Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octoplus Huawei Tool
Old 07-13-2021, 13:55   #196 (permalink)
AbDuLlAH kHaWaR's Avatar
Member: 1442994
Thanks Meter: 409
Huawei p30 lite mar-lx1a unlock done with tp free
job id: 00000000014227ea
2021-07-13 12:50:37 gmt -------------------------------------------------
starting connect
selected phone model: ‪mar-lx1a‬
searching huawei usb com 1.0 port...
Detected ‪huawei usb com 1.0‬ port
writing bootloader kirin710_v1...
Initializing remote service connection...
Downloading additional resources...
Writing ‪xloader‬ partition...
Writing ‪uce‬ partition...
Writing ‪fastboot‬ partition...
Bootloader update successfully
rebooting to fastboot mode...
Searching fastboot devices...
Found android device: Jrq4c19505000687
detected ‪android sooner single adb interface‬ port
device model: ‪mar-lx1a‬
system: ‪mar-l01a 10.0.0.435(irlc555e9r1p3)‬
fb lock state: ‪locked‬
user lock state: ‪locked‬
connect done.
Performed by ‪1.2.5.3‬ software version.
2021-07-13 12:52:28 gmt -------------------------------------------------
starting direct unlock
username: Octoplus888
connecting to the credit server...
Checking balance...
Your balance: 30 credits
sending device information...
Sending firmware information...
To perform this operation you need to have: 0 credits.
Removing firmware protection...
Connecting to server...
Waiting for a response from the server...
Fb lock state: ‪unlocked‬
saving backup of modem_secure...
Reading secure data...
Unlocking phone...
Rebooting device...
Direct unlock done.
The Following User Says Thank You to AbDuLlAH kHaWaR For This Useful Post:
Old 07-19-2021, 12:49   #197 (permalink)
Member: 1442994
Thanks Meter: 409
huawei JSN-21 FRP FMAIL REMOVED
Welcome to Octoplus Huawei Software v.‪1.2.5.3‬
To enable 'Manufacture' mode dial
- for Qualcomm and Hisilicon based models: *#*#2846579#*#*
ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode
- for MTK based models: *#*#14789632#*#*
ProjectMenu > Background Settings > USB Port Settings > Debug Mode
To enable 'Fastboot' mode
1. Power off the phone. Remove SD and SIM cards
2. Press 'Vol-' and insert USB cable
3. Wait until phone enters 'Fastboot' mode
To enable 'Upgrade' mode
2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable
3. Wait until phone enters 'Upgrade mode'
Found COM ports:
1: COM65 HUAWEI USB COM 1.0
2: COM1 Θύρα επικοινωνιών
Job ID: 00000000014906F1
2021-07-19 11:46:16 GMT -------------------------------------------------
Starting Reset FRP (Factory Mode)
Selected phone model: ‪JSN-L21‬
Username:
Warning: Invalid username
Reset FRP (Factory Mode) failed.
Performed by ‪1.2.5.3‬ Software version.
Your balance: 30 credit(s)
Job ID: 000000000149071E
2021-07-19 11:46:49 GMT -------------------------------------------------
Username: octoplus888
Connecting to the credit server...
Searching HUAWEI USB COM 1.0 port...
Detected ‪HUAWEI USB COM 1.0‬ port
Writing bootloader KIRIN710_V1...
Writing ‪XLOADER‬ partition...
Writing ‪UCE‬ partition...
Writing ‪FASTBOOT‬ partition...
Bootloader Update successfully
Rebooting to fastboot mode...
Searching Fastboot devices...
Found android device: 3QX4C20414007672
Device Model: ‪JSN-L21‬
System: ‪JSN-L21 9.1.0.360(C431E3R1P1)‬
Checking balance...
Sending device information...
FB Lock State: ‪UNLOCKED‬
User Lock State: ‪LOCKED‬
MEID: ‪00000000000000‬
IMEI A: ‪861825040173484‬
IMEI B: ‪861825040193524‬
S/N: ‪3QX4C20414007672‬
Resetting FRP...
Writing FRP partition..
Rebooting device...
Reset FRP (Factory Mode) done.
Old 07-19-2021, 21:33   #198 (permalink)
Member: 1442994
Thanks Meter: 409
HuAWEI P30 PRO VOG-L29 FRP GMAIL REMOVED WITH TP FREE
Found COM ports:
1: COM1 Communications Port
2: COM5 Android Adapter PCUI
3: COM6 DBAdapter Reserved Interface
4: COM7 HUAWEI Mobile Connect - Fake Acm Interface
Job ID: 000000000149B013
2021-07-19 20:13:28 GMT -------------------------------------------------
Starting ON/OFF Factory Mode
Selected phone model: ‪VOG-L29‬
To Enable Factory mode put the phone in Upgrade mode and connect USB cable!
To Disable Factory mode connect the phone in Factory mode or Factory Fastboot mode!
Checking the existence of the auto firmware file...
Performing ON Factory Mode operation...
Checking firmware package type
Searching device in Upgrade mode...
Detected ‪DBAdapter Reserved Interface‬ port
Connecting to phone..
Error: Device does not support this update file
Warning: Switching your device to Factory Mode is not possible! Please, connect your device via Test Point and perform the desired operation.
ON/OFF Factory Mode failed.
Job ID: 000000000149B3CC
2021-07-19 20:26:44 GMT -------------------------------------------------
Error: HUAWEI USB COM 1.0 port not found
Job ID: 000000000149B4E2
2021-07-19 20:30:47 GMT -------------------------------------------------
Writing bootloader KIRIN980_V1...
Found android device: 026FRD199R004610
Device Model: ‪VOG-L29‬
System: ‪VOG-L29 11.0.0.147(C431E8R2P3)‬
Checking balance...
Resetting FRP...
Rebooting device...
Old 07-21-2021, 16:50   #199 (permalink)
Member: 1442994
Thanks Meter: 409
HuAWEI P30 PRO VOG-L29 FRP GMAIL REMOVE WITH TP FREE
Found COM ports:
1: COM4 HUAWEI Mobile Connect - Fake Acm Interface
3: COM7 DBAdapter Reserved Interface
Job ID: 00000000014B555E
2021-07-21 15:36:29 GMT -------------------------------------------------
Job ID: 00000000014B558E
2021-07-21 15:37:11 GMT -------------------------------------------------
Job ID: 00000000014B578C
2021-07-21 15:47:21 GMT -------------------------------------------------
Username:
Job ID: 00000000014B579E
2021-07-21 15:47:48 GMT -------------------------------------------------
Found android device: 026AYU19AH002170
Device Model: ‪VOG-L09‬
System: ‪VOG-L09 11.0.0.147(C431E8R2P3)‬
Checking balance...
Resetting FRP...
Rebooting device...
Old 07-30-2021, 13:24   #200 (permalink)
Member: 1442994
Thanks Meter: 409
HUAWEI P20 PRO CLT-L09 UNLOCK DONE WITH TP
Found COM ports:
1: COM3 Standard Serial over Bluetooth link
2: COM4 Standard Serial over Bluetooth link
Job ID: 000000000154AE17
2021-07-30 12:21:54 GMT -------------------------------------------------
Starting Connect
Selected phone model: ‪CLT-L09‬
Writing bootloader KIRIN970_A8.1_V0...
Found android device: LCL7N19416000808
Detected ‪Android Sooner Single ADB Interface‬ port
Device Model: ‪CLT-L09‬
System: ‪CLT-L09 10.0.0.171(C432E3R1P3)‬
MEID: ‪A00000A7F72949‬
IMEI A: ‪869312042475847‬
IMEI B: ‪869312042475847‬
S/N: ‪LCL7N19416000808‬
Connect done.
2021-07-30 12:23:03 GMT -------------------------------------------------
Starting Direct Unlock
Saving backup of MODEM_SECURE...
Downloading unlock patch files...
Writing MODEM_SECURE partition...
Rebooting device...
Direct Unlock done.
Old 08-03-2021, 10:30   #201 (permalink)
Member: 1442994
Thanks Meter: 409
ANE-lX1 FRP GMAIL REMOVED WOTH TEST POINTS#
Found COM ports:
1: COM1 Θύρα επικοινωνιών
Job ID: 000000000158D707
2021-08-03 09:28:28 GMT -------------------------------------------------
Selected phone model: ‪ANE-LX1‬
Writing bootloader KIRIN659_A8.0_V1...
Found android device: 89UDU18420001179
Device Model: ‪ANE-LX1‬
System: ‪ANE-LX1 9.1.0.378(C55E9R1P6)‬
IMEI A: ‪867906033848615‬
IMEI B: ‪000000000000000‬
S/N: ‪89UDU18420001179‬
Old 08-03-2021, 17:45   #202 (permalink)
Member: 1442994
Thanks Meter: 409
ANE-LX1 UNLOCK WITH TP FREE
Found COM ports:
1: COM22 HUAWEI USB COM 1.0
Job ID: 0000000001596FA8
2021-08-03 16:44:18 GMT -------------------------------------------------
Starting Connect
Found android device: 89UDU19304000846
System: ‪ANE-LX1 9.1.0.381(C432E7R1P7)‬
IMEI A: ‪867440048686968‬
S/N: ‪89UDU19304000846‬
Connect done.
2021-08-03 16:45:07 GMT -------------------------------------------------
Error: Can't get file ImeiFile_I1.bin!
Error: Can't get file ImeiFile_I1.hash!
Rebooting device...
Direct Unlock done.
Old 08-11-2021, 14:05   #203 (permalink)
Member: 1442994
Thanks Meter: 409
Found COM ports:
Job ID: 00000000016274A3
2021-08-11 12:55:44 GMT -------------------------------------------------
Starting Connect
Selected phone model: ‪MAR-LX1A‬
Found android device: JRQ0220525005462
Device Model: ‪MAR-LX1A‬
System: ‪MAR-L01A 10.0.0.470(C431E14R2P7)‬
FB Lock State: ‪LOCKED‬
Connect done.
2021-08-11 12:57:08 GMT -------------------------------------------------
Checking balance...
Direct Unlock failed.
Job ID: 00000000016276EF
2021-08-11 13:01:55 GMT -------------------------------------------------
Starting Connect
Connect done.
2021-08-11 13:03:07 GMT -------------------------------------------------
Checking balance...
Unlocking phone...
Rebooting device...
Direct Unlock done.
Old 08-11-2021, 14:30   #204 (permalink)
Member: 1442994
Thanks Meter: 409
Found COM ports:
Job ID: 0000000001627ED7
2021-08-11 13:25:14 GMT -------------------------------------------------
Starting Connect
Canceling... Please be patient!
Connect canceled.
Job ID: 0000000001627F1D
2021-08-11 13:26:04 GMT -------------------------------------------------
Starting Connect
Connect canceled.
Job ID: 0000000001627F66
2021-08-11 13:26:51 GMT -------------------------------------------------
Starting Connect
Found android device: JRQ0219726000734
System: ‪MAR-L01A 10.0.0.435(IRLC555E9R1P3)‬
Connect done.
2021-08-11 13:28:38 GMT -------------------------------------------------
Username:
2021-08-11 13:28:53 GMT -------------------------------------------------
Checking balance...
Unlocking phone...
Rebooting device...
Direct Unlock done.
Old 08-13-2021, 16:19   #205 (permalink)
Member: 1442994
Thanks Meter: 409
Found COM ports:
Job ID: 000000000165032E
2021-08-13 15:13:19 GMT -------------------------------------------------
Starting Connect
Selected phone model: ‪MYA-L11‬
Please Power off the phone and insert USB cable
MTK Preloader COM port is not found
Connect failed.
Job ID: 00000000016503AD
2021-08-13 15:14:44 GMT -------------------------------------------------
Starting Connect
Connect failed.
Job ID: 000000000165041B
2021-08-13 15:16:15 GMT -------------------------------------------------
Starting Connect
Detected ‪MediaTek PreLoader USB VCOM (Android)‬ port
Error: Auto Boot Flash Tool
Try to "Power ON" / "Power OFF" device and perform operation again
Connect failed.
Job ID: 000000000165042B
2021-08-13 15:16:29 GMT -------------------------------------------------
Starting Connect
Searching devices in META mode
Switching device to MTK META mode
Send para V1 OK!
Waiting for device loading
BaseBand chip: MT6737T,S01
S/W version: Maya-L11C432B183
H/W board version: S01
BaseBand chip: ‪MT6735, E00‬
S/W version: ‪MOLY.LR9.W1444.MD.LWTG.MP.V94.P66‬
H/W board version: ‪HQ6737T_66_1HA_M0_HW‬
IMEI A: ‪867545037753767‬
IMEI B: ‪FFFFFFFFFFFFFFF‬
Connect done.
2021-08-13 15:17:03 GMT -------------------------------------------------
Reading mddb from target
Reading sim lock info...
Writing unlock data. Step 1
Writing unlock data. Step 2
Direct Unlock done.
Old 08-19-2021, 10:12   #206 (permalink)
Member: 1442994
Thanks Meter: 409
Welcome to Octoplus Huawei Software v.?1.2.5.3?
Found COM ports:
1: COM68 Standard Serial over Bluetooth link
2: COM5 DBAdapter Reserved Interface
3: COM6 Android Adapter PCUI
Job ID: 00000000014B212E
2021-07-21 10:58:42 GMT -------------------------------------------------
Selected phone model: ?VOG-L29?
Detected ?DBAdapter Reserved Interface? port
Performed by ?1.2.5.3? Software version.
Job ID: 00000000014B213B
2021-07-21 10:58:57 GMT -------------------------------------------------
Phone connect successfully!
Writing firmware partitions...
Writing ?SHA256RSA? partition...
Writing ?CRC? partition...
Writing ?BASE_VERLIST? partition...
Writing ?BASE_VER? partition...
Writing ?PACKAGE_TYPE? partition...
Writing ?HISIUFS_GPT? partition...
ON/OFF Factory Mode done.
Job ID: 00000000014B21E1
2021-07-21 11:01:54 GMT -------------------------------------------------
Performing OFF Factory Mode operation...
Detected ?HUAWEI USB COM 1.0? port
Writing ?XLOADER? partition...
Writing ?UCE? partition...
Writing ?FASTBOOT? partition...
Found android device: 026AYU204V004955
Detected ?Android Sooner Single ADB Interface? port
Device Model: ?VOG-L09?
System: ?VOG-L09 9.1.0.280(C431E4R2P2)?
FB Lock State: ?UNLOCKED?
User Lock State: ?LOCKED?
Writing secure data...
Rebooting device...
Job ID: 00000000014B2279
2021-07-21 11:04:42 GMT -------------------------------------------------
Job ID: 00000000014B2287
2021-07-21 11:04:53 GMT -------------------------------------------------
Job ID: 00000000014B22A9
2021-07-21 11:05:23 GMT -------------------------------------------------
Checking balance...
MEID: ?A00000B6CC9ED4?
IMEI A: ?866473044363820?
IMEI B: ?866473044363820?
Resetting FRP...
Rebooting device...
Job ID: 00000000014B230D
2021-07-21 11:07:54 GMT -------------------------------------------------
Rebooting device...
Old 08-23-2021, 16:04   #207 (permalink)
Member: 1442994
Thanks Meter: 409
p30 lite unlock with testpoints
Found COM ports:
Job ID: 00000000016F61EF
2021-08-23 15:00:43 GMT -------------------------------------------------
Starting Connect
Found android device: 36V4C20813000721
Connect done.
2021-08-23 15:02:09 GMT -------------------------------------------------
Checking balance...
Unlocking phone...
Rebooting device...
Direct Unlock done.
Old 10-14-2021, 12:03   #208 (permalink)
Member: 1442994
Thanks Meter: 409
Job ID: 0000000001AAE3CD
2021-10-14 11:02:09 GMT -------------------------------------------------
Starting Reset FRP
Selected phone model: ‪EVA-L09‬
Found android device: MWSPG18425900309
Device Model: ‪EVA-L09‬
System: ‪EVA-L09C02B361‬
IMEI A: ‪864822032531941‬
IMEI B: ‪869827020135386‬
S/N: ‪MWSPG18425900309‬
Writing Reset FRP data...
Reset FRP done.
Performed by ‪1.2.6.1‬ Software version.
Old 10-14-2021, 12:29   #209 (permalink)
Member: 1442994
Thanks Meter: 409
Job ID: 0000000001AAEC33
2021-10-14 11:26:56 GMT -------------------------------------------------
Starting Reset FRP
Found android device: L2N4C19919005195
Checking balance...
System: ‪MAR-L21A 10.0.0.448(C431E13R2P7)‬
Resetting FRP...
Rebooting device...
Reset FRP done.
Old 10-30-2021, 12:34   #210 (permalink)
Member: 1442994
Thanks Meter: 409
Welcome to Octoplus Huawei Software v.‪1.2.6.1‬
Found COM ports:
1: COM3 Intel(R) Active Management Technology - SOL
Job ID: 0000000001BDEE38
2021-10-30 11:29:18 GMT -------------------------------------------------
Found android device: JRQDU19903001614
Username: Default_user
Checking balance...
Your balance: 0 credits
Error: Server Authorization failed. ‪Response timed out‬
Job ID: 0000000001BDEF1B
2021-10-30 11:32:05 GMT -------------------------------------------------
Checking balance...
Unlocking phone...
Rebooting device...
Direct Unlock done.
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.36696 seconds with 7 queries
