06-11-2021, 09:56 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Pakistan Age: 44
Member: 240756 Status: Offline Thanks Meter: 90 | Nokia Driver installation Error folder.always show error. See attached pic. and whenever i try to repair imei of Nokia 5 TA-1024 software has been closed during process. Code: RUNNING NOKIA Tool 0.051 CARD SERIAL: 1XXXXXXX [XXXX] PHONE "D1AGAS3773115642" CONNECTED Project : ND1 Security version : 0004 model : D1A sub_model : none software version : ND1-563D-0-00WW-B01 SW model : 00WW build number : B01 hardware version : 5.0 RF band id : _850_900_1800_1900^W_1_2_5_8^L_1_3_5_7_8_20_28_38_40 chip version : none MCP info : none EMMC version : Samsung 5.1 16GB secure : yes Bootloader type : commercial Download size : 00000511 mB Elapsed: 7 secs. ================================== software Tool Close during process PHONE "D1AGAS3773115642" CONNECTED Project : ND1 Security version : 0004 model : D1A sub_model : none software version : ND1-563D-0-00WW-B01 SW model : 00WW build number : B01 hardware version : 5.0 RF band id : _850_900_1800_1900^W_1_2_5_8^L_1_3_5_7_8_20_28_38_40 chip version : none MCP info : none EMMC version : Samsung 5.1 16GB secure : yes Bootloader type : commercial Download size : 00000511 mB Security version : 0004 Challenge : EE1E1A04411E8F7D97BF1D96DB718CA11806D536 Waiting for calculation process ... RESPONSE: "SUCCESS" [256] BOOTLOADER AUTH PASSED Flash "D1C-0-5600-emmc_appsboot_service.zip" to "aboot" PHONE "D1AGAS3773115642" REMOVED PHONE "D1AGAS3773115642" CONNECTED Perform AUTH routine Security version : 0004 Project : ND1 UID : 52C2683510914452C9872D5087515FBEECCC8DDF Waiting for calculation process ... RESPONSE: "SUCCESS" [256] SERVICE AUTH PASSED Flash "D1C-0-5600-ftm.img" to "ftmboot" Flash "D1C-0-5600-emmc_appsboot.mbn" to "aboot" REBOOT TO FACTORY MODE ... FATAL ERROR: STOPPED BY USER Last edited by the_laser; 06-14-2021 at 00:14. |
06-14-2021, 00:14 | #2 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | Default windows driver for EasyBox cardreader is faulty and it will break Nokia tool "Service" function for smartphones - Nokia tool will be forcible closed during SERVICE operation while phone reboot to factory mode. solution : install this cardreader drivers : https://support.lenovo.com/ru/en/dow...-thinkpad-x250 |
The Following User Says Thank You to the_laser For This Useful Post: |
06-19-2021, 08:54 | #3 (permalink) | |
Member: 240756 Status: Offline Thanks Meter: 90 | Quote:
smard card driver(WUDF). See Pics. Please resolve this issue.i really need help.software process break and close during any operation. | |
06-19-2021, 09:11 | #4 (permalink) |
Member: 9519 Status: Offline Thanks Meter: 2,150 | try to use normal OS, not in test mode. probably, thats why signed driver not installed. i'm tried this driver on standard smartcard reader with USB\VID_058F&PID_9540 ( device manager -> properties -> hardware IDs ) and it is working without problem. i can not help you more, if you still not succeed with this, then you need to get other smartcard reader and use easybox card in it. |
06-19-2021, 13:01 | #5 (permalink) | |
Frp is working fine i have tried. | |
06-20-2021, 18:15 | #7 (permalink) | |
Member: 240756 Status: Offline Thanks Meter: 90 | Quote: How to fix this and which type of driver have to install.installed Alco Micro smart card driver which you reffered. | |
The Following User Says Thank You to Aazib jhon For This Useful Post: |
06-22-2021, 05:27 | #8 (permalink) |
Member: 9519 Status: Offline Thanks Meter: 2,150 | i can not help you more. check windows device manager with proper driver installed. |
06-22-2021, 14:57 | #9 (permalink) | |
the problem same. i update windows and also drivers online but in 3 PC have Same problem. Anyway thanks your help. i will try once more and will make Video also. | |
06-25-2021, 08:44 | #10 (permalink) |
Junior Member Join Date: Jun 2013
Member: 1960844 Status: Offline Sonork: saeed1000 Thanks Meter: 0 | hello I have the same problem (setting IMEI) in the step : REBOOT TO FACTORY MODE ... automatically dongle disconnects and software stop working second problem how to set second IMEI becouse second box is inactive? Im trying these by easy box dongle - nokia tool .060- win 10 x64 - nokia 3.1 plus |
