GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   HYDRA TOOL (https://forum.gsmhosting.com/vbb/f1065/)
-   -   Blocked Dongles & "Error : LOCKED and NOT USABLE" Post Here (https://forum.gsmhosting.com/vbb/f1065/blocked-dongles-error-locked-not-usable-post-here-2768377/)
DELRO 06-06-2020 01:30
Hydra Update Manager Tool Ver 1.0.1 Build 74
Windows 10 (Version 10.0, Build 18362, 64-bit Edition)
Intel(R) Core(TM) i3-6006U CPU @ 2.00GHz
Intel(R) HD Graphics 520
Ram Installed : 4 GB
Connecting to Hydra Server...
3...Ok
******* Dongle Info *******
Version : Hydra Tool v 1.1
Serial : 191000002568
Initialize : OKAY
Status : Activated
Life : 0-[10-0-0-0-0]
DELRO 06-06-2020 02:07
C:\Users\JEREMY\Desktop\GSM GADGETS\HYDRA\HydraToo_FullPackage_06-03-2020\HMainTool.exe
Current Version : v1.0.0.32
Server Version : v1.0.0.28
---- Release Notes ------
Updated Exe..
#Database moved to DB Folder
Downloads
password : hydratool
ExeOnly
https://drive.google.com/open?id=1Yx...ltXdyv-B9DCCoY
Fullpackage
Link 1: https://drive.google.com/open?id=1xE...H9eLd_rYG8mxIK
Link 2 : https://*******/2WWPJbo
https://s885.photobucket.com/user/de...q6wob.jpg.html
Please update you software without hassle to us
Hydra Tool 06-06-2020 09:27
3...Ok
Initialize : OKAY
Status : Activated
Hello,
Please always use dongle at direct pc hub, do not use at external pc hub, due low voltage your dongle is blocked, and allow 2 times reset dongle, Master ReseT Buton at HumTool (Star Icon) Click it, it will Reset your card, But Please next time be careful to use at direct pc hub.
Best Regards | Hydra Team
desmond2727 06-08-2020 07:32
Windows 7 Service Pack 3 (Version 6.1, Build 7601, 64-bit Edition)
Intel(R) Core(TM) i5-6400 CPU @ 2.70GHz
Intel(R) HD Graphics 530
Server 1 - Other Country...Ok
Version : Hydra Tool v 1.2
Serial : 200600003959
Initialize : OKAY
Status : NOT Activated
Life : 0-[0-0-0-0-0]
ERROR : ACTIVATION KEY NOT AVAILABLE, PLEASE CONTACT PRODUCT
i have problem to active
Hydra Tool 06-08-2020 09:56
Initialize : OKAY
Hello,
Please PM US or contact by telegram app to check your issue.
DELRO 06-10-2020 03:08
Hydra MediaTeK Tool Ver 1.0.1 Build 89
Windows 8.1 (Version 6.3, Build 9600, 64-bit Edition)
Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz
Windows Access Right Admin
Initialize : OKAY
Status : Activated
=========== HYDRA DONGLE ALERT ===============
TAKE NOTE
ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY
PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED
I install it on my PC. but still error. What happen to my dongle? after update to new version i can't use it anymore. i already use the STAR button. You said that direct to PC PORT, i already connect it directly since last time before using the STAR BUTTON. and now i can't use it anymore
Hydra Tool 06-11-2020 09:41
Hello,
Please post screenshot for I can help you,
You can contact us by the Telegram app to check your issue remotely.
DELRO 06-12-2020 01:48
Originally Posted by Hydra Tool (Post 14110495)
Hello,
I Don't Know how to use Telegram, ican't add you either. DELROPD/ DELRO AL. kindly message me.
Much prefer if you have FB messenger so that i can PM you directly
oldcoyoteinc 06-12-2020 11:20
1 Attachment(s)
my dongle is connected directly to the usb port for a long time. this is second time for the same error
Hydra Tool 06-12-2020 15:31
Hello,
Please Run HumTool and click Star Icon (Master Reset) Buton,
If your issue not solved by this process, please pm me for check your issue.
oldcoyoteinc 06-13-2020 13:41
Originally Posted by Hydra Tool (Post 14111639)
Hello,
it does not work on my dongle
Hydra Tool 06-14-2020 18:12
Hello,
Please PM Me to check your issue remotely.
sonsonsy 07-13-2020 23:13
https://ibb.co/SJXd3BN
NO sniffer , direct connected to pc without hub , delete all sys remote files .
i do it read info for note 8 , then close hydra re-run it this message appeared .
i use master reset for first time but same problem .
please make hydra more stable .
please fix my problem
danibutt19 07-24-2020 15:44
Hydra MediaTeK Tool Ver 1.0.1 Build 98
Windows 7 Service Pack 1 (Version 6.1, Build 7601, 64-bit Edition)
Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz
Intel(R) Q35 Express Chipset Family
Serial : 190700001264
Initialize : OKAY
Status : Activated
TAKE NOTE
Why my dongle is blocked i user after a long time and dongle said locked and not usable
Hydra Tool 07-24-2020 17:13
Initialize : OKAY
Status : Activated
TAKE NOTE
Hello,
I just sent you PM, Please check your inbox for check your issue.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.19843 seconds with 6 queries
