11-20-2020, 03:40 | #2 (permalink) |
Junior Member Join Date: Oct 2009
Member: 1137902 Status: Offline Thanks Meter: 0 | [info] Loading history ... [done] Finished loading settings! [info] Adding USB\VID_04D9&PID_1703\6C21 [warn] Smartcard state: 05 [warn] Current frequency reading error! Heater might not work as expected!(51) [erro] Device does nor respond correctly to our request! Please update the box to the latest version in BOOT mode! [warn] Smartcard state: 05 [warn] Current frequency reading error! Heater might not work as expected!(51) [info] Removing USB\VID_04D9&PID_1703\6C21F [info] Adding USB\VID_04D9&PID_1703\6C21 [warn] Smartcard state: 05 [warn] Current frequency reading error! Heater might not work as expected!(51) Heater (T:220 M:240) Extern (T:0 M:0) K Sensor (T:30 M:30) [info] Removing USB\VID_04D9&PID_1703\6C21F [info] Adding USB\VID_0000&PID_0002\6&304F5B40&0&4 [info] Removing USB\VID_0000&PID_0002\6&304F5B40&0&4 [info] Adding USB\VID_0000&PID_0002\6&304F5B40&0&4 [info] Removing USB\VID_0000&PID_0002\6&304F5B40&0&4 [info] Adding USB\VID_04D9&PID_1703\6C21F [info] Device Update requested! Connecting to server ... [info] Requesting firmware update 4 [erro] Some problem occured while conecting to server, please retry [info] Removing USB\VID_04D9&PID_1703\6C21 [info] Adding USB\VID_04D9&PID_1703\6C21F [info] Device Update requested! Connecting to server ... [info] Requesting firmware update 4 [info] LiveSession - Buffered RW [info] Operation ended with Result: LiveSession failed! [erro] Can't detect device after update! Please check connection and update in BOOT mode if required! [info] Removing USB\VID_04D9&PID_1703\6C21F [info] Removing USB\VID_046D&PID_C534\6&235FE06F&0&1 [info] Adding USB\VID_046D&PID_C534\6&235FE06F&0&2 |
