02-01-2019, 19:35 | #5 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 45
Member: 9519 Status: Offline Thanks Meter: 2,152 | 1. make sure you installed all drivers from NTool drivers folder 2. unpack P2C_BootFix.zip into some folder, like c:\bootfix, open command prompt and go to this folder 3. disassemble phone ( preheat display or you will surely damage it ) 4. connect marked testpoint to +3.3v source, battery "+" connector will do job just fine 5. connect phone to PC, if you do job well, then you will see "Qualcomm HS-USB QDLoader 9008" port, not ADB Fastboot port 6. immediately run load_fh.cmd and check if loader uploaded okay, if not - disconnect cable, reconnect battery and proceed from p.4 7. run load_boot.cmd 8. your phone is ready to be flashed with whatever firmware you want |
