Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NTool by Setool Team
Old 07-02-2018, 07:59   #1 (permalink)
Member: 2095587
Thanks Meter: 36
Nokia 6(2018) FATAL ERRO
plz help me
error
RUNNING NTool 0.032
SERVER CREDITS LEFT/USED: 10/10
Elapsed: 1 secs.
SELECT FIRMWARE PACKAGE
Will flash : PL2-2230-0-00CNWW-B01.NBx
PLEASE CONNECT POWERED OFF PHONE
PHONE "PL2GAM17C1303676" CONNECTED
model : P2C
sub_model : none
software version : PL2-064D-0-00CN-B05
SW model : 00CN
build number : B05
hardware version : 5.0
RF band id : G_850_900_1800_1900^W_1_2_5_8^C_0^T_34_39^L_1_3_
secure : yes
Bootloader type : commercial
Download size : 00000512 mB
BOOTLOADER AUTH PASSED
Flash "B2N-0-2230-xbl_service.zip" to "xbl_a"
Flash "B2N-0-2230-xbl_service.zip" to "xbl_b"
Flash "B2N-0-2230-abl_service.zip" to "abl_a"
Flash "B2N-0-2230-abl_service.zip" to "abl_b"
FATAL ERROR: oem set_active : Slot Change is not allowed in Lock State
Elapsed: 2 secs.
Old 07-02-2018, 08:48   #2 (permalink)
Member: 9519
Thanks Meter: 2,152
just repeat flashing
The Following User Says Thank You to the_laser For This Useful Post:
Old 07-03-2018, 06:48   #3 (permalink)
Member: 2095587
Thanks Meter: 36
now successfully done..
RUNNING NTool 0.032
Elapsed: 1 secs.
ProjectCode : PL2
model : P2C
sub_model : none
SW model : 00CN
build number : B05
secure : yes
Bootloader type : service
Security version : 0004
ProjectCode : PL2
UID : D4E3D9758E0061137DEA598977A428F005C4AF63
Waiting for calculation process ...
RESPONSE: "SUCCESS" [256]
SERVICE AUTH PASSED
Set active partition to slot A
Perform auth routine
Flash "B2N-0-2230-gpt_both0.bin" to "partition"
Skip flashing "B2N-0-2230-xbl_service.elf"
Skip flashing "B2N-0-2230-abl_service.elf"
Flash "B2N-0-2230-tz.mbn" to "tz_a"
Flash "B2N-0-2230-rpm.mbn" to "rpm_a"
Flash "B2N-0-2230-hwcfg.img" to "hwcfg"
Flash "B2N-0-2230-hyp.mbn" to "hyp_a"
Flash "B2N-0-2230-pmic.elf" to "pmic_a"
Flash "B2N-0-2230-keymaster.mbn" to "keymaster_a"
Flash "B2N-0-2230-cmnlib.mbn" to "cmnlib_a"
Flash "B2N-0-2230-cmnlib64.mbn" to "cmnlib64_a"
Flash "B2N-0-2230-dspso.bin" to "dsp_a"
Flash "B2N-0-2230-devcfg.mbn" to "devcfg_a"
Flash "B2N-0-2230-sec.dat" to "sec"
Flash "B2N-0-2230-mdtpsecapp.mbn" to "mdtpsecapp_a"
Flash "B2N-0-2230-storsec.mbn" to "storsec"
Flash "systeminfo.img" to "systeminfo_a"
Perform fastboot command "reboot-bootloader"
PHONE "PL2GAM17C1303676" REMOVED
ProjectCode : PL2
SERVICE AUTH PASSED
Flash "B2N-3-2230-NON-HLOS.bin" to "modem_a"
Flash "B2N-0-2230-00CN-mdtp.img" to "mdtp_a"
Flash "PL2-0-2230-00WW-boot.img" to "boot_a"
Erase "boot_b"
Flash "PL2-0-2230-00WW-system.img" to "system_a"
Flash "PL2-0-2230-00WW-system_other.img" to "system_b"
Flash "B2N-0-2230-BTFM.bin" to "bluetooth_a"
Flash "B2N-0-2230-00CN-persist.img" to "persist"
Erase "userdata"
Flash "PL2-00CN-001-sutinfo.img" to "sutinfo"
Flash "B2N-1-2230-NV-default.mbn" to "nvdef_a"
Flash "C1N-0-0020-0001-hidden.img.ext4" to "hidden_a"
Flash "PL2-00WW-018-cda.img" to "cda_a"
Erase "ssd"
Erase "misc"
Erase "sti"
Flash "PL2-00CN-010-splash.img" to "splash_a"
Erase "ddr"
Flash "PL2-0-2230-00WW-vendor.img" to "vendor_a"
Flash "B2N-0-2230-xbl.elf" to "xbl_a"
Flash "B2N-0-2230-xbl.elf" to "xbl_b"
Flash "B2N-0-2230-abl.elf" to "abl_a"
Flash "B2N-0-2230-abl.elf" to "abl_b"
Perform fastboot command "oem set_active _a"
Perform fastboot command "oem enable-charger-screen"
Flash "md4.dat" to "md4"
FINISHED
Elapsed: 459 secs.
The Following User Says Thank You to hamim ctg For This Useful Post:
Page generated in 0.12877 seconds with 8 queries
