10-21-2021, 12:31 | #1 (permalink) |
Junior Member Join Date: Jan 2008
Member: 679555 Status: Offline Thanks Meter: 8 | WLZ-AN00 Reset Huawei ID question [Answered] 2021-10-21 10:45:43.873 Refreshing serial ports list 2021-10-21 10:45:43.881 Found COM ports: 2021-10-21 10:45:43.881 1: COM1 ???? 2021-10-21 10:45:43.881 2: COM48 USB Serial Port 2021-10-21 10:45:44.418 Welcome to Octoplus Huawei Software v.1.2.6.1 2021-10-21 10:45:44.418 2021-10-21 10:45:44.418 To enable 'Manufacture' mode dial 2021-10-21 10:45:44.418 - for Qualcomm and Hisilicon based models: *#*#2846579#*#* 2021-10-21 10:45:44.419 ProjectMenu > Background Settings > USB Port Settings > Manufacture Mode 2021-10-21 10:45:44.419 - for MTK based models: *#*#14789632#*#* 2021-10-21 10:45:44.419 ProjectMenu > Background Settings > USB Port Settings > Debug Mode 2021-10-21 10:45:44.421 2021-10-21 10:45:44.421 To enable 'Fastboot' mode 2021-10-21 10:45:44.421 1. Power off the phone. Remove SD and SIM cards 2021-10-21 10:45:44.421 2. Press 'Vol-' and insert USB cable 2021-10-21 10:45:44.422 3. Wait until phone enters 'Fastboot' mode 2021-10-21 10:45:44.422 2021-10-21 10:45:44.422 To enable 'Upgrade' mode 2021-10-21 10:45:44.423 1. Power off the phone. Remove SD and SIM cards 2021-10-21 10:45:44.423 2. Press and hold 'Vol-' and 'Vol+' keys and insert USB cable 2021-10-21 10:45:44.423 3. Wait until phone enters 'Upgrade mode' 2021-10-21 10:45:45.426 Refreshing serial ports list 2021-10-21 10:45:45.432 Found COM ports: 2021-10-21 10:45:45.433 1: COM1 ???? 2021-10-21 10:45:45.433 2: COM48 USB Serial Port 2021-10-21 10:45:45.505 64-bit executable. 2021-10-21 10:45:45.715 Filter started successfully! 2021-10-21 10:45:45.715 Init finished 2021-10-21 10:46:25.476 Job ID: 0000000001B3325A 2021-10-21 10:46:26.183 2021-10-21 10:46:26 GMT ------------------------------------------------- 2021-10-21 10:46:26.536 Starting Reset Huawei ID 2021-10-21 10:46:26.888 Selected phone model: WLZ-AN00 2021-10-21 10:46:30.834 Searching HUAWEI USB COM 1.0 port... 2021-10-21 10:46:31.180 Refreshing serial ports list 2021-10-21 10:46:31.558 Found COM ports: 2021-10-21 10:46:31.901 1: COM120 HUAWEI USB COM 1.0 2021-10-21 10:46:32.241 2: COM1 ???? 2021-10-21 10:46:32.582 3: COM48 USB Serial Port 2021-10-21 10:46:32.923 Detected HUAWEI USB COM 1.0 port 2021-10-21 10:46:33.285 Writing bootloader KIRIN990_V1... 2021-10-21 10:46:33.963 Initializing remote service connection... 2021-10-21 10:46:34.319 Writing XLOADER partition... 2021-10-21 10:46:38.003 Failed to write secure header data 2021-10-21 10:46:38.361 2021-10-21 10:46:38.715 Reset Huawei ID failed. 2021-10-21 10:46:39.071 Performed by 1.2.6.1 Software version. |
