06-12-2018, 00:27 | #1 (permalink) |
No Life Poster Join Date: Mar 2018 Location: Future.... ✌️
Member: 2825953 Status: Offline Thanks Meter: 246 | Nokia 3 Android 8.0 tried for service purposes but only the vibration problem Code: RUNNING NTool 0.030 PLEASE CONNECT POWERED OFF PHONE PHONE "XXXXXXXXXXXXXXXX" CONNECTED ProjectCode : NE1 model : NE1 sub_model : none software version : NE1-3310-0-00WW-B01 SW model : 00WW build number : B01 RF band id : chip version : MT6737 MCP version : Micron 16GB secure : no Bootloader type : service Download size : 00001054 mB Security version : 0004 ProjectCode : NE1 UID : XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX Waiting for calculation process ... RESPONSE: "SUCCESS" [256] SERVICE AUTH PASSED Flash "NE1-0-331B-lk.img" to "lk" ReadCommBlock : A device attached to the system is not functioning FATAL ERROR: Failed to write "lk", error : "The operation completed successfully" PHONE "XXXXXXXXXXXXXXXXXX" REMOVED Elapsed: 304 secs. SELECT FIRMWARE PACKAGE Will flash : NE1-139M-0-00WW-B03-SERVICE.NBx PLEASE CONNECT POWERED OFF PHONE Last edited by the_laser; 06-12-2018 at 01:06. |
06-12-2018, 02:36 | #2 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | it seems that device disconnected during boot write, so phone is now without part of boot, called "LittleKernel" why this happen ? usually low battery or just disconnected cable. a several options to do - write required boot part yourself in 3 minutes with Mediatek tools - wait until i'm release boot repair for this phone ( could take a long time, because of p.1 ) - use other tools, which support HMD Nokia 3 and try to fix boot with it Instructions to fix : 1. download from NTool support area Fix_NE1_LK.zip ( Inside Nokia3.Essential.NE1 folder ) 2. unpack archive with stored paths to disk C: 3. if you have x64 windows run as administrator Code: C:\MTK\SP_FlashTool_NE1\SmartPhoneDriver\x64\dpinst.exe if you have x32 windows run as administrator Code: C:\MTK\SP_FlashTool_NE1\SmartPhoneDriver\x86\dpinst.exe 4. run as administrator Code: C:\MTK\SP_FlashTool_NE1\flash_tool.exe 5. connect phone and if you do all fine, you will see "OK" dialog box after few seconds. it is very possible that you have drivers from other tools, which will recognize Nokia 3 on wrong step and you will get error : Code: ERROR : S_AUTH_HANDLE_IS_NOT_READY (0x1388) [User] This is a secure Base-band Chip! Please select the authentication file first. [HINT]: then press and hold "volume up" + power on until phone restart - procedure should be completed. after LK repair, charge phone for at least 40 minutes and proceed with flashing NE1-139M-0-00WW-B03-SERVICE.NBx using NTool, then do required service operations. it is better NOT use USB 3.0 ports for MTK phones. Last edited by the_laser; 06-12-2018 at 02:42. |
The Following 12 Users Say Thank You to the_laser For This Useful Post: |
06-12-2018, 07:46 | #3 (permalink) |
Member: 2825953 Status: Offline Thanks Meter: 246 | thank you sir my problem was big issue can't detected spflash tool before but your provided solution is amazing magic in 5 minute my problem solved. Code: RUNNING NTool 0.030 SELECT FIRMWARE PACKAGE Will flash : NE1-139M-0-00WW-B03-SERVICE.NBx PLEASE CONNECT POWERED OFF PHONE PHONE "XXXXXXXXXXXXXX" CONNECTED model : NE1 sub_model : none software version : NE1-3310-0-00WW-B01 SW model : 00WW build number : B01 RF band id : chip version : MT6737 MCP version : Micron 16GB secure : yes Bootloader type : commercial Download size : 00000128 mB BOOTLOADER AUTH PASSED Flash "NE1-0-215H-lk_service.zip" to "lk" PHONE "XXXXXXXXXXXXXX" REMOVED PHONE "XXXXXXXXXXXXXX" CONNECTED Flash "NE1-0-139M-preloader_NE1.bin" to "preloader" Skip flashing "NE1-0-139M-lk_service.bin" Flash "NE1-0-215H-lk_service.zip" to "lk" Flash "NE1-0-139M-trustzone.bin" to "tee1" Flash "NE1-0-139M-trustzone.bin" to "tee2" Perform fastboot command "reboot-bootloader" PHONE "XXXXXXXXXXXXXX" REMOVED PHONE "XXXXXXXXXXXXXX" CONNECTED Flash "NE1-0-139M-00WW-boot.img" to "boot" Flash "NE1-0-139M-00WW-recovery.img" to "recovery" Flash "NE1-0-139M-secro.img" to "secro" Flash "NE1-0-139M-logo.bin" to "logo" Flash "NE1-0-139M-00WW-system.img" to "system" Flash "NE1-00WW-001-sutinfo.img" to "sutinfo" Flash "NE1-00WW-009-cda.img" to "cda" Flash "fver" to "sys_info" Flash "cache" Flash "userdata" Flash "NE1-0-215H-lk.bin" to "lk" FINISHED Elapsed: 504 secs. |
The Following 4 Users Say Thank You to -=P.F.U=- For This Useful Post: |
06-12-2018, 14:08 | #4 (permalink) |
Member: 9519 Status: Offline Thanks Meter: 2,150 | good to hear. always charge phone - battery should be at least 50% before flashing. |
The Following 5 Users Say Thank You to the_laser For This Useful Post: |
06-12-2018, 20:42 | #5 (permalink) |
Member: 2825953 Status: Offline Thanks Meter: 246 | Please give me solution, very sorry for this problem. After repairing completed this same phone, after decide some optional issues it was upgraded via WiFi, Customer thinking old version was smooth able for him, so it's was try to downgrade with your recommendation firmware. But when the flashboot mode starts to flash through this unfortunately get this error. Now Device Manager only shows MTK USB port. phone battery was 75% charge. Code: RUNNING NTool 0.030 SELECT FIRMWARE PACKAGE Will flash : NE1-139M-0-00WW-B03-SERVICE.NBx PLEASE CONNECT POWERED OFF PHONE PHONE "xxxxxxxxxx" CONNECTED ProjectCode : NE1 model : NE1 sub_model : none software version : NE1-331B-0-00WW-B01 SW model : 00WW build number : B01 RF band id : chip version : MT6737 MCP version : Micron 16GB secure : no Bootloader type : service Download size : 00001054 mB Security version : 0004 ProjectCode : NE1 UID : xxxxxxxxxx Waiting for calculation process ... RESPONSE: "SUCCESS" [256] SERVICE AUTH PASSED Flash "NE1-0-139M-preloader_NE1.bin" to "preloader" ReadCommBlock : The semaphore timeout period has expired FATAL ERROR: Failed to write "preloader", error : "The operation completed successfully" Elapsed: 304 secs. |
