Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octoplus Huawei Tool
Old 10-18-2023, 13:48   #406 (permalink)
djmurod86's Avatar
Member: 455852
Sonork: 100.1596308
Thanks Meter: 1,992
‪hry-l21t 12.0.0.221(c10e2r1p3)‬ frp done
Job ID: 00000000024B225C
2023-10-18 12:45:27
Starting Reset FRP
Selected phone model: ‪HRY-LX1T‬
Warning: Please, make sure the phone`s battery is fully charged and connected, after connect the device via Factory Mode (use Hardware Test Point or "ON/OFF Factory Mode option").
Warning: Selected response: Proceed
Searching HUAWEI USB COM 1.0 port...
Detected ‪HUAWEI USB COM 1.0‬ port
Phone connect successfully
Writing bootloader KIRIN710_V1...
Initializing remote service connection...
Writing ‪XLOADER‬ partition...
Writing ‪UCE‬ partition...
Writing ‪FASTBOOT‬ partition...
Bootloader Update successfully
Rebooting to fastboot mode...
Warning: If you use modified USB cable please reconnect cable from the mother board and press "Ok" to proceed the operation
Warning: Selected response: Ok
Searching Fastboot devices...
Found android device: XELNW19709000986
Detected ‪Android Sooner Single ADB Interface‬ port
Reading basic data...
Device Model: ‪HRY-LX1T‬
System: ‪HRY-L21T 12.0.0.221(C10E2R1P3)‬
Android Version: ‪10‬
Base Version: ‪HRY-LGRP4-OVS 102.0.0.221‬
Custom Version: ‪HRY-L21T-CUST 102.0.0.2(C10)‬
Preload Version: ‪HRY-L21T-PRELOAD 102.0.0.3(C10R1)‬
C_Version: ‪C10‬
D_Version: ‪D000‬
FB Lock State: ‪LOCKED‬
User Lock State: ‪LOCKED‬
Downloading resource...
Connecting to the credit server...
Username: XXXXXXXX
Checking balance...
Your balance: 100 credits
Sending device information...
Sending firmware information...
Removing firmware protection...
Connecting to server...
Waiting for a response from the server...
FB Lock State: ‪UNLOCKED‬
Resetting FRP...
Writing FRP partition..
Rebooting device...
Reset FRP done.
Performed by ‪1.3.4‬ Software version.
The Following 2 Users Say Thank You to djmurod86 For This Useful Post:
Old 11-07-2023, 17:08   #407 (permalink)
Member: 1797426
Thanks Meter: 283
Huawei MediaPad M5 Lite BAH2-L09 Reset FRP done
2023-11-07 11:14:57.685 Selected phone model: BAH2-L09
2023-11-07 11:14:57.741 Searching Fastboot devices...
2023-11-07 11:14:59.819 Total interfaces: 1
2023-11-07 11:14:59.819 Interface 0 : flags: 1, name(79): \\?\usb#vid_18d1&pid_d00d#6&1453ecc3&0&1#{f72fe0d4-cbcb-407d-8814-9ed673d0dd6b}
2023-11-07 11:14:59.819 Found android device: QXDNU19807100976
2023-11-07 11:14:59.839 Detected Android Sooner Single ADB Interface port
2023-11-07 11:14:59.869 Reading product model
2023-11-07 11:15:01.869 Reading build number
2023-11-07 11:15:03.879 Reading basic data...
2023-11-07 11:15:05.002 Reading product model
2023-11-07 11:15:06.008 Reading build number
2023-11-07 11:15:08.033 Response contains FAIL!
2023-11-07 11:15:08.034 oem oeminforead-BASE_VERSION fail
2023-11-07 11:15:09.046 Response contains FAIL!
2023-11-07 11:15:09.047 oem oeminforead-CUSTOM_VERSION fail
2023-11-07 11:15:12.075 Device Model: BAH2-L09
2023-11-07 11:15:12.085 System: BAH2-L09 8.0.0.360(OCEC10)
2023-11-07 11:15:12.095 Android Version: 8.0.0
2023-11-07 11:15:12.105 C_Version: C10
2023-11-07 11:15:12.105 D_Version: D001
2023-11-07 11:15:14.105 Downloading resource...
2023-11-07 11:15:15.175 Reading product model
2023-11-07 11:15:16.955 Reading build number
2023-11-07 11:15:18.995 Connecting to server...
2023-11-07 11:15:20.195 FRP unlock 2
2023-11-07 11:15:20.545 Writing sign buf data
2023-11-07 11:15:21.906 Writing Reset FRP data...
2023-11-07 11:15:21.935 Reset FRP done.
2023-11-07 11:15:21.952 Performed by 1.3.4 Software version.
The Following User Says Thank You to ivannikolaevich For This Useful Post:
Old 11-28-2023, 06:58   #408 (permalink)
Member: 2684254
Sonork: 1-212-228-9600
Thanks Meter: 64
Huawei Y5 2019 (AMN-LX9) Reset FRP done
Job ID: 000000000XXXXX
2023-11-27 22:15:23
Starting Reset FRP
Selected phone model: ‪AMN-LX9‬
Please, put your device in Factory mode (use "ON/OFF Factory Mode" option or Hardware Test Point) and insert USB cable
Detected ‪MediaTek USB Port‬ port
Handshake done
Detecting Chip Version...
HW Chip : MT6761
HW Version : 8A00.CA01.0200.0000
Brom Version: 5
Boot Loader Version: FE
Sending Authentication Data...
Using MTK_AllInOne_DA_v3.3001.2018/10/18.17:38_452898 download agent...
Found a suitable Download agent
Sending Download Agent...
DA successfully sent
Synchronizing with DA...
Mobile Status: SYNC
Mobile Status: brom
Sending BootLoader Info...
Initializing Memory Flash...
Initialization completed
Sending Loader...
Mobile Status: SYNC
Loader successfully sent
Reading Flash Info...
EMMC rpmb size : 4 Mb
EMMC boot1 size : 4 Mb
EMMC boot2 size : 4 Mb
EMMC gp1 size : 0 Mb
EMMC gp2 size : 0 Mb
EMMC gp3 size : 0 Mb
EMMC gp4 size : 0 Mb
EMMC user area size : 15028 Mb
IMEI A: ‪86XXXXXXXXXXXX
IMEI B: ‪86XXXXXXXXXXXX
Reading Partition Table
Reading FRP Partition
Removing FRP secure data...
Reset FRP done.
The Following User Says Thank You to Jorabek-1987 For This Useful Post:
Old 12-07-2023, 19:57   #409 (permalink)
Member: 2951556
Thanks Meter: 69
frp dra-lx3 (huawey y5 2018) done
The Following 2 Users Say Thank You to RMESystems For This Useful Post:
Old 12-15-2023, 19:13   #410 (permalink)
Member: 2951556
Thanks Meter: 69
Welcome to Octoplus Huawei Software v.‪1.3.4‬
Para activar el modo 'Manufacture' marque
- para dispositivos basados en procesadores Qualcomm y Hisilicon: *#*#2846579#*#*
ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode
- for MTK based models: *#*#14789632#*#*
ProjectMenu > Background Settings > USB Port Settings > Debug Mode
Para activar el modo 'Fastboot'
1. Apague el dispositivo. Retire las tarjetas SD y SIM
2. Presione 'Vol-' y enchufe el cable USB
3. Espere hasta que el dispositivo se ponga en el modo 'Fastboot'
Para activar modo 'Upgrade'
2. Pulse los botones 'Vol-' y 'Vol+' y conecte el cable USB
3. Espere para que el teléfono entre en el modo 'Upgrade mode'
Puertos COM encontrados:
1: COM28 HUAWEI Mobile Connect - Fake Acm Interface
2: COM5 USB Serial Port
3: COM29 Android Adapter PCUI
4: COM31 DBAdapter Reserved Interface
Job ID: 0000000002695C80
2023-12-15 18:01:29
Iniciando Reset FRP
Modelo de teléfono seleccionado: ‪STK-L03‬
Advertencia: Please, make sure the phone`s battery is fully charged and connected, after connect the device via Factory Mode (use Hardware Test Point or "ON/OFF Factory Mode option").
Advertencia: Selected response: Proceed
Error: HUAWEI USB COM 1.0 port not found
Error: Fastboot dispositivos no encontrados
Reset FRP fallido.
Ejecutado por ‪1.3.4‬ versión de software.
Job ID: 0000000002695CBE
2023-12-15 18:03:38
Iniciando Reset FRP
Grabando ‪XLOADER‬ sección...
Grabando ‪UCE‬ sección...
Grabando ‪FASTBOOT‬ sección...
Advertencia: If you use modified USB cable please reconnect cable from the mother board and press "Ok" to proceed the operation
Advertencia: Selected response: Ok
Found android device: WTFNW20630000379
Leyendo datos básicos...
Modelo de dispositivo: ‪STK-LX3‬
Sistema: ‪STK-L23B 12.0.0.225(C605E2R2P1)‬
Versión de Android: ‪10‬
Base Version: ‪STK-LGRP10-OVS 102.0.0.225‬
Custom Version: ‪STK-L23B-CUST 102.0.0.2(C605)‬
Preload Version: ‪STK-L23B-PRELOAD 102.0.0.1(C605R2)‬
C_Version: ‪C605‬
D_Version: ‪D1‬
Username: oct_xxxxxxx
Checking balance...
Conectando con servidor...
Resetting FRP...
Grabando FRP sección..
Rebooting device...
Reset FRP ejecutado.
The Following User Says Thank You to RMESystems For This Useful Post:
Old 12-19-2023, 07:01   #411 (permalink)
Dr_Wolodya's Avatar
Member: 75408
Thanks Meter: 1,190
‪HRY-LX1 Read Cert successfully done:
Job ID: 00000000018E5FFB
2023-12-19 04:25:11
Starting Read Cert
Selected phone model: ‪HRY-LX1‬
Found android device: VFFDU18C01001695
Device Model: ‪HRY-LX1‬
System: ‪HRY-LX1 9.1.0.273D(C652E3R1P12)‬
Reading certificate files...
Reading certificate for IMEI A...
Reading certificate for IMEI B...
Rebooting device...
Read Cert done.
The Following 2 Users Say Thank You to Dr_Wolodya For This Useful Post:
Old 12-22-2023, 15:55   #412 (permalink)
Member: 2951556
Thanks Meter: 69
Job ID: 00000000026D1972
2023-12-22 14:32:46
Iniciando Reset FRP
Modelo de teléfono seleccionado: ‪AMN-L23‬
Detected ‪MediaTek USB Port_V1632‬ port
Handshake done
HW Chip : MT6761
Brom Version: 5
Enviando DA...
DA enviado exitosamente
Sincronizando con DA...
Mobile Status: SYNC
Mobile Status: brom
Enviando la información de BootLoader...
Inicialización de memoria Flash...
Inicialización finalizada
Enviando cargador...
Mobile Status: SYNC
Cargador enviado exitosamente
Leyendo la información Flash...
EMMC rpmb size : 16 Mb
EMMC user area size : 29820 Mb
IMEI A: ‪86xxxxxxxxxxxxx‬
IMEI B: ‪86xxxxxxxxxxxxx‬
Lectura de tabla de secciones
Lectura de sección FRP
Old 01-17-2024, 17:08   #413 (permalink)
Member: 2951556
Thanks Meter: 69
Job ID: 00000000018F238F
2024-01-17 16:00:18
Iniciando Reset FRP
Modelo de teléfono seleccionado: ‪STK-LX3‬
Found android device: WTFNW20629001562
C_Version: ‪C605‬
D_Version: ‪D1‬
Checking balance...
Resetting FRP...
Rebooting device...
Old 01-18-2024, 13:10   #414 (permalink)
Member: 746586
Thanks Meter: 202
PPA LX2 Huawei ID Remove
Job ID: 0000000001E6DB4C
2024-01-18 11:57:03
Starting Reset Huawei ID
Selected phone model: ‪PPA-LX2‬
Writing bootloader KIRIN710A_V3...
Operation in progress. Please wait for instructions...
Found android device: CNXYD21826203092
Device Model: ‪PPA-LX2‬
System: ‪PPAH-L22 10.1.1.277(C185E8R3P1)‬
Base Version: ‪PPAH-LGRP2-OVS 10.1.1.277‬
Custom Version: ‪PPAH-L22-CUST 10.1.1.8(C185)‬
Preload Version: ‪PPAH-L22-PRELOAD 10.1.1.1(C185R3)‬
C_Version: ‪C185‬
D_Version: ‪D000‬
Username: Default_user
Checking balance...
Your balance: 1 credits
MEID: ‪00000000000000‬
IMEI A: ‪865xxxxxxxxxxx
IMEI B: ‪865xxxxxxxxxxx
S/N: ‪CNXYD21826203092‬
Resetting Huawei ID...
Rebooting device...
Warning: Please perform "Clear data" manually via Recovery Mode, if your device doesn`t start properly!
Reset Huawei ID done.
The Following User Says Thank You to apacheadmiral For This Useful Post:
Old 01-22-2024, 11:14   #415 (permalink)
Member: 746586
Thanks Meter: 202
NOVA 8i Chip is damaged done
Job ID: 0000000001E8BA81
2024-01-22 10:03:25
Starting Restore "Chip is damaged"
Selected phone model: ‪NEN-LX1‬
Searching Qualcomm HS-USB QDLoader 9008 port...
Please, reconnect battery, connect USB cable with attached Test Point on your phone!
Detected ‪Qualcomm HS-USB QDLoader 9008‬ port
Connecting to device...
Hadshaking...
Reading bootloader info...
OEM PK HASH: B25DECD85D217F5D9B53DC3C42EF7846DCEF59DD3E0AF4D126 06199F5099FF23
MSM HW ID: 0014D0E1
Serial Number: 52FD41BF
Sending loader Qualcomm Snapdragon 662V.1.mbn...
Loader send successfully
Reconnecting, please wait...
Configuring device...
Reading partition table...
Creating backup...
Backup saved to NEN-LX1_BACKUP_FIRMWARE_2024-01-22_12-04-20.
Restoring "Chip is damaged"...
Performing factory reset...
Warning: 1. Plese activate Your device (finish all activating stages). 2. Thereafter, You have to put device into EDL Mode and tap "Ok" button. Note: if You don't complete steps above "Find Device" service will not be available!
Hadshaking...
MSM HW ID: 0014D0E1
Restoring "Find device"...
Restore "Chip is damaged" done.
The Following 2 Users Say Thank You to apacheadmiral For This Useful Post:
Old 01-25-2024, 17:06   #416 (permalink)
Member: 2945914
Thanks Meter: 411
P40 lite Huawei ID removed
Found COM ports:
1: COM1 Communications Port
2: COM3 USB Serial Port
3: COM51 HUAWEI USB COM 1.0
Job ID: 00000000018E34FB
2024-01-25 15:40:51
Selected phone model: ‪JNY-LX1‬
Selected method: Reset Huawei Id (EMUI 10)
Writing bootloader KIRIN810_V4...
Found android device: UT7TSX20CP012418
Device Model: ‪JNY-LX1‬
System: ‪JNY-L21 10.1.0.243(C432E1R6P1)‬
Base Version: ‪JNY-LGRP2-OVS 10.1.0.243‬
Custom Version: ‪JNY-L21-CUST 10.1.0.1(C432)‬
Preload Version: ‪JNY-L21-PRELOAD 10.1.0.1(C432R6)‬
C_Version: ‪C432‬
D_Version: ‪D000‬
Checking balance...
Rebooting device...
The Following 2 Users Say Thank You to Genci&Geri For This Useful Post:
Old 01-26-2024, 15:52   #417 (permalink)
Member: 746586
Thanks Meter: 202
NOVA 8i Huawei ID done
Job ID: 0000000001EAF99B
2024-01-26 14:49:28
Hadshaking...
MSM HW ID: 0014D0E1
Serial Number: B647EF4D
Creating backup...
Backup saved to NEN-LX1_BACKUP_FIRMWARE_2024-01-26_16-50-14.
Searching for Huawei Id protection...
Resetting Huawei Id...
Please perform the factory reset operation manually through the recovery mode if the operation was not done automatically
Old 01-26-2024, 16:06   #418 (permalink)
Member: 746586
Thanks Meter: 202
nova
Nova 8i "Chip is damaged" done.
Job ID: 00000000018E6F86
2024-01-26 14:55:41
Hadshaking...
MSM HW ID: 0014D0E1
Creating backup...
Backup saved to NEN-LX1_BACKUP_FIRMWARE_2024-01-26_16-56-26.
Hadshaking...
MSM HW ID: 0014D0E1
Old 01-28-2024, 15:31   #419 (permalink)
Member: 2951556
Thanks Meter: 69
Job ID: 00000000018E7776
2024-01-28 14:19:57
Iniciando Reset FRP
Modelo de teléfono seleccionado: ‪JKM-LX3‬
Found android device: S4V6R20622009114
Modelo de dispositivo: ‪JKM-LX3‬
Sistema: ‪JKM-LX3 9.1.0.349(C605E5R1P2)‬
Versión de Android: ‪9‬
Base Version: ‪JKM-LGRP2-OVS 9.1.0.349‬
Custom Version: ‪JKM-LX3-CUST 9.1.0.5(C605)‬
Preload Version: ‪JKM-L23X-PRELOAD 9.1.0.2(C605R1)‬
C_Version: ‪C605‬
D_Version: ‪D000‬
Checking balance...
Your balance: 200 credits
IMEI A: ‪863xxxxxxxxxxx‬
IMEI B: ‪863xxxxxxxxxxxx‬
S/N: ‪S4V6xxxxxxxxxxxx‬
Resetting FRP...
Rebooting device...
Old 02-05-2024, 16:48   #420 (permalink)
Member: 2951556
Thanks Meter: 69
1: COM5 USB Serial Port
Job ID: 0000000001EFAF96
2024-02-05 15:45:05
Iniciando Reset FRP
Modelo de teléfono seleccionado: ‪DRA-LX3‬
Found android device: QDB9K19A19904377
Modelo de dispositivo: ‪DRA-LX3‬
Sistema: ‪DRA-LX3 1.0.0.184(C469)‬
Grabando datos de remoción de FRP...
Page generated in 0.28614 seconds with 9 queries
