08-08-2020, 11:04 | #1 (permalink) |
Freak Poster Join Date: Aug 2015
Member: 2439409 Status: Offline Thanks Meter: 104 | nokia 7 plus flashing problem .... help me team RUNNING NOKIA Tool 0.055 CARD SERIAL: 10000753 [0117] SELECT FIRMWARE PACKAGE Will flash : B2N-4120-0-00WW-B01.NBx PLEASE CONNECT POWERED OFF PHONE PHONE "B2NGAM8941501018" CONNECTED Project : B2N1 Security version : 0004 model : B2A sub_model : none software version : B2N-415E-0-00WW-B01 SW model : 00WW build number : B01 hardware version : 5.0 RF band id : G_850_900_1800_1900^W_1_2_5_8^L_1_3_5_7_8_20_28_ secure : yes Bootloader type : commercial Download size : 00000384 mB Security version : 0004 Challenge : A7CB78E7D9CC9D2F6386C17D28C96361C90904AC Waiting for calculation process ... RESPONSE: "SUCCESS" [256] BOOTLOADER AUTH PASSED Flash "B2N-0-4120-xbl_service.zip" to "xbl_a" FATAL ERROR: Failed to write "xbl_a", error : "Error flashing partition : Write Protected" Elapsed: 2 secs. SELECT FIRMWARE PACKAGE Will flash : B2N-4120-0-00WW-B01.NBx PLEASE CONNECT POWERED OFF PHONE PHONE "B2NGAA8830303071" CONNECTED Project : B2N1 Security version : 0004 model : B2A sub_model : none software version : B2N-410E-0-00WW-B01 SW model : 00WW build number : B01 hardware version : 5.0 RF band id : G_850_900_1800_1900^W_1_2_5_8^L_1_3_5_7_8_20_28_ secure : yes Bootloader type : commercial Download size : 00000384 mB Security version : 0004 Challenge : 56DE1E9C4EB3CD167AB60F69744DA721BB008E5B Waiting for calculation process ... RESPONSE: "SUCCESS" [256] BOOTLOADER AUTH PASSED Flash "B2N-0-4120-xbl_service.zip" to "xbl_a" Flash "B2N-0-4120-xbl_service.zip" to "xbl_b" Flash "B2N-0-4120-abl_service.zip" to "abl_a" Flash "B2N-0-4120-abl_service.zip" to "abl_b" PHONE "B2NGAA8830303071" REMOVED PHONE "B2NGAA8830303071" CONNECTED Perform auth routine Security version : 0004 Project : B2N1 UID : 3FE7CA534912F9C185DA6300B874514B23F76D9B Waiting for calculation process ... RESPONSE: "SUCCESS" [256] SERVICE AUTH PASSED Flash "B2N-0-4120-gpt_both0.bin" to "partition" Skip flashing "B2N-0-4120-xbl_service.elf" Skip flashing "B2N-0-4120-xbl_service.elf" Skip flashing "B2N-0-4120-abl_service.elf" Skip flashing "B2N-0-4120-abl_service.elf" Flash "B2N-0-4120-tz.mbn" to "tz_a" Flash "B2N-0-4120-rpm.mbn" to "rpm_a" Flash "B2N-0-4120-hwcfg.img" to "hwcfg" Flash "B2N-0-4120-hyp.mbn" to "hyp_a" Flash "B2N-0-4120-pmic.elf" to "pmic_a" Flash "B2N-0-4120-keymaster64.mbn" to "keymaster_a" Flash "B2N-0-4120-cmnlib.mbn" to "cmnlib_a" Flash "B2N-0-4120-cmnlib64.mbn" to "cmnlib64_a" Flash "B2N-4-4120-dspso.bin" to "dsp_a" Flash "B2N-0-4120-devcfg.mbn" to "devcfg_a" Flash "B2N-0-4120-sec.dat" to "sec" Flash "B2N-0-4120-mdtpsecapp.mbn" to "mdtpsecapp_a" Flash "B2N-0-4120-storsec.mbn" to "storsec" Erase "systeminfo_a" Flash "systeminfo.img" to "systeminfo_a" Perform fastboot command "reboot-bootloader" PHONE "B2NGAA8830303071" REMOVED PHONE "B2NGAA8830303071" CONNECTED Perform auth routine Security version : 0004 Project : B2N1 UID : 3FE7CA534912F9C185DA6300B874514B23F76D9B Waiting for calculation process ... RESPONSE: "SUCCESS" [256] SERVICE AUTH PASSED Flash "B2N-3-4120-NON-HLOS.bin" to "modem_a" Flash "B2N-0-4120-mdtp.img" to "mdtp_a" Flash "B2N-0-4120-00WW-boot.img" to "boot_a" Erase "boot_b" Flash "B2N-0-4120-00WW-system.img" to "system_a" Flash "B2N-0-4120-00WW-system_other.img" to "system_b" Flash "B2N-0-4120-BTFM.bin" to "bluetooth_a" Flash "B2N-0-4120-persist.img" to "persist" Erase "userdata" Flash "B2N-00WW-001-sutinfo.img" to "sutinfo" Flash "B2N-0-4120-NV-default.mbn" to "nvdef_a" Flash "C1N-0-0020-0001-hidden.img.ext4" to "hidden_a" Flash "B2N-00WW-015-cda.img" to "cda_a" Erase "ssd" Erase "misc" Erase "sti" Flash "B2N-00WW-015-splash.img" to "splash_a" Flash "B2N-00WW-015-multi-splash.img" to "splash2" Erase "ddr" Flash "B2N-0-4120-00WW-vendor.img" to "vendor_a" Flash "B2N-0-4120-xbl.elf" to "xbl_a" Flash "B2N-0-4120-xbl.elf" to "xbl_b" Flash "B2N-0-4120-abl.elf" to "abl_a" Flash "B2N-0-4120-abl.elf" to "abl_b" Perform fastboot command "oem set_active _a" Perform fastboot command "oem enable-charger-screen" Flash "B2N-0-3510-0001-logfs_ufs_8mb.bin" to "logfs" Flash "md4.dat" to "md4" ReadCommBlock : A device attached to the system is not functioning FATAL ERROR: Failed to write "md4", error : "The operation completed successfully" Elapsed: 346 secs. SELECT FIRMWARE PACKAGE Will flash : B2N-4120-0-00WW-B01.NBx PLEASE CONNECT POWERED OFF PHONE PHONE "B2NGAA8830303071" CONNECTED Project : B2N1 Security version : 0004 model : B2A sub_model : none software version : B2N-4120-0-00WW-B01 SW model : 00WW build number : B01 hardware version : 5.0 RF band id : G_850_900_1800_1900^W_1_2_5_8^L_1_3_5_7_8_20_28_ secure : yes Bootloader type : commercial Download size : 00000384 mB Security version : 0004 Challenge : 9BF6DD0CBEF90E9052AF084B3C5DC0645C2CBB2E Waiting for calculation process ... RESPONSE: "SUCCESS" [256] BOOTLOADER AUTH PASSED Flash "B2N-0-4120-xbl_service.zip" to "xbl_a" Flash "B2N-0-4120-xbl_service.zip" to "xbl_b" Flash "B2N-0-4120-abl_service.zip" to "abl_a" Flash "B2N-0-4120-abl_service.zip" to "abl_b" PHONE "B2NGAA8830303071" REMOVED PHONE "B2NGAA8830303071" CONNECTED Perform auth routine Security version : 0004 Project : B2N1 UID : 3FE7CA534912F9C185DA6300B874514B23F76D9B Waiting for calculation process ... RESPONSE: "SUCCESS" [256] SERVICE AUTH PASSED Flash "B2N-0-4120-gpt_both0.bin" to "partition" Skip flashing "B2N-0-4120-xbl_service.elf" Skip flashing "B2N-0-4120-xbl_service.elf" Skip flashing "B2N-0-4120-abl_service.elf" Skip flashing "B2N-0-4120-abl_service.elf" Flash "B2N-0-4120-tz.mbn" to "tz_a" Flash "B2N-0-4120-rpm.mbn" to "rpm_a" Flash "B2N-0-4120-hwcfg.img" to "hwcfg" Flash "B2N-0-4120-hyp.mbn" to "hyp_a" Flash "B2N-0-4120-pmic.elf" to "pmic_a" Flash "B2N-0-4120-keymaster64.mbn" to "keymaster_a" Flash "B2N-0-4120-cmnlib.mbn" to "cmnlib_a" Flash "B2N-0-4120-cmnlib64.mbn" to "cmnlib64_a" Flash "B2N-4-4120-dspso.bin" to "dsp_a" Flash "B2N-0-4120-devcfg.mbn" to "devcfg_a" Flash "B2N-0-4120-sec.dat" to "sec" Flash "B2N-0-4120-mdtpsecapp.mbn" to "mdtpsecapp_a" Flash "B2N-0-4120-storsec.mbn" to "storsec" Erase "systeminfo_a" Flash "systeminfo.img" to "systeminfo_a" Perform fastboot command "reboot-bootloader" PHONE "B2NGAA8830303071" REMOVED PHONE "B2NGAA8830303071" CONNECTED Perform auth routine Security version : 0004 Project : B2N1 UID : 3FE7CA534912F9C185DA6300B874514B23F76D9B Waiting for calculation process ... RESPONSE: "SUCCESS" [256] SERVICE AUTH PASSED Flash "B2N-3-4120-NON-HLOS.bin" to "modem_a" Flash "B2N-0-4120-mdtp.img" to "mdtp_a" Flash "B2N-0-4120-00WW-boot.img" to "boot_a" Erase "boot_b" Flash "B2N-0-4120-00WW-system.img" to "system_a" Flash "B2N-0-4120-00WW-system_other.img" to "system_b" Flash "B2N-0-4120-BTFM.bin" to "bluetooth_a" Flash "B2N-0-4120-persist.img" to "persist" Flash "B2N-00WW-001-sutinfo.img" to "sutinfo" Flash "B2N-0-4120-NV-default.mbn" to "nvdef_a" Flash "C1N-0-0020-0001-hidden.img.ext4" to "hidden_a" Flash "B2N-00WW-015-cda.img" to "cda_a" Flash "B2N-00WW-015-splash.img" to "splash_a" Flash "B2N-00WW-015-multi-splash.img" to "splash2" Erase "ddr" Flash "B2N-0-4120-00WW-vendor.img" to "vendor_a" Flash "B2N-0-4120-xbl.elf" to "xbl_a" Flash "B2N-0-4120-xbl.elf" to "xbl_b" Flash "B2N-0-4120-abl.elf" to "abl_a" Flash "B2N-0-4120-abl.elf" to "abl_b" Perform fastboot command "oem set_active _a" Perform fastboot command "oem enable-charger-screen" Flash "B2N-0-3510-0001-logfs_ufs_8mb.bin" to "logfs" Flash "md4.dat" to "md4" FINISHED PHONE "B2NGAA8830303071" REMOVED Elapsed: 346 secs. SELECT FIRMWARE PACKAGE Will flash : B2N-4120-0-00WW-B01.NBx PLEASE CONNECT POWERED OFF PHONE PHONE "B2NGAM8941501018" CONNECTED Project : B2N1 Security version : 0004 model : B2A sub_model : none software version : B2N-415E-0-00WW-B01 SW model : 00WW build number : B01 hardware version : 5.0 RF band id : G_850_900_1800_1900^W_1_2_5_8^L_1_3_5_7_8_20_28_ secure : yes Bootloader type : commercial Download size : 00000384 mB Security version : 0004 Challenge : 9767451CE658B718E74ADFFCFD656A759DD43528 Waiting for calculation process ... RESPONSE: "SUCCESS" [256] BOOTLOADER AUTH PASSED Flash "B2N-0-4120-xbl_service.zip" to "xbl_a" FATAL ERROR: Failed to write "xbl_a", error : "Error flashing partition : Write Protected" Elapsed: 2 secs. SELECT FIRMWARE PACKAGE Will flash : B2N-4120-0-00WW-B01.NBx PLEASE CONNECT POWERED OFF PHONE PHONE "B2NGAM8941501018" CONNECTED Project : B2N1 Security version : 0004 model : B2A sub_model : none software version : B2N-415E-0-00WW-B01 SW model : 00WW build number : B01 hardware version : 5.0 RF band id : G_850_900_1800_1900^W_1_2_5_8^L_1_3_5_7_8_20_28_ secure : yes Bootloader type : commercial Download size : 00000384 mB Security version : 0004 Challenge : 32AD42F7E865A69AB458C1C2C42DCC5E27D4C7A8 Waiting for calculation process ... RESPONSE: "SUCCESS" [256] BOOTLOADER AUTH PASSED Flash "B2N-0-4120-xbl_service.zip" to "xbl_a" FATAL ERROR: Failed to write "xbl_a", error : "Error flashing partition : Write Protected" Elapsed: 2 secs. SELECT FIRMWARE PACKAGE Will flash : B2N-4120-0-00WW-B01.NBx PLEASE CONNECT POWERED OFF PHONE PHONE "B2NGAM8941501018" CONNECTED Project : B2N1 Security version : 0004 model : B2A sub_model : none software version : B2N-415E-0-00WW-B01 SW model : 00WW build number : B01 hardware version : 5.0 RF band id : G_850_900_1800_1900^W_1_2_5_8^L_1_3_5_7_8_20_28_ secure : yes Bootloader type : commercial Download size : 00000384 mB Security version : 0004 Challenge : B670CF844696459A2437393AD344176F28BB26FE Waiting for calculation process ... RESPONSE: "SUCCESS" [256] BOOTLOADER AUTH PASSED Flash "B2N-0-4120-xbl_service.zip" to "xbl_a" FATAL ERROR: Failed to write "xbl_a", error : "Error flashing partition : Write Protected" Elapsed: 2 secs. |
