Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MFC Team Products > iPOWER X & iREWORK Station
Old 11-26-2017, 20:06   #1 (permalink)
.::Gsmdenis::.'s Avatar
Member: 79315
Thanks Meter: 6,024
MFC Suite 3in1 V3.5 Released ! -2021/02/10
iREWORK Official Version 2.1 Released !
Software Download:
  • Software is available for all customers with valid to download that from Download Section.
The Following 3 Users Say Thank You to .::Gsmdenis::. For This Useful Post:
Old 10-28-2018, 21:05   #2 (permalink)
Member: 79315
Thanks Meter: 6,024
Arrow iREWORK Official Version 2.2 Released !
  • This file is Version 2.2 that including iREWORK and iPOWER X Main Software
iREWORK Station Changelogs:
  • Solved bug in settings Memorize that could case software crash
  • Solved chart display bug after press "clear" button (chart did not display from zero time)
  • Solved bug when apply profile option (display different option value on Box)
  • Added more user instant messages while action
  • Added more profile in factory settings
  • Improved Advance settings "Jump" function (This need update box firmware)
  • Improved box response actions
  • Software version update to 2.2
Software Download:
The Following User Says Thank You to .::Gsmdenis::. For This Useful Post:
Old 10-29-2018, 18:42   #3 (permalink)
Member: 79315
Thanks Meter: 6,024
Thumbs up iREWORK Official Version 2.2 Full Installer Released !
iREWORK Official Version 2.2 Full installer Released !
  • Fixed Profile Option display Bugs
Software Download:
Old 11-06-2018, 20:57   #4 (permalink)
Member: 79315
Thanks Meter: 6,024
Arrow iREWORK Official Version 2.3 Full installer Released !
iPOWER X & iREWORK Official Version 2.3 Full installer Released !
  • This file is Version 2.3 that including iREWORK and iPOWER X Main Software
Update Changelogs:
  • Modify the bug that the software can't open on some computers
  • Improve the effectiveness of iPOWER X Box (such as reach the target value of 5 times faster and "ON" button response speed, etc.)
  • Improving iPOWER X input voltage detection
  • Improving iPOWER X output voltage detection
  • Solved more software interface bugs, such as status bar message etc.
  • Change maximum output voltage overvoltage protection limit to 18V
  • Update iPOWER X firmware (user must manually update box through V2.3 software)
  • Software version update to 2.3
Software Download:
  • We recommend all customers to upgrade to this Version, Software is available for all customers with valid to download that from Download Section.
Old 11-18-2018, 13:30   #5 (permalink)
Member: 79315
Thanks Meter: 6,024
Arrow iPOWER X Box Official V2.5 Released !
iREWORK Box Official V2.5 Released !
  • The main software 2.5 which including IREWORK STATION and iPOWER X BOX (English and Chinese version) is now available to all customers.
The changes are here:
  • Add iPOWER X BOX Firmware Version info
  • Update iPOWER BOX Firmware to V4
  • Imporved "POWER" button output standard response time
All customers are encouraged to upgrade to the latest version, The update file required install full installer version 2.3 first, after download the update file you need extract the file to C:/MFC_IRPW folder. and then do box firmware update.
How to upgrade iPOWER X Firmware ?
Old 04-21-2019, 07:08   #6 (permalink)
Member: 79315
Thanks Meter: 6,024
Arrow iREWORK Official Version 3.1 Released !
Update Changelogs:
  • Redesigned iREWORK Main Software interface;
  • Added the option to read box settings and automatically select when iREWORK is connected;
  • Updated iREWORK firmware version to V4 - when select related option (Specially for option 1) and the ESP Data cable is not present that the box will go into waiting mode will start heating;
  • Modify option 2 as the default option;
  • Added the ability to select the graph display line width, the ability to enable or disable the legend and complete load option (if complete load is selected then software will recording all the acquisition data from start time);
  • Added the ability to customize graph channel color;
  • Added display operating state on graph (SHUTDOWN /WORKING /WAITING)
Software Download:
Old 07-24-2019, 17:57   #7 (permalink)
Member: 79315
Thanks Meter: 6,024
Thumbs up iREWORK Official Version 3.2 Released !
We're pleased to announce the release of iREWORK & iPOWER X 3.2.
  • This is a major release with many new exciting features.
All Changelogs listed here:
  • Improved the graphical interface, now iREWORK and iPOWER X interfaces are similar and more intuitive
  • Fixed blocking when using bigger line width of graph
  • Fixed box disconnect issues due to communications errors (Now software will reconnect automatically)
  • Cursors usage has changed. Now just click on the graph two times to select cursors position and measure. (For iPOWER X)
  • Fixed various crashes when 50ms was selected (For iPOWER X)
  • Fixed various selection crash issue while playing recording (For iPOWER X)
  • Markers function changed (Now click on graph first then add markers by using shortcut key )
  • Markers fit problem solved for Chinese characters
  • Software version update to V3.2
  • Box firmware updated to be faster and more accurate
The Following 4 Users Say Thank You to .::Gsmdenis::. For This Useful Post:
Old 07-23-2020, 08:56   #8 (permalink)
Member: 79315
Thanks Meter: 6,024
Arrow MFC Suite 3in1 V3.3 Beta3 Released ! -2020/7/23
Bugfixes & Changes:
  • Improved FDR timeout issue
  • Improved update /restore function under windows 32bit
  • Improved history loading
  • Improved multi same model device operating in same time
  • Added to detect device UDID in recovery mode for the first attach
  • Solved some bugs when closing the software
Updates:
  • After download the update file you need extract the file to c:/mfc folder.
Software Download:
Ps. As this is a major new release with many changes, we'll be going for an extended testing phase. There are also some gui fixes which we'll describe in more detail after the release is out. Please try and report issues in this thread to avoid duplicate support issue.
Old 02-10-2021, 07:27   #9 (permalink)
Member: 79315
Thanks Meter: 6,024
Arrow MFC V3.5 Beta1 Released !- Purple diagnostic function updated 2021/2/10
We're very pleased to announce a new release MFC V3.5 Beta
This has new features and bugfixes:
  • Add Com Port Refresh Function
  • Add All Area /Region syscfg Selection
  • Add Backlight testing function
  • Add read Battery All Data function
  • Add read Device Temperature data / Nand Data function
  • Add test function for Compress / Touch / PhotoSensor / Button etc
  • Improved Backup All syscfg Data function
  • Fixed Write Syscfg backup Data function
  • Fixed Driver install for WTF mode
  • Other small bugs fix
Upgrading to new Versions:
  • This update file required install full installer version 3.4 first, after download the update file you need extract the file to c:/mfc folder. The downloaded version of the software is available now from support page with valid membership.
Dropbox Link V3.4: Download
Dropbox Link V3.5b1: Download
Page generated in 0.27870 seconds with 9 queries
