Aamir_Zia | 07-22-2020 15:27 | Nokia 3.2 TA1156 Fastboot STUCK Bootloader unlocked and stucked in Fastboot
customer did it . ( ROOT ) PHP Code: C:\Program Files (x86)\Minimal ADB and Fastboot>fastboot getvar all
(bootloader) version:0.5
(bootloader) battery-soc-ok:yes
(bootloader) battery-voltage:3794253
(bootloader) variant:QRD eMMC
(bootloader) unlocked:yes
(bootloader) secure:yes
(bootloader) version-baseband:
(bootloader) version-bootloader:
(bootloader) logical-block-size:0x200
(bootloader) erase-block-size:0x200
(bootloader) display-panel:
(bootloader) off-mode-charge:0
(bootloader) charger-screen-enabled:0
(bootloader) max-download-size: 0x1feffc00
(bootloader) slot-count:2
(bootloader) current-slot:INVALID
(bootloader) slot-retry-count:b:0
(bootloader) slot-success:b:No
(bootloader) slot-active:b:No
(bootloader) slot-unbootable:b:Yes
(bootloader) slot-retry-count:a:0
(bootloader) slot-success:a:No
(bootloader) slot-active:a:No
(bootloader) slot-unbootable:a:Yes
(bootloader) has-slot:userdata: No
(bootloader) has-slot:demoapp: No
(bootloader) has-slot:elabel: No
(bootloader) has-slot:wt_log: No
(bootloader) has-slot:logdump: No
(bootloader) has-slot:dpo: No
(bootloader) has-slot:msadp: No
(bootloader) has-slot:apdp: No
(bootloader) has-slot:custom: Yes
(bootloader) has-slot:keymaster: Yes
(bootloader) has-slot:cmnlib64: Yes
(bootloader) has-slot:cmnlib: Yes
(bootloader) has-slot:mcfg: No
(bootloader) has-slot:syscfg: No
(bootloader) has-slot:mdtp: Yes
(bootloader) has-slot:dip: No
(bootloader) has-slot:mota: No
(bootloader) has-slot:limits: No
(bootloader) has-slot:oem: No
(bootloader) has-slot:config: No
(bootloader) has-slot:keystore: No
(bootloader) has-slot:misc: No
(bootloader) has-slot:persist: No
(bootloader) has-slot:vendor: Yes
(bootloader) has-slot:system: Yes
(bootloader) has-slot:devinfo: No
(bootloader) has-slot:boot: Yes
(bootloader) has-slot:vbmeta: Yes
(bootloader) has-slot:dtbo: Yes
(bootloader) has-slot:aboot: Yes
(bootloader) has-slot:picture: Yes
(bootloader) has-slot:splash: Yes
(bootloader) has-slot:sec: No
(bootloader) has-slot:fsg: No
(bootloader) has-slot:DDR: No
(bootloader) has-slot:modemst2: No
(bootloader) has-slot:modemst1: No
(bootloader) has-slot:dsp: Yes
(bootloader) has-slot:devcfg: Yes
(bootloader) has-slot:tz: Yes
(bootloader) has-slot:rpm: Yes
(bootloader) has-slot:sbl1: Yes
(bootloader) has-slot:ssd: No
(bootloader) has-slot:fsc: No
(bootloader) has-slot:modem: Yes
(bootloader) partition-type:userdata:ext4
(bootloader) partition-size:userdata: 0x183879e00
(bootloader) partition-type:demoapp:raw
(bootloader) partition-size:demoapp: 0x4000000
(bootloader) partition-type:elabel:raw
(bootloader) partition-size:elabel: 0x500000
(bootloader) partition-type:wt_log:raw
(bootloader) partition-size:wt_log: 0x4000000
(bootloader) partition-type:logdump:raw
(bootloader) partition-size:logdump: 0x4000000
(bootloader) partition-type:dpo:raw
(bootloader) partition-size:dpo: 0x2000
(bootloader) partition-type:msadp:raw
(bootloader) partition-size:msadp: 0x40000
(bootloader) partition-type:apdp:raw
(bootloader) partition-size:apdp: 0x40000
(bootloader) partition-type:custom_b:raw
(bootloader) partition-size:custom_b: 0x3200000
(bootloader) partition-type:custom_a:raw
(bootloader) partition-size:custom_a: 0x3200000
(bootloader) partition-type:keymaster_b:raw
(bootloader) partition-size:keymaster_b: 0x100000
(bootloader) partition-type:keymaster_a:raw
(bootloader) partition-size:keymaster_a: 0x100000
(bootloader) partition-type:cmnlib64_b:raw
(bootloader) partition-size:cmnlib64_b: 0x100000
(bootloader) partition-type:cmnlib64_a:raw
(bootloader) partition-size:cmnlib64_a: 0x100000
(bootloader) partition-type:cmnlib_b:raw
(bootloader) partition-size:cmnlib_b: 0x100000
(bootloader) partition-type:cmnlib_a:raw
(bootloader) partition-size:cmnlib_a: 0x100000
(bootloader) partition-type:mcfg:raw
(bootloader) partition-size:mcfg: 0x400000
(bootloader) partition-type:syscfg:raw
(bootloader) partition-size:syscfg: 0x80000
(bootloader) partition-type:mdtp_b:raw
(bootloader) partition-size:mdtp_b: 0x2000000
(bootloader) partition-type:mdtp_a:raw
(bootloader) partition-size:mdtp_a: 0x2000000
(bootloader) partition-type:dip:raw
(bootloader) partition-size:dip: 0x100000
(bootloader) partition-type:mota:raw
(bootloader) partition-size:mota: 0x80000
(bootloader) partition-type:limits:raw
(bootloader) partition-size:limits: 0x8000
(bootloader) partition-type:oem:raw
(bootloader) partition-size:oem: 0x4000000
(bootloader) partition-type:config:raw
(bootloader) partition-size:config: 0x8000
(bootloader) partition-type:keystore:raw
(bootloader) partition-size:keystore: 0x80000
(bootloader) partition-type:misc:raw
(bootloader) partition-size:misc: 0x100000
(bootloader) partition-type:persist:raw
(bootloader) partition-size:persist: 0x2000000
(bootloader) partition-type:vendor_b:raw
(bootloader) partition-size:vendor_b: 0x28000000
(bootloader) partition-type:vendor_a:raw
(bootloader) partition-size:vendor_a: 0x28000000
(bootloader) partition-type:system_b:raw
(bootloader) partition-size:system_b: 0xc0000000
(bootloader) partition-type:system_a:raw
(bootloader) partition-size:system_a: 0xc0000000
(bootloader) partition-type:devinfo:raw
(bootloader) partition-size:devinfo: 0x100000
(bootloader) partition-type:boot_b:raw
(bootloader) partition-size:boot_b: 0x4000000
(bootloader) partition-type:boot_a:raw
(bootloader) partition-size:boot_a: 0x4000000
(bootloader) partition-type:vbmeta_b:raw
(bootloader) partition-size:vbmeta_b: 0x10000
(bootloader) partition-type:vbmeta_a:raw
(bootloader) partition-size:vbmeta_a: 0x10000
(bootloader) partition-type:dtbo_b:raw
(bootloader) partition-size:dtbo_b: 0x800000
(bootloader) partition-type:dtbo_a:raw
(bootloader) partition-size:dtbo_a: 0x800000
(bootloader) partition-type:aboot_b:raw
(bootloader) partition-size:aboot_b: 0x400000
(bootloader) partition-type:aboot_a:raw
(bootloader) partition-size:aboot_a: 0x400000
(bootloader) partition-type:picture_b:raw
(bootloader) partition-size:picture_b: 0x600000
(bootloader) partition-type:picture_a:raw
(bootloader) partition-size:picture_a: 0x600000
(bootloader) partition-type:splash_b:raw
(bootloader) partition-size:splash_b: 0x600000
(bootloader) partition-type:splash_a:raw
(bootloader) partition-size:splash_a: 0x600000
(bootloader) partition-type:sec:raw
(bootloader) partition-size:sec: 0x4000
(bootloader) partition-type:fsg:raw
(bootloader) partition-size:fsg: 0xa00000
(bootloader) partition-type:DDR:raw
(bootloader) partition-size:DDR: 0x8000
(bootloader) partition-type:modemst2:raw
(bootloader) partition-size:modemst2: 0x400000
(bootloader) partition-type:modemst1:raw
(bootloader) partition-size:modemst1: 0x400000
(bootloader) partition-type:dsp_b:raw
(bootloader) partition-size:dsp_b: 0x1000000
(bootloader) partition-type:dsp_a:raw
(bootloader) partition-size:dsp_a: 0x1000000
(bootloader) partition-type:devcfg_b:raw
(bootloader) partition-size:devcfg_b: 0x40000
(bootloader) partition-type:devcfg_a:raw
(bootloader) partition-size:devcfg_a: 0x40000
(bootloader) partition-type:tz_b:raw
(bootloader) partition-size:tz_b: 0x200000
(bootloader) partition-type:tz_a:raw
(bootloader) partition-size:tz_a: 0x200000
(bootloader) partition-type:rpm_b:raw
(bootloader) partition-size:rpm_b: 0x80000
(bootloader) partition-type:rpm_a:raw
(bootloader) partition-size:rpm_a: 0x80000
(bootloader) partition-type:sbl1_b:raw
(bootloader) partition-size:sbl1_b: 0x80000
(bootloader) partition-type:sbl1_a:raw
(bootloader) partition-size:sbl1_a: 0x80000
(bootloader) partition-type:ssd:raw
(bootloader) partition-size:ssd: 0x2000
(bootloader) partition-type:fsc:raw
(bootloader) partition-size:fsc: 0x400
(bootloader) partition-type:modem_b:raw
(bootloader) partition-size:modem_b: 0x5400000
(bootloader) partition-type:modem_a:raw
(bootloader) partition-size:modem_a: 0x5400000
(bootloader) hw-revision:10000
(bootloader) pcb_sn:4960307491002243
(bootloader) serialno:4T89626AA1961003398
(bootloader) kernel:lk
(bootloader) productid:4T89626AA1961003398
(bootloader) product:Deadpool
(bootloader) block_factory_reset:
(bootloader) block_fastboot_mode:
(bootloader) MEID:00000000000000
(bootloader) IMEI1:352907
(bootloader) IMEI0:352907
(bootloader) proof:1
Not connecting with Easybox |
