode... 2020-10-27 17:08:04.091 Connecting to phone.. 2020-10-27 17:08:04.197 Phone connect successfully! 2020-10-27 17:08:04.305 Writing firmware partitions... 2020-10-27 17:08:04.416 Writing SHA256RSA partition... 2020-10-27 17:08:05.188 Writing CRC partition... 2020-10-27 17:08:06.330 Writing VERLIST partition... 2020-10-27 17:08:06.856 Failed write VERLIST partition 2020-10-27 17:08:36.882 Switching your device to Factory Mode is not possible! Please, connect your device via Test Point and perform the desired operation. 2020-10-27 17:08:36.992 2020-10-27 17:08:37.101 ON/OFF Factory Mode failed. 2020-10-27 17:08:37.212 Performed by 1.2.2.2 Software version. |
10-28-2020, 19:24 | #4 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hello, can explain what are searcing of do in this very easy model? want remove FRP, want downgrade, explain exactly what have in mind of do becouse i'm viewing a little of attempt a case in these log |
10-28-2020, 19:39 | #5 (permalink) | ||
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
