GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Easy 56 Adapter (https://forum.gsmhosting.com/vbb/f1064/)
-   -   problem serial? (https://forum.gsmhosting.com/vbb/f1064/problem-serial-2530411/)
wrsimao 12-10-2018 21:46
problem serial?
hello,
Yesterday coming for me some board to chenge SN, same process another but server for check FMI cant not check more... i find another, genarete id and check put in board sn bt wifi (without FMI)... after finish to put ios his stay locked, i put arround 5 sn without FMI but still locked.... In past week same process is ok... possible apple update somethink?
wrsimao 12-11-2018 00:00
no matter what serial you put it .. every time you try to log the ipad, it still continues with original device serial..
think this machine is die
diabletina 12-11-2018 02:19
It's surely ipad 6 with 64GB nand . unfortenly This nand is not supported with adapter you write serial number but if yoi check your dzvice you will see that's no think happen so in my case i remove nand i write serial with pro3000 or ipbox and all is ok i hope the team will male update for this little bug
wrsimao 12-11-2018 05:51
I find what’s happen.. board is ipad 6 16gb i write new sn bt WiFi without FMI, but after install iOS is continuous show previously SN... I put back in machine and his show correctly SN but when instal iOS don’t change SN..
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.09750 seconds with 6 queries
