07-22-2018, 19:13 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: pakistan
Member: 270869 Status: Offline Sonork: 100.1600061 Thanks Meter: 433 | ATH-AL00 flashing error [Answered] 2018-07-22 17:15:12.115 2018-07-22 17:15:12.116 To enable 'Manufacture' mode dial 2018-07-22 17:15:12.117 - for Qualcomm and Hisilicon based models: *#*#2846579#*#* 2018-07-22 17:15:12.118 ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode 2018-07-22 17:15:12.119 2018-07-22 17:15:12.120 To enable 'Fastboot' mode 2018-07-22 17:15:12.121 1. Power off the phone. Remove SD and SIM cards 2018-07-22 17:15:12.122 2. Press 'Vol-' and insert USB cable 2018-07-22 17:15:12.123 3. Wait until phone enters 'Fastboot' mode 2018-07-22 17:15:12.142 Refreshing serial ports list 2018-07-22 17:15:12.571 Found COM ports: 2018-07-22 17:15:12.572 1: COM1 Communications Port 2018-07-22 17:15:12.572 2: COM7 USB Serial Port 2018-07-22 17:15:12.573 3: COM3 Intel(R) Active Management Technology - SOL 2018-07-22 17:15:12.573 Loading application settings 2018-07-22 17:15:12.575 Init finished 2018-07-22 17:15:42.032 Selected file: F:/Huawei/7i/ATH-UL00/Software/dload/UPDATE.APP 2018-07-22 17:16:22.896 2018-07-22 17:16:22 GMT ------------------------------------------------- 2018-07-22 17:16:22.898 Starting Write Firmware 2018-07-22 17:16:22.905 Searching for connected Fastboot devices... 2018-07-22 17:16:23.905 Total interfaces: 1 2018-07-22 17:16:23.905 Interface 0: flags: 1, name(73): \\?\usb#vid_18d1&pid_d00d#cd8bd4f5#{f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} 2018-07-22 17:16:24.706 Device Model: ATH-TL00 2018-07-22 17:16:25.107 Extracting firmware partitions... 2018-07-22 17:16:31.770 partition has been extract successfully 2018-07-22 17:16:31.770 Checking firmware compatibility 2018-07-22 17:16:33.817 Selected firmware is not compatible with your device revision. Writing of this firmware may lead to phone damage! You can write firmware at your own risk. Do you want to write firmware? 2018-07-22 17:16:34.218 Connecting to server... 2018-07-22 17:16:35.445 FRP unlock 0 2018-07-22 17:16:35.751 Writing erase FRP data 2018-07-22 17:16:41.753 Writing RPM partition.. 2018-07-22 17:16:42.558 RPM partition has been written successfully 2018-07-22 17:16:42.559 Writing TZ partition.. 2018-07-22 17:16:43.374 TZ partition has been written successfully 2018-07-22 17:16:43.374 Writing SBL1 partition.. 2018-07-22 17:16:44.184 SBL1 partition has been written successfully 2018-07-22 17:16:44.184 Writing MODEM partition.. 2018-07-22 17:16:48.644 MODEM partition has been written successfully 2018-07-22 17:16:48.644 Writing HYP partition.. 2018-07-22 17:16:49.452 HYP partition has been written successfully 2018-07-22 17:16:49.453 Writing FSG partition.. 2018-07-22 17:16:50.255 FSG partition has been written successfully 2018-07-22 17:16:50.256 Writing RECOVERY partition.. 2018-07-22 17:16:53.414 RECOVERY partition has been written successfully 2018-07-22 17:16:53.415 Writing ERECOVERY partition.. 2018-07-22 17:16:56.575 ERECOVERY partition has been written successfully 2018-07-22 17:16:56.576 Writing SYSTEM partition.. 2018-07-22 17:19:56.292 Error: Failed write SYSTEM partition 2018-07-22 17:19:56.293 2018-07-22 17:19:56.293 Write Firmware done. 2018-07-22 17:19:56.294 Performed by 1.0.2 Software version. 2018-07-22 17:26:59.980 2018-07-22 17:26:59 GMT ------------------------------------------------- 2018-07-22 17:26:59.982 Starting Write Firmware 2018-07-22 17:26:59.991 Searching for connected Fastboot devices... 2018-07-22 17:27:15.753 Error: Fastboot devices not found 2018-07-22 17:27:15.753 2018-07-22 17:27:15.754 Write Firmware failed. 2018-07-22 17:27:15.754 Performed by 1.0.2 Software version. 2018-07-22 17:35:22.325 Selected file: F:/Huawei/7i/ATH-UL00/B399/Software/dload/UPDATE.APP 2018-07-22 17:35:48.744 2018-07-22 17:35:48 GMT ------------------------------------------------- 2018-07-22 17:35:48.746 Starting Write Firmware 2018-07-22 17:35:48.749 Searching for connected Fastboot devices... 2018-07-22 17:35:49.749 Total interfaces: 1 2018-07-22 17:35:49.750 Interface 0: flags: 1, name(73): \\?\usb#vid_18d1&pid_d00d#cd8bd4f5#{f72fe0d4-cbcb-407d-8814-9ed673d0dd6b} 2018-07-22 17:35:50.550 Device Model: ATH-UL00 2018-07-22 17:35:50.951 Extracting firmware partitions... 2018-07-22 17:36:00.092 partition has been extract successfully 2018-07-22 17:36:00.093 Checking firmware compatibility 2018-07-22 17:36:02.345 Selected firmware is not compatible with your device revision. Writing of this firmware may lead to phone damage! You can write firmware at your own risk. Do you want to write firmware? 2018-07-22 17:36:02.746 Connecting to server... 2018-07-22 17:36:03.812 FRP unlock 0 2018-07-22 17:36:04.117 Writing erase FRP data 2018-07-22 17:36:10.118 Writing RPM partition.. 2018-07-22 17:36:10.945 RPM partition has been written successfully 2018-07-22 17:36:10.945 Writing TZ partition.. 2018-07-22 17:36:11.769 TZ partition has been written successfully 2018-07-22 17:36:11.770 Writing SBL1 partition.. 2018-07-22 17:36:12.583 SBL1 partition has been written successfully 2018-07-22 17:36:12.584 Writing MODEM partition.. 2018-07-22 17:36:15.836 MODEM partition has been written successfully 2018-07-22 17:36:15.837 Writing HYP partition.. 2018-07-22 17:36:16.644 HYP partition has been written successfully 2018-07-22 17:36:16.644 Writing FSG partition.. 2018-07-22 17:36:17.476 FSG partition has been written successfully 2018-07-22 17:36:17.476 Writing RECOVERY partition.. 2018-07-22 17:36:20.704 RECOVERY partition has been written successfully 2018-07-22 17:36:20.705 Writing ERECOVERY partition.. 2018-07-22 17:36:23.908 ERECOVERY partition has been written successfully 2018-07-22 17:36:23.909 Writing SYSTEM partition.. 2018-07-22 17:39:36.056 Error: Failed write SYSTEM partition 2018-07-22 17:39:36.056 2018-07-22 17:39:36.057 Write Firmware done. 2018-07-22 17:39:36.057 Performed by 1.0.2 Software version. Last edited by Octopus box; 07-23-2018 at 06:03. |
07-23-2018, 06:02 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Please try to write another firmware for this device model and post here the result. Also, please write us here link to firmware, which You have used, we will check it. |
07-24-2018, 19:54 | #3 (permalink) |
Member: 270869 Status: Offline Sonork: 100.1600061 Thanks Meter: 433 | its ath-al00 refurbished phone no imei and serial no. i will try many file but not success problem come with other person flash for playstore... any solution....... |
07-24-2018, 20:18 | #4 (permalink) |
Member: 270869 Status: Offline Sonork: 100.1600061 Thanks Meter: 433 | Another file write Error Welcome to Octoplus/Octopus Huawei Software v.1.0.2 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode Selected file: F:/Huawei/7i/New folder (3)/UPDATE.APP 2018-07-24 18:55:18 GMT ------------------------------------------------- Starting Write Firmware Searching for connected Fastboot devices... Error: Fastboot devices not found Write Firmware failed. Performed by 1.0.2 Software version. 2018-07-24 18:55:38 GMT ------------------------------------------------- Starting Write Firmware Searching for connected Fastboot devices... Error: Fastboot devices not found Write Firmware failed. Performed by 1.0.2 Software version. 2018-07-24 18:56:08 GMT ------------------------------------------------- Starting Write Firmware Searching for connected Fastboot devices... Device Model: ATH-UL00 Extracting firmware partitions... partition has been extract successfully Checking firmware compatibility Selected firmware is not compatible with your device revision. Writing of this firmware may lead to phone damage! You can write firmware at your own risk. Do you want to write firmware? Connecting to server... Writing ERECOVERY partition.. ERECOVERY partition has been written successfully Writing FSG partition.. FSG partition has been written successfully Writing HYP partition.. HYP partition has been written successfully Writing MODEM partition.. MODEM partition has been written successfully Writing RECOVERY partition.. RECOVERY partition has been written successfully Writing RPM partition.. RPM partition has been written successfully Writing SBL1 partition.. SBL1 partition has been written successfully Writing SYSTEM partition.. Error: Failed write SYSTEM partition Write Firmware done. Performed by 1.0.2 Software version. |
