10-14-2020, 09:55 | #1 (permalink) |
Insane Poster Join Date: Apr 2014 Location: yem
Member: 2172436 Status: Offline Sonork: lololo Thanks Meter: 2 | reboot LYA-L29 Factory Mode failed! [Answered] Starting ON/OFF Factory Mode Selected phone model: LYA-L29 To Enable Factory mode put the phone in Upgrade mode and connect USB cable! To Disable Factory mode put the phone in Factory or Fastboot mode and connect USB cable! ON/OFF Factory Mode canceled. Performed by 1.2.2.1 Software version. 2020-10-14 08:51:42 GMT ------------------------------------------------- Starting ON/OFF Factory Mode Selected phone model: LYA-L29 To Enable Factory mode put the phone in Upgrade mode and connect USB cable! To Disable Factory mode put the phone in Factory or Fastboot mode and connect USB cable! Performing ON Factory Mode operation... Checking firmware package type Initializing remote service connection... Downloading patch files from server... Searching device in Upgrade mode... Connecting to phone.. Phone connect successfully! Writing firmware partitions... Writing SHA256RSA partition... Writing CRC partition... Writing BASE_VERLIST partition... Error: Failed write BASE_VERLIST partition Checking firmware package type Initializing remote service connection... Downloading patch files from server... Searching device in Upgrade mode... Connecting to phone.. Phone connect successfully! Writing firmware partitions... Writing SHA256RSA partition... Writing CRC partition... Writing PACKAGE_TYPE partition... Error: Failed write PACKAGE_TYPE partition Warning: Switching your device to Factory Mode is not possible! Please, connect your device via Test Point and perform the desired operation. ON/OFF Factory Mode failed. Performed by 1.2.2.1 Software version. |
10-14-2020, 10:03 | #3 (permalink) |
Member: 2172436 Status: Offline Sonork: lololo Thanks Meter: 2 | 2020-10-14 08:39:20 GMT ------------------------------------------------- Starting Read Info (Fastboot Mode) Searching Fastboot devices... Found a fastboot device: LHS7N19219001171 Product Model: LYA-L29 Build Number: LYA-L29 10.1.0.298(C185E7R2P4) Region Code: C185E7R2P4 Android Version: 10 Base Version: LYA-LGRP2-OVS 10.1.0.298 Custom Version: LYA-L29-CUST 10.0.0.7(C185) Preload Version: LYA-L29-PRELOAD 10.0.0.4(C185R2) C_Version: C185 D_Version: D000 DeviceName: LYA-L29 |
10-14-2020, 14:46 | #5 (permalink) |
Member: 2172436 Status: Offline Sonork: lololo Thanks Meter: 2 | Welcome to Octoplus Huawei Software v.1.2.2.1 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 1: COM24 USB Serial Port 2: COM1 Communications Port 3: COM101 Novatel Wireless VCOM GPS Port 4: COM143 Novatel Wireless VCOM GPS Port Found COM ports: 1: COM24 USB Serial Port 2: COM1 Communications Port 3: COM101 Novatel Wireless VCOM GPS Port 4: COM143 Novatel Wireless VCOM GPS Port 2020-10-14 13:40:49 GMT ------------------------------------------------- Starting Auto detect No devices in manufacture mode detected Auto detect failed. Performed by 1.2.2.1 Software version. 2020-10-14 13:40:51 GMT ------------------------------------------------- Starting Auto detect Error: Connect serial port. Cause: No such file or directory Auto detect failed. Performed by 1.2.2.1 Software version. Found COM ports: 1: COM24 USB Serial Port 2: COM1 Communications Port 3: COM101 Novatel Wireless VCOM GPS Port 4: COM143 Novatel Wireless VCOM GPS Port 2020-10-14 13:41:34 GMT ------------------------------------------------- Starting Connect Selected phone model: LYA-L29 Searching HUAWEI USB COM 1.0 port... Error: HUAWEI USB COM 1.0 port not found Searching Fastboot devices... Found a fastboot device: LHS7N19219001171 Connect failed. Performed by 1.2.2.1 Software version. 2020-10-14 13:42:25 GMT ------------------------------------------------- Starting ON/OFF Factory Mode Selected phone model: LYA-L29 To Enable Factory mode put the phone in Upgrade mode and connect USB cable! To Disable Factory mode put the phone in Factory or Fastboot mode and connect USB cable! Performing ON Factory Mode operation... Checking firmware package type Initializing remote service connection... Downloading patch files from server... Searching device in Upgrade mode... Connecting to phone.. Phone connect successfully! Writing firmware partitions... Writing SHA256RSA partition... Writing CRC partition... Writing BASE_VERLIST partition... Error: Failed write BASE_VERLIST partition Checking firmware package type Initializing remote service connection... Downloading patch files from server... Searching device in Upgrade mode... Error: No devices in Upgarde mode found Warning: Switching your device to Factory Mode is not possible! Please, connect your device via Test Point and perform the desired operation. ON/OFF Factory Mode failed. Performed by 1.2.2.1 Software version. 2020-10-14 13:45:07 GMT ------------------------------------------------- Starting ON/OFF Factory Mode Selected phone model: LYA-L29 To Enable Factory mode put the phone in Upgrade mode and connect USB cable! To Disable Factory mode put the phone in Factory or Fastboot mode and connect USB cable! Performing ON Factory Mode operation... Checking firmware package type Initializing remote service connection... Downloading patch files from server... Searching device in Upgrade mode... Connecting to phone.. Phone connect successfully! Writing firmware partitions... Writing SHA256RSA partition... Writing CRC partition... Writing BASE_VERLIST partition... Error: Failed write BASE_VERLIST partition Checking firmware package type Initializing remote service connection... Downloading patch files from server... Searching device in Upgrade mode... Connecting to phone.. Phone connect successfully! Writing firmware partitions... Writing SHA256RSA partition... Writing CRC partition... Writing PACKAGE_TYPE partition... Error: Failed write PACKAGE_TYPE partition Warning: Switching your device to Factory Mode is not possible! Please, connect your device via Test Point and perform the desired operation. ON/OFF Factory Mode failed. Performed by 1.2.2.1 Software version. |
10-14-2020, 14:56 | #6 (permalink) | |
Freak Poster Join Date: Mar 2016 Location: HUAWEI
Member: 2548753 Status: Offline Thanks Meter: 256 | Quote:
TESTED MANY TIME | |
