Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > iPOWER X & iREWORK Station
Old 10-03-2020, 11:43   #1 (permalink)
Member: 467983
Thanks Meter: 16
aUTORIZATION UNABLE TO UPDATE
Heater (T:220 M:240)
Extern (T:0 M:0)
K Sensor (T:30 M:30)
[warn] Authorization required!
[info] Device Update requested! Connecting to server ...
[info] Requesting firmware update 4
[info] LiveSession - updating box firmware now ...
[erro] Plist Payload
[info] > Entering boot mode ...
[info] Removing USB\VID_04D9&PID_1703\BB64FF11
[info] Adding USB\VID_03EB&PID_2067\BB64FF11
[erro] set configuration 1...
[erro] claimed interface 0...
[info] Operation ended with Result: Failed to Authorize!
[erro] Can't detect device after update! Please check connection and update in BOOT mode if required!
[done] Finished loading settings!
Extern (T:0 M:0)
Heater (T:140 M:150)
Extern (T:80 M:85)
[erro] Device does nor respond correctly to our request! Please update the box to the latest version in BOOT mode!
[info] Adding USB\VID_04D9&PID_1703\BB64FF11
[info] Removing USB\VID_03EB&PID_2067\BB64FF11
[erro] Manufacturer descriptor problem! Skipping...
[info] > Writing ...
[erro] > Cannot interpret data for this version, please use a newer software or update your box!
Old 10-06-2020, 11:20   #2 (permalink)
PhoneCareCenter's Avatar
Member: 574123
Sonork: 100.1581804
Thanks Meter: 1,839
@flip_gsm
If you have not solved this issue then try to Update Software to the latest version, restart your PC for this operation or Temporarily disable Firewall. Contact me on Skype for further assistance.
MFC Team
Old 11-21-2020, 10:11   #3 (permalink)
Member: 2573937
I have the same problem. Please tell me how to solve the problem. Thank you .^^
Old 11-27-2020, 01:20   #4 (permalink)
Member: 2364827
failed to authorize
hello, i have a problem with irework, no authorization! how to fix it ???
sn: 56A395CC
FWV 3
please help, thank you !
Old 11-28-2020, 05:44   #5 (permalink)
.::Gsmdenis::.'s Avatar
Member: 79315
Thanks Meter: 6,024
We have upload one beta version for test.
Steps:
A,Go to https://www.mfcbox.com/content/dashborad Active iREWORK by Serial number
B, Download the beta software https://www.mfcbox.com/uploads/betatest/MFC_S3.41.rar and unzip to c:/mfc folder (Required install 3.31 first)
C, Open software and go setting Choose "Backup server" then press switch server&Restart
D, Go to iREWORK tab do update your box
Br.,
Page generated in 0.17482 seconds with 8 queries
