Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > iPOWER X & iREWORK Station
Old 02-04-2019, 17:23   #1 (permalink)
Member: 194092
Thanks Meter: 6
[help]USING DEFAULT PRESET!!!!
hi! i would like to know if the presets of the irework must be used with hot air station.
i've tried to remove the a9, with only a9 profile with no luck.
i have must used hot air.
is it normal?
Old 02-05-2019, 06:25   #2 (permalink)
.::Gsmdenis::.'s Avatar
Member: 79315
Thanks Meter: 6,024
hello,
You can work with or without hot air , as we test both way are working.
If you wanna use hot air , you can reduce the temperature a little bit lower than default settings, eg 10-15 degrees lower .
While working , you can using hot air heating the top of RAM (for A9 you need do very fast , can not heat long time) then use remove tools to do that.
Br.,
Denis
Old 02-05-2019, 12:11   #3 (permalink)
Member: 194092
Thanks Meter: 6
i've tried a10 profile....only preheat...
after 8 minutes from the reached temperature, it was impossible to remove the cpu.
i've used hot air...i dont understand why
Old 02-11-2019, 17:50   #4 (permalink)
Member: 194092
Thanks Meter: 6
please, please help!!!
Old 02-14-2019, 06:45   #5 (permalink)
Member: 79315
Thanks Meter: 6,024
can you show me some pictures how you did ?
Old 02-15-2019, 19:13   #6 (permalink)
Member: 194092
Thanks Meter: 6
like the video you posted about remove iphone 7 cpu.
my problem is that, if i don't use hotair, i can not desolder the cpu
one question: from when i reach the right temperature (with acoustic signal), how much time i have to wait before remove the cpu?
Old 02-16-2019, 02:59   #7 (permalink)
Member: 79315
Thanks Meter: 6,024
usually once reach the temperature, wait 1-3 mins then can start to disassemble , this depends on how you put the PCB (mean's must touch the heating base as well), that's why we ask you 'A few pictures of the issue would help us diagnose the problem' !
Br.,
Old 03-03-2019, 21:04   #8 (permalink)
Member: 194092
Thanks Meter: 6
why don't you insert also a "time attack" in the program
for example a countdown from when the heater reach the temperature
Old 03-05-2019, 08:39   #9 (permalink)
Member: 194092
Thanks Meter: 6
so i've tried to remove cpu of iphone 6...
after ten minutes at 255 degrees, still impossible to remove cpu, so i have used also hot air
then i've tried a small experiment: check the real temperature of the motherbord: setting irework at 270, i've 190 on the motherboard!
https://www.youtube.com/watch?v=K86U4FDMYOQ
Old 03-07-2019, 08:50   #10 (permalink)
Member: 79315
Thanks Meter: 6,024
You have to install the screws for both side at the UPH, otherwise the temperature will be bad !
Please check attached picture ! thanks
BR.,
Old 03-07-2019, 13:37   #11 (permalink)
Member: 194092
Thanks Meter: 6
i've never had those screws!
could you tell me the size?
Old 03-07-2019, 14:41   #12 (permalink)
Member: 79315
Thanks Meter: 6,024
check in that plastic tool box ! must inside that box !
Old 03-07-2019, 22:13   #13 (permalink)
Member: 194092
Thanks Meter: 6
https://www.youtube.com/watch?v=iQzB3p4HX0w
no chances afte used the screw
Old 03-08-2019, 12:33   #14 (permalink)
Member: 79315
Thanks Meter: 6,024
A, While work you must be sure the phone board contacting UPH Base very well
B, while you test temperature you should test the UPH base first , if phone board contacting UPH base very well, then test the top (the temperature should be almost similar)
C, you can also using also ESP cable to check the temperature if good
Br.,
Old 03-08-2019, 14:35   #15 (permalink)
Member: 194092
Thanks Meter: 6
Ok, i will check the uph base without the motherboard and i will post you a video
thanks
Page generated in 0.17766 seconds with 10 queries
