04-13-2021, 17:42 | #1 (permalink) |
No Life Poster Join Date: Jan 2012 Location: YOUR HEART
Member: 1712884 Status: Offline Thanks Meter: 857 | Request help with Huawei ID AQM-LX1 [Answered] Code: Welcome to Octoplus Huawei Software v.1.2.4.2 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 1: COM1 Communications Port Job ID: 0000000000DF31E4 2021-04-13 16:38:09 GMT ------------------------------------------------- Starting Read Info (Fastboot Mode) Selected phone model: AQM-AL00 Searching Fastboot devices... Found a fastboot device: YFF6R20714004674 Product Model: AQM-LX1 Build Number: AQM-L21A 10.1.0.157(C185E2R4P1) Region Code: C185E2R4P1 Android Version: 10 Base Version: AQM-LGRP2-OVS 10.1.0.157 Custom Version: AQM-L21A-CUST 10.1.0.2(C185) Preload Version: AQM-L21A-PRELOAD 10.1.0.1(C185R4) C_Version: C185 D_Version: D000 DeviceName: AQM-L21A Read Info (Fastboot Mode) done. Performed by 1.2.4.2 Software version. |
04-14-2021, 09:19 | #2 (permalink) |
Product Supporter Join Date: Jan 2019 Location: USA, New York
Member: 2891705 Status: Offline Thanks Meter: 2,141 | Hello. Please select in phone model list: AQM-AL00 and perform Reset Huawei ID operation, post here results. |
The Following User Says Thank You to Octopus support For This Useful Post: |
04-14-2021, 09:35 | #3 (permalink) |
Member: 1712884 Status: Offline Thanks Meter: 857 | Code: Welcome to Octoplus Huawei Software v.1.2.4.2 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 1: COM1 Communications Port Job ID: 0000000000DFC417 2021-04-14 08:21:43 GMT ------------------------------------------------- Starting Connect Selected phone model: AQM-AL00 Searching HUAWEI USB COM 1.0 port... Error: HUAWEI USB COM 1.0 port not found Searching Fastboot devices... Canceling... Please be patient! Connect canceled. Performed by 1.2.4.2 Software version. Job ID: 0000000000DFC43D 2021-04-14 08:22:17 GMT ------------------------------------------------- Starting Connect Selected phone model: AQM-AL00 Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Writing bootloader KIRIN810_V1... Initializing remote service connection... Writing XLOADER partition... Connect failed. Performed by 1.2.4.2 Software version. Job ID: 0000000000DFC4F1 2021-04-14 08:24:59 GMT ------------------------------------------------- Starting Connect Selected phone model: AQM-AL00 Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Writing bootloader KIRIN810_V1... Initializing remote service connection... Writing XLOADER partition... Connect failed. Performed by 1.2.4.2 Software version. Job ID: 0000000000DFC53C 2021-04-14 08:26:06 GMT ------------------------------------------------- Starting Connect Selected phone model: AQM-AL00 Searching HUAWEI USB COM 1.0 port... Error: HUAWEI USB COM 1.0 port not found Searching Fastboot devices... Canceling... Please be patient! Connect canceled. Performed by 1.2.4.2 Software version. Job ID: 0000000000DFC567 2021-04-14 08:26:39 GMT ------------------------------------------------- Starting Connect Selected phone model: AQM-AL00 Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Writing bootloader KIRIN810_V1... Initializing remote service connection... Writing XLOADER partition... Connect failed. Performed by 1.2.4.2 Software version. Job ID: 0000000000DFC743 2021-04-14 08:33:11 GMT ------------------------------------------------- Starting Connect Selected phone model: AQM-AL00 Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Writing bootloader KIRIN810_V1... Initializing remote service connection... Writing XLOADER partition... Connect failed. Performed by 1.2.4.2 Software version. |
04-14-2021, 15:20 | #4 (permalink) |
Member: 1712884 Status: Offline Thanks Meter: 857 | by new version and connect failed Code: Welcome to Octoplus Huawei Software v.1.2.5 To enable 'Manufacture' mode dial - for Qualcomm and Hisilicon based models: *#*#2846579#*#* ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode - for MTK based models: *#*#14789632#*#* ProjectMenu > Background Settings > USB Port Settings > Debug Mode To enable 'Fastboot' mode 1. Power off the phone. Remove SD and SIM cards 2. Press 'Vol-' and insert USB cable 3. Wait until phone enters 'Fastboot' mode To enable 'Upgrade' mode 1. Power off the phone. Remove SD and SIM cards 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 3. Wait until phone enters 'Upgrade mode' Found COM ports: 1: COM1 Communications Port 2021-04-14 14:18:14 GMT ------------------------------------------------- Starting Connect Selected phone model: AQM-AL00 Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Writing bootloader KIRIN810_V1... Initializing remote service connection... Writing XLOADER partition... Connect failed. Performed by 1.2.5 Software version. 2021-04-14 14:18:50 GMT ------------------------------------------------- Starting Connect Selected phone model: AQM-AL00 Searching HUAWEI USB COM 1.0 port... Detected HUAWEI USB COM 1.0 port Writing bootloader KIRIN810_V1... Initializing remote service connection... Writing XLOADER partition... Connect failed. Performed by 1.2.5 Software version. |
04-19-2021, 07:59 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. We will check where can be the problem and inform you. |
04-19-2021, 09:02 | #7 (permalink) |
Member: 2891705 Status: Offline Thanks Meter: 2,141 | Hello. Please select in phone model list: STK-AL00 and repeat the operation once again. Post here results. |
The Following 2 Users Say Thank You to Octopus support For This Useful Post: |
