07-14-2018, 11:58 | #17 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | unpack attached file into NTool directory, run flash.cmd and connect powered off phone most probably you will get error like "can't flash aboot" copy entire command output and paste it here |
07-20-2018, 02:13 | #18 (permalink) | |
No Life Poster Join Date: Jun 2010 Location: Home Sweet Home
Member: 1322701 Status: Offline Thanks Meter: 127 | Quote:
... OKAY [ 0.180s] finished. total time: 0.190s productid: D1CGAPE742605328 finished. total time: 0.110s target reported max download size of 535822336 bytes sending 'aboot' (904 KB)... OKAY [ 1.551s] writing 'aboot'... FAILED (remote: Critical partition flashing is not allowed) finished. total time: 1.671s C:\ntool>pause Press any key to continue . . . | |
07-21-2018, 14:33 | #21 (permalink) |
Member: 9519 Status: Offline Thanks Meter: 2,150 | in case if anyone encounter same problem : boot file is valid for any Nokia 5 2017, Nokia 6 2017 to calculate "authorization" you need to do md5 from phone serial number, then replace code for your phone in next line of flash.cmd Code: @.\tools\fastboot oem dm-verity 7799b45982be8c6d5934c1a554a12ba4 |
01-06-2020, 05:56 | #22 (permalink) | |
No Life Poster Join Date: Mar 2009 Location: ua
Member: 1001119 Status: Offline Sonork: 100.1601226 Thanks Meter: 129 | Quote:
how to do md5 from phone serial? its my sn D1CGAPE722104411 PHONE "D1CGAPE722104411" CONNECTED FATAL ERROR: oem getversions: unknown command | |
01-06-2020, 06:14 | #23 (permalink) |
Member: 1001119 Status: Offline Sonork: 100.1601226 Thanks Meter: 129 | solved thanks. .... RUNNING NOKIA Tool 0.054 CARD SERIAL: 10XXXXXX [0117] PHONE "D1CGAPE722104411" CONNECTED FATAL ERROR: oem getversions: unknown command Elapsed: 20 secs. PHONE "D1CGAPE722104411" CONNECTED FATAL ERROR: oem getversions: unknown command Elapsed: 130 secs. PHONE "D1CGAPE722104411" CONNECTED FATAL ERROR: oem getversions: unknown command Elapsed: 2 secs. PHONE "D1CGAPE722104411" CONNECTED FATAL ERROR: oem getversions: unknown command Elapsed: 20 secs. PHONE "D1CGAPE722104411" CONNECTED FATAL ERROR: oem getversions: unknown command Elapsed: 10 secs. PHONE "D1CGAPE722104411" CONNECTED FATAL ERROR: oem getversions: unknown command Elapsed: 13 secs. PHONE "D1CGAPE722104411" CONNECTED FATAL ERROR: oem getversions: unknown command Elapsed: 11 secs. PHONE "D1CGAPE722104411" CONNECTED Project : D1C Security version : 0001 model : D1C sub_model : none software version : D1C-1310-0-00CN-A04 SW model : 00CN build number : A04 hardware version : 3.0 RF band id : _850_900_1800_1900^W_1_2_5_8^C_0^T_34_39^L_1_3_5_3 8_39_40_ chip version : none MCP info : none EMMC version : Samsung 5.1 64GB secure : yes Bootloader type : service Download size : 00000511 mB Elapsed: 27 secs. |
