10-30-2018, 18:00 | #2 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 45
Member: 9519 Status: Offline Thanks Meter: 2,152 | use ND1_BootFix.zip files from NTool support area ( Nokia 5.ND1 folder ) search here how to use bootfix package, i'm posted instructions few times, in short : - unpack package to some folder - connect phone - run load_firehose.cmd - after successfull execution run load_boot.cmd - finally reflash phone |
The Following 3 Users Say Thank You to the_laser For This Useful Post: |
11-05-2018, 03:46 | #3 (permalink) | |
Freak Poster Join Date: Apr 2006
Member: 261334 Status: Offline Thanks Meter: 13 | Quote:
11-08-2018, 00:11 | #5 (permalink) |
Member: 261334 Status: Offline Thanks Meter: 13 | Code: 20:10:56: INFO: FH_LOADER WAS CALLED EXACTLY LIKE THIS ************************************************ fh_loader.exe --port=\\.\COM698 --reset ************************************************ 20:10:56: DEBUG: Binary build date: May 4 2016 @ 10:02:58 20:10:56: DEBUG: Build Version: 16.05. 4.10.02.58 20:10:56: INFO: Current working dir (cwd): C:\Users\Admin\Desktop\Nokia 6\ND1_BootFix - copia\ 20:10:56: INFO: Showing network mappings to allow debugging 20:10:56: DEBUG: Se registrar*n las nuevas conexiones. 20:10:56: DEBUG: 20:10:56: DEBUG: No hay entradas en la lista. 20:10:56: DEBUG: 20:10:56: INFO: User wants to talk to port '\\.\COM698' 20:10:56: DEBUG: port_fd=0x50 20:10:57: INFO: Took 0.03100000 seconds to open port 20:10:57: INFO: Sorting TAGS to ensure order is <configure>,<erase>, others, <patch>,<power> 20:10:57: INFO: If you don't want this, use --dontsorttags 20:10:57: INFO: Sending <configure> 20:10:57: DEBUG: CHANNEL DATA (P0000) (H00202) ( 246 bytes) - HOST TO TARGET --> =========================================================================================================== <?xml version="1.0" encoding="UTF-8" ?> <data> <configure MemoryName="eMMC" Verbose="0" AlwaysValidate="0" MaxDigestTableSizeInBytes="8192" MaxPayloadSizeToTargetInBytes="1048576" ZlpAwareHost="1" SkipStorageInit="0" TargetName="8960" /> </data> ============================================================================================================ 20:10:57: DEBUG: CharsInBuffer=0 Trying to read from USB 8192 bytes 20:10:57: DEBUG: CHANNEL DATA (16 bytes) <-- TARGET to HOST 20:10:57: DEBUG: CharsInBuffer = 16 20:10:57: DEBUG: printBuffer:4247 PRETTYPRINT Buffer is 16 bytes 20:10:57: DEBUG: printBuffer:4324 04 00 00 00 10 00 00 00 0D 00 00 00 08 00 00 00 ................ 20:10:57: DEBUG: printBuffer:4337 _____ | ___| | |__ _ __ _ __ ___ _ __ | __| '__| '__/ _ \| '__| | |__| | | | | (_) | | \____/_| |_| \___/|_| 20:10:57: {ERROR: DetermineTag:4982 XML not formed correctly. Expected a < character at loc 0 _____ | ___| | |__ _ __ _ __ ___ _ __ | __| '__| '__/ _ \| '__| | |__| | | | | (_) | | \____/_| |_| \___/|_| 20:10:57: {ERROR: GetNextPacket:6095 3. TAG not found or recognized _____ | ___| | |__ _ __ _ __ ___ _ __ | __| '__| '__/ _ \| '__| | |__| | | | | (_) | | \____/_| |_| \___/|_| 20:10:57: {ERROR: GetNextPacket:6105 There is a chance your target is in SAHARA mode!! There is a chance your target is in SAHARA mode!! There is a chance your target is in SAHARA mode!! This can mean 1. You forgot to send DeviceProgrammer first (i.e. QSaharaServer.exe -s 13:prog_emmc_firehose_8994_lite.mbn) 2. OR, you did send DeviceProgrammer, but it has crashed and/or is not correct for this target Regardless this program speaks FIREHOSE protocol and your target is speaking SAHARA protcol, so this will not work Last edited by the_laser; 11-08-2018 at 05:58. |
11-08-2018, 05:57 | #6 (permalink) |
Member: 9519 Status: Offline Thanks Meter: 2,152 | probably your device totally discharged. put phone on charger for at least 40 minutes. connect phone and perform hardware reset ( hold volume up + power until device reconnect ) you need to run load_firehose.cmd immediately after port appears in system. sorry, i can not help you more at all. |
The Following User Says Thank You to the_laser For This Useful Post: |
