Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > iPOWER X & iREWORK Station
Old 10-28-2018, 21:09   #1 (permalink)
.::Gsmdenis::.'s Avatar
Member: 79315
Thanks Meter: 6,024
Arrow MFC Suite 3in1 V3.5 Released ! -2021/02/10
iPOWER X Official Version 2.2 Released !
Software Download:
  • Software is available for all customers with valid to download that from Download Section.
The Following 15 Users Say Thank You to .::Gsmdenis::. For This Useful Post:
Old 10-29-2018, 18:44   #2 (permalink)
Member: 79315
Thanks Meter: 6,024
Arrow iPOWER X Official Version 2.2 Full installer Released !
  • This file is Version 2.2 that including iREWORK and iPOWER X Main Software
iREWORK Station Changelogs:
  • Fixed Profile Option display Bugs
Software Download:
The Following 2 Users Say Thank You to .::Gsmdenis::. For This Useful Post:
Old 11-06-2018, 20:50   #3 (permalink)
Member: 79315
Thanks Meter: 6,024
Arrow iPOWER X Official Version 2.3 Full installer Released !
iPOWER X & iREWORK Official Version 2.3 Full installer Released !
  • This file is Version 2.3 that including iREWORK and iPOWER X Main Software
Update Changelogs:
  • Modify the bug that the software can't open on some computers
  • Improve the effectiveness of iPOWER X Box (such as reach the target value of 5 times faster and "ON" button response speed, etc.)
  • Improving iPOWER X input voltage detection
  • Improving iPOWER X output voltage detection
  • Solved more software interface bugs, such as status bar message etc.
  • Change maximum output voltage overvoltage protection limit to 18V
  • Update iPOWER X firmware (user must manually update box through V2.3 software)
  • Software version update to 2.3
Software Download:
  • We recommend all customers to upgrade to this Version, Software is available for all customers with valid to download that from Download Section.
Upgrade iPOWER X Box Firmware:
  • Open V2.3 Software, Connect iPOWER X box to computer, Holding "On" Button and plug input Power, waiting the procedure done.
Old 11-08-2018, 07:49   #4 (permalink)
Member: 79315
Thanks Meter: 6,024
iPOWER X Firmware Updated !
Upgrade Firmware Steps (Internet Required):
  • Open iPOWER X software (Always use the Latest Software)
  • Connect iPOWER X box to Computer by PC Cable
  • Holding "On" key of iPOWER X Box
  • Connect DC Input Power to iPOWER X Box
  • Once start upgrading release "On" Key
  • Waiting Upgrading procedure Done
The Following 3 Users Say Thank You to .::Gsmdenis::. For This Useful Post:
Old 11-18-2018, 13:30   #5 (permalink)
Member: 79315
Thanks Meter: 6,024
Arrow iPOWER X Box Official V2.5 Released !
  • The main software 2.5 which including IREWORK STATION and iPOWER X BOX (English and Chinese version) is now available to all customers.
The changes are here:
  • Add iPOWER X BOX Firmware Version info
  • Update iPOWER BOX Firmware to V4
  • Imporved "POWER" button output standard response time
All customers are encouraged to upgrade to the latest version, The update file required install full installer version 2.3 first, after download the update file you need extract the file to C:/MFC_IRPW folder. and then do box firmware update.
How to upgrade iPOWER X Firmware ?
Old 02-20-2019, 08:28   #6 (permalink)
Member: 79315
Thanks Meter: 6,024
Arrow iPOWER X Box Official V3.0 Released !
We're pleased to announce the release for iPOWRE X 3.0, This is a major release with many new features and bugfixes. It's recommended all users upgrade to this version.
  • The main software 3.0 which including IREWORK STATION and iPOWER X BOX (English and Chinese version) is now available to all customers.
All Changelogs listed here:
Box Firmware updates:
  • Modified box firmware and main software to support 3 digits for Output Voltage and Test Voltage;
  • Modified box firmware to output data at a much faster rate (> 1000points per second/channel) in order to detect small fluctuations of current or voltage; the Graph Update rate is displayed in the computer software near the buffer size;
Software updates:
  • Redesigned the data aquisition procedure and data display so it can support much faster data rates;
  • Added Communication Speed option in Software and Box's Firmware enabled to talk at higher baudrates with the software (default is 115200bps and now 230400, 614400 and 921600bps are available too);
  • Time/DIV setting to select X axis unit time (The graph is formed by 10 time units);
  • Added Trigger parameters - the trigger can be edited to a desired value for each channel and once the desired value will be reached the graph will start recording and stop after the 10 time units *Time/DIV setting. If trigger parameters are zero then the trigger function will be disabled;
  • Trigger sweep mode dictates if the trigger will fire one time and stop, or will fire continuously. There are two settings, NORMAL and SINGLE;
  • Recording of almost unlimited time (depends on computer memory and hard drive space);
  • Added crosshair cursor (the two green lines that form a cross) to be easy to measure graph current position and value. It will calculate graph voltage, current, current time in current screen, total time from zero;
  • Added normal time cursors (to measure precise time between 2 points). This can be enabled disabled by checking the Cursors checkbox;
  • Added LOAD and SAVE function for graph that will output .dso file types;
  • Organized graphic function in channels (default channels are Input Voltage, Output Voltage, Output Current, Test Voltage). This channels are organized in groups and there is a default group. Channels cane be hidden displayed individually and also in groups;
  • Added Analog display function in case oscilloscope function is not required;
  • Added "Property" type menu on the right side of graph to be easy to manager related settings;
  • Modified top axis to display time from start of recording;
  • Modified right axis to represent Current in Amperes, so the current is better displayed at higher voltages. (So the left axis is the voltage axis, right axis is the current axis, top axis is the time from start axis, and bottom axis the the current frame time axis);
  • Added Markers that can be edited and added by the user for each channel. This markers will be useful to compare previous measurements againts new measurements and detect problems for devices; A max of 100 markers are available for each channel. Markers can be added also by using keyboard shortcuts (C, V, T, I);
  • Added horizontal time selection slider used to navigate in graph once stopped;
  • Added Show/Color function for individual graph elements (can show/hide channels, show hide/targets, change channel display color);
  • Saving a graph the user must check if the "Save" property is checked for each channel if wants to save. By default this is TRUE. Also if the user press 'SHIFT' while pressing Save will force the software to save Markers and Channel information only and not channel data;
  • After loading a graph the the user can adjust "Offset" property for each channel group (a .dso file represents a channel group). This will force the data to be displayed by adding the "Offset" value to each individual point so when entire group can be moved by X seconds left or right in graph. "Offset" represents seconds and can be positive or negative;
  • Support complete Chinese and English interface;
  • Added Auto Pulse function. The Auto pulse function will start and stop the power supply after a configurable amount of time for a configurable amount of times. This can be stopped by pressing STOP button or by disabling the Auto pulse checkbox;
  • Added Voltage Calibration function to calibrate box and display more precise voltage and current readings;
  • Added Current Calibration function to calibrate the current display to a zero offset. Please use this function after the voltage calibration is complete;
Bug-Fixes:
  • Various crashes during aquisition;
  • Correct display of markers labels;
The Following 21 Users Say Thank You to .::Gsmdenis::. For This Useful Post:
Old 04-21-2019, 06:52   #7 (permalink)
Member: 79315
Thanks Meter: 6,024
Arrow iPOWER X Box Official V3.1 Released !
We're pleased to announce the release for iPOWRE X 3.1, As this is a fairly large release with some heavy new features,there could still be bugs, If you find any issues, please report them here so avoid duplicates, feedback will be greatly appreciated.
  • Added analyzer tools tab in order to certify/comparison the data acquisition result (.dso file types) to help do fast data processing and fault diagnosis etc;
  • Added identifier for vertical/horizontal axis;
  • Added the ability to select the graph line width, the ability to enable or disable the legend option;
  • Added the ability to customize graph channel color;
  • Reorganized Voltage and Current Analog Meter show effects;
  • Added crosshair cursor showing the real-time and dynamic data;
  • Plus various other fixes
The Following 4 Users Say Thank You to .::Gsmdenis::. For This Useful Post:
Old 07-24-2019, 17:53   #8 (permalink)
Member: 79315
Thanks Meter: 6,024
Thumbs up iPOWER X Official Version 3.2 Released !
We're pleased to announce the release of iREWORK & iPOWER X 3.2.
  • This is a major release with many new exciting features.
  • Improved the graphical interface, now iREWORK and iPOWER X interfaces are similar and more intuitive
  • Fixed blocking when using bigger line width of graph
  • Fixed box disconnect issues due to communications errors (Now software will reconnect automatically)
  • Cursors usage has changed. Now just click on the graph two times to select cursors position and measure. (For iPOWER X)
  • Fixed various crashes when 50ms was selected (For iPOWER X)
  • Fixed various selection crash issue while playing recording (For iPOWER X)
  • Markers function changed (Now click on graph first then add markers by using shortcut key )
  • Markers fit problem solved for Chinese characters
  • Software version update to V3.2
  • Box firmware updated to be faster and more accurate
The Following 7 Users Say Thank You to .::Gsmdenis::. For This Useful Post:
Old 07-23-2020, 08:56   #9 (permalink)
Member: 79315
Thanks Meter: 6,024
Arrow MFC Suite 3in1 V3.3 Beta3 Released ! -2020/7/23
Bugfixes & Changes:
  • Improved FDR timeout issue
  • Improved update /restore function under windows 32bit
  • Improved history loading
  • Improved multi same model device operating in same time
  • Added to detect device UDID in recovery mode for the first attach
  • Solved some bugs when closing the software
Updates:
  • After download the update file you need extract the file to c:/mfc folder.
Software Download:
Ps. As this is a major new release with many changes, we'll be going for an extended testing phase. There are also some gui fixes which we'll describe in more detail after the release is out. Please try and report issues in this thread to avoid duplicate support issue.
Old 02-10-2021, 07:27   #10 (permalink)
Member: 79315
Thanks Meter: 6,024
Arrow MFC V3.5 Beta1 Released !- Purple diagnostic function updated 2021/2/10
We're very pleased to announce a new release MFC V3.5 Beta
This has new features and bugfixes:
  • Add Com Port Refresh Function
  • Add All Area /Region syscfg Selection
  • Add Backlight testing function
  • Add read Battery All Data function
  • Add read Device Temperature data / Nand Data function
  • Add test function for Compress / Touch / PhotoSensor / Button etc
  • Improved Backup All syscfg Data function
  • Fixed Write Syscfg backup Data function
  • Fixed Driver install for WTF mode
  • Other small bugs fix
Upgrading to new Versions:
  • This update file required install full installer version 3.4 first, after download the update file you need extract the file to c:/mfc folder. The downloaded version of the software is available now from support page with valid membership.
Dropbox Link V3.4: Download
Dropbox Link V3.5b1: Download
The Following User Says Thank You to .::Gsmdenis::. For This Useful Post:
Page generated in 0.29022 seconds with 8 queries
