Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > iPOWER X & iREWORK Station
Old 03-12-2021, 13:45   #1 (permalink)
Member: 869567
Thanks Meter: 3
iPOWER Software and firmware version mismatch
Getting this error:
" iPOWER Software and firmware version mismatch "
no manual update file found on MFC website.
Update Authorize is grayed out.
Last edited by .::Gsmdenis::.; 03-12-2021 at 20:26. Reason: attached picture remove, due to with serial number :-)
Old 03-12-2021, 20:26   #2 (permalink)
.::Gsmdenis::.'s Avatar
Member: 79315
Thanks Meter: 6,024
Active your iPOWER X on mfcbox.com by using box serial number, and then do update !!!
Old 03-13-2021, 01:14   #3 (permalink)
Member: 869567
Thanks Meter: 3
Only have an 8 digit number number (bar code) on the bottom of my iPOWER X and that doesn't work.
Old 03-13-2021, 03:51   #4 (permalink)
Member: 79315
Thanks Meter: 6,024
input start with 0x as Prefix before the serial number
Old 03-13-2021, 15:43   #5 (permalink)
Member: 869567
Thanks Meter: 3
Ok, thanks.
Activated but still getting error:
[info] iPOWER X - Searching ...
[info] iPOWER X - device found !
[info] iPOWER X - Software and firmware version mismatch! Please update your iPower manually!
[erro] Resetting due too many errors!
Update Authorize still grayed out.
Switching servers same problem.
Old 03-14-2021, 08:58   #6 (permalink)
Member: 79315
Thanks Meter: 6,024
check this guide:
https://www.mfcbox.com/tutorials/how...e-ipower-x-box
Old 03-15-2021, 02:54   #7 (permalink)
Member: 869567
Thanks Meter: 3
Still not working, new error. Is it a server problem maybe?
[serv] News: Welcome to our Online Server
[erro] Server init state unknown
Old 03-15-2021, 06:38   #8 (permalink)
Member: 79315
Thanks Meter: 6,024
Are you sure you using v3.51B ?
Old 03-15-2021, 11:34   #9 (permalink)
Member: 869567
Thanks Meter: 3
I'm starting the MFC_3.5B1.exe from file manager, execute exe file manually.
Get this now, progress, but sitll not ok?
Old 03-15-2021, 18:02   #10 (permalink)
Member: 79315
Thanks Meter: 6,024
You need release the button once update starting
Old 03-15-2021, 22:14   #11 (permalink)
Member: 869567
Thanks Meter: 3
I know, I did, tried different ones, releasing it as soon as update started, holding it longer etc...
This was just a few minutes ago:
Is this ok now?
Old 03-16-2021, 15:23   #12 (permalink)
Member: 79315
Thanks Meter: 6,024
If be able to use now , then mean's ok !
Page generated in 0.17667 seconds with 9 queries
