Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octoplus Huawei Tool
Old 04-07-2021, 14:36   #1 (permalink)
Member: 2531008
Thanks Meter: 15
stk l21 write cert fail [Answered]
2021-04-07 11:11:53.917 Loading application settings
2021-04-07 11:11:53.952 Refreshing serial ports list
2021-04-07 11:11:54.012 Found COM ports:
2021-04-07 11:11:54.492 Welcome to Octoplus Huawei Software v.1.2.4
2021-04-07 11:11:54.492 To enable 'Manufacture' mode dial
2021-04-07 11:11:54.497 - for Qualcomm and Hisilicon based models: *#*#2846579#*#*
2021-04-07 11:11:54.497 ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode
2021-04-07 11:11:54.502 - for MTK based models: *#*#14789632#*#*
2021-04-07 11:11:54.502 ProjectMenu > Background Settings > USB Port Settings > Debug Mode
2021-04-07 11:11:54.507
2021-04-07 11:11:54.507 To enable 'Fastboot' mode
2021-04-07 11:11:54.507 1. Power off the phone. Remove SD and SIM cards
2021-04-07 11:11:54.512 2. Press 'Vol-' and insert USB cable
2021-04-07 11:11:54.512 3. Wait until phone enters 'Fastboot' mode
2021-04-07 11:11:54.517
2021-04-07 11:11:54.517 To enable 'Upgrade' mode
2021-04-07 11:11:54.522 1. Power off the phone. Remove SD and SIM cards
2021-04-07 11:11:54.522 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable
2021-04-07 11:11:54.527 3. Wait until phone enters 'Upgrade mode'
2021-04-07 11:11:54.960 Refreshing serial ports list
2021-04-07 11:11:55.005 Found COM ports:
2021-04-07 11:11:55.260 Init finished
2021-04-07 11:13:44.782 Connected to log server.
2021-04-07 11:13:47.354 Job ID: 0000000000D8238E
2021-04-07 11:13:47.894 2021-04-07 11:13:47 GMT -------------------------------------------------
2021-04-07 11:13:48.154 Starting Read Cert
2021-04-07 11:13:48.449 Selected phone model: STK-L21
2021-04-07 11:13:51.670 Searching HUAWEI USB COM 1.0 port...
2021-04-07 11:13:51.914 Refreshing serial ports list
2021-04-07 11:13:52.247 Found COM ports:
2021-04-07 11:13:52.522 1: COM112 HUAWEI USB COM 1.0
2021-04-07 11:13:52.758 Detected HUAWEI USB COM 1.0 port
2021-04-07 11:13:53.034 Writing bootloader KIRIN710_V1...
2021-04-07 11:13:53.278 Initializing remote service connection...
2021-04-07 11:14:04.296 Writing XLOADER partition...
2021-04-07 11:14:04.896 Writing UCE partition...
2021-04-07 11:14:35.512 Writing FASTBOOT partition...
2021-04-07 11:14:51.181 Bootloader Update successfully
2021-04-07 11:14:51.436 Rebooting to fastboot mode...
2021-04-07 11:14:51.711 Searching Fastboot devices...
2021-04-07 11:14:56.419 Total interfaces: 1
2021-04-07 11:14:56.711 Interface 0 : flags: 1, name(81): \\?\usb#vid_18d1&pid_d00d#xmjnw19b28000496#{f72fe0 d4-cbcb-407d-8814-9ed673d0dd6b}
2021-04-07 11:14:56.941 Found a fastboot device: XMJNW19B28000496
2021-04-07 11:14:57.191 Refreshing serial ports list
2021-04-07 11:14:57.511 Found COM ports:
2021-04-07 11:14:57.801 Detected Android Sooner Single ADB Interface port
2021-04-07 11:14:59.021 Response contains FAIL!
2021-04-07 11:14:59.291 Reading serial number failed
2021-04-07 11:15:08.427 Removing firmware protection...
2021-04-07 11:15:09.297 Connecting to server...
2021-04-07 11:15:10.677 Private enc 0
2021-04-07 11:15:10.952 Waiting for a response from the server...
2021-04-07 11:15:35.953 Writing sign buf data
2021-04-07 11:15:37.959 FB Lock State: UNLOCKED
2021-04-07 11:15:38.239 User Lock State: LOCKED
2021-04-07 11:15:40.760 Response contains FAIL!
2021-04-07 11:15:41.019 Reading serial number failed
2021-04-07 11:15:45.161 Device Model: STK-L21
2021-04-07 11:15:45.434 System: STK-L21M 10.0.0.366(C185E6R5P1)
2021-04-07 11:15:46.393 Reading certificate files...
2021-04-07 11:15:50.838 Rebooting device...
2021-04-07 11:15:51.134
2021-04-07 11:15:51.413 Read Cert done.
2021-04-07 11:15:51.676 Performed by 1.2.4 Software version.
2021-04-07 11:18:56.738 Selected IMEI_A file: C:/LOCAL DISK/ADROID HACKS/art-l29 clean/art-l29/ART-L29_IMEI_SLOT_1_864754046433352.obf
2021-04-07 11:19:04.325 Selected IMEI_B file: C:/LOCAL DISK/ADROID HACKS/art-l29 clean/art-l29/ART-L29_IMEI_SLOT_2_864754046487101.obf
2021-04-07 11:19:53.401 Connected to log server.
2021-04-07 11:19:56.431 Job ID: 0000000000D825A8
2021-04-07 11:19:57.481 2021-04-07 11:19:57 GMT -------------------------------------------------
2021-04-07 11:19:57.761 Starting Write Cert
2021-04-07 11:19:58.086 Selected phone model: STK-L21
2021-04-07 11:20:01.582 Connecting to the credit server...
2021-04-07 11:20:11.242 Searching HUAWEI USB COM 1.0 port...
2021-04-07 11:20:11.568 Refreshing serial ports list
2021-04-07 11:20:11.894 Found COM ports:
2021-04-07 11:20:12.163 1: COM112 HUAWEI USB COM 1.0
2021-04-07 11:20:12.407 Detected HUAWEI USB COM 1.0 port
2021-04-07 11:20:12.690 Writing bootloader KIRIN710_V1...
2021-04-07 11:20:12.993 Initializing remote service connection...
2021-04-07 11:20:29.978 Writing XLOADER partition...
2021-04-07 11:20:30.623 Writing UCE partition...
2021-04-07 11:21:01.058 Writing FASTBOOT partition...
2021-04-07 11:21:16.096
2021-04-07 11:21:16.541 Write Cert failed.
2021-04-07 11:21:16.861 Performed by 1.2.4 Software version.
2021-04-07 11:21:48.549 Connected to log server.
2021-04-07 11:21:50.689 Job ID: 0000000000D82677
2021-04-07 11:21:51.244 2021-04-07 11:21:51 GMT -------------------------------------------------
2021-04-07 11:21:51.549 Starting Write Cert
2021-04-07 11:21:51.854 Selected phone model: STK-L21
2021-04-07 11:21:56.420 Connecting to the credit server...
2021-04-07 11:22:07.080 Searching HUAWEI USB COM 1.0 port...
2021-04-07 11:22:32.000 Refreshing serial ports list
2021-04-07 11:22:32.341 Found COM ports:
2021-04-07 11:22:32.626 1: COM112 HUAWEI USB COM 1.0
2021-04-07 11:22:32.896 Detected HUAWEI USB COM 1.0 port
2021-04-07 11:22:35.047 Writing bootloader KIRIN710_V1...
2021-04-07 11:22:35.327 Initializing remote service connection...
2021-04-07 11:22:46.059 Writing XLOADER partition...
2021-04-07 11:25:17.187
2021-04-07 11:25:17.522 Write Cert failed.
2021-04-07 11:25:17.852 Performed by 1.2.4 Software version.
Old 04-07-2021, 16:10   #2 (permalink)
Octopus support's Avatar
Member: 2891705
Thanks Meter: 2,136
Hello.
Thanks for report, we will check where can be the problem and inform you result here, stay tuned.
Old 04-08-2021, 21:27   #3 (permalink)
Member: 2531008
Thanks Meter: 15
Still waiting for your feedback tried art l29 same issue is kirin 710f really supported?
Page generated in 0.12898 seconds with 9 queries
