09-23-2021, 19:31 | #1 (permalink) |
Freak Poster Join Date: Feb 2014 Location: Pakistan Age: 38
Member: 2135915 Status: Offline Thanks Meter: 50 | Huawei y6p med-lx9 huawei id reset done. Welcome to Octoplus Huawei Software v.1.2.6 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 1: COM13 USB Serial Port 2: COM79 Android Adapter PCUI 3: COM80 DBAdapter Reserved Interface Job ID: 000000000192CA90 2021-09-23 18:07:31 GMT ------------------------------------------------- Starting Reset Huawei ID Selected phone model: MED-LX9 Please, put your device in Factory mode (use "ON/OFF Factory Mode" option or Hardware Test Point) and insert USB cable MediaTek USB Port is not found Reset Huawei ID failed. Performed by 1.2.6 Software version. Job ID: 000000000192CAE7 2021-09-23 18:08:43 GMT ------------------------------------------------- Starting ON/OFF Factory Mode Selected phone model: MED-LX9 To Enable Factory mode put the phone in Upgrade mode and connect USB cable! To Disable Factory mode connect the phone in Factory mode or Factory Fastboot mode! Checking the existence of the auto firmware file... Warning: Switching your device to Factory Mode is not possible! Please, connect your device via Test Point and perform the desired operation. ON/OFF Factory Mode failed. Performed by 1.2.6 Software version. Job ID: 000000000192CB00 2021-09-23 18:09:07 GMT ------------------------------------------------- Starting ON/OFF Factory Mode Selected phone model: MED-LX9 To Enable Factory mode put the phone in Upgrade mode and connect USB cable! To Disable Factory mode connect the phone in Factory mode or Factory Fastboot mode! Canceling... Please be patient! Error: No devices to ON/OFF factory mode! ON/OFF Factory Mode failed. Performed by 1.2.6 Software version. Job ID: 000000000192CB16 2021-09-23 18:09:32 GMT ------------------------------------------------- Starting Reset Huawei ID Selected phone model: MED-LX9 Please, put your device in Factory mode (use "ON/OFF Factory Mode" option or Hardware Test Point) and insert USB cable Detected MediaTek USB Port_V1633 port Detecting Chip Version... HW Chip : MT6765 HW Version : 8A00.CA00.0000.0000 Initializing remote service connection... Downloading Mtk Loader... Downloading additional resources... Writing loader... DA successfully sent Reconnecting... Detected MediaTek PreLoader USB VCOM_V1633 (Android) port Downloading additional resources... Initializing remote service connection... Downloading secure data... Downloading additional resources... Reading secure data dump done! Resetting Huawei ID... Reset Huawei ID done. Performed by 1.2.6 Software version. huawei id reset done but keboard not working 3g 4g is working |
The Following 3 Users Say Thank You to shazebmobile For This Useful Post: |
