Back glass replacement Hi, What is the best laser machine for iPhone back glass separating ? Best regards Henrik |
I bought one from REWA. It works great. They have detailed introduction video and after-sales videos support, and that is amazing! |
hi bro nice post i you dont mine please send the video. thank you;) |
thanks for your kindness |
iPhone Back Glass Repair Tips If your back cover glass is accidentally broken, there are two ways to repair it, one is to go to the official after-sales service, and the other is to go to a third-party repair point for repair. 1. Go to the official after-sales service point for maintenance Generally, if your back cover is accidentally broken, if you go to the after-sales service for maintenance, if your display screen and rear camera are no problem, then the after-sales service will replace all accessories except the display screen and rear camera for you. This repair Plans apply to all iPhone 12 series, with repairs ranging from $349 to $599 All after-sales repair shops repair in the same way. They will not replace the back cover glass for you alone. If your iPhone 12 is dropped and the back cover is broken and the screen is also faulty, you can only replace the whole machine. 2. Third-party repair shop Most of the third-party repair shops can replace the rear cover glass, and the price varies according to the quality of the rear cover glass and the way of repair. It should be noted that there are no original accessories for the individually replaced back cover glass. If you need to replace the original back cover, you can only replace the disassembly accessories with the middle frame. 3. How to replace the back cover by a third-party repair shop At present, the mainstream professional repair shops on the market usually use a laser machine to polish the rear cover, and then heat it at a low temperature to remove the damaged glass, remove it and clean it, and then install a new glass. This repair method is the current maintenance method. The least damage to the mobile phone, not only does not need to disassemble and high temperature baking, basically zero damage to the mobile phone. |
best is use manual seperation.....or just buy laser machine |
is it possible to use the heat gun? |
noone try heatgun anyone ? |
