GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   HYDRA TOOL (https://forum.gsmhosting.com/vbb/f1065/)
-   -   Blocked Dongles & "Error : LOCKED and NOT USABLE" Post Here (https://forum.gsmhosting.com/vbb/f1065/blocked-dongles-error-locked-not-usable-post-here-2768377/)
Hydra Tool 07-24-2020 17:15
Originally Posted by sonsonsy (Post 14145764)
https://ibb.co/SJXd3BN
NO sniffer , direct connected to pc without hub , delete all sys remote files .
i do it read info for note 8 , then close hydra re-run it this message appeared .
i use master reset for first time but same problem .
please make hydra more stable .
please fix my problem
Hello,
Just send you PM for check your issue remotly, Please check inbox.
Best Regards
FullFlash™ 07-27-2020 08:58
******* Dongle Info *******
Version : Hydra Tool v 1.1
Serial : 190400000635
Initialize : OKAY
Status : Activated
Life : 2-[10-0-0-0-0]
=========== HYDRA DONGLE ALERT ===============
TAKE NOTE
ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY
PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED
Hydra Tool 07-27-2020 09:53
Initialize : OKAY
Status : Activated
TAKE NOTE
Hello,
Just sent you PM, Please check your inbox for check your issue.
Best Regards | Hydra Team
cs55 07-27-2020 10:22
Hydra Qualcomm Tool Ver 1.0.1 Build 98
Windows 10 (Version 10.0, Build 18362, 64-bit Edition)
Intel(R)Core(TM) i3-3110M CPU @ 2.40GHz
Intel(R) HD Graphics 4000
Ram Installed : 6 GB
Windows Access Right Admin
Serial : 191200002886
Initialize : OKAY
Status : Activated
Life : 0-[10-0-0-0-0]
TAKE NOTE
i will send pm.
julius84 08-19-2020 19:50
12:44:34 : Hydra SpreadTrum Tool  Ver 1.0.0 Build 73
12:44:34 : Windows 10 (Version 10.0, Build 18362, 64-bit Edition)
12:44:34 : Intel(R)Core(TM) i7-3537U CPU @ 2.00GHz
12:44:34 : Intel(R) HD Graphics 4000
12:44:34 : Ram Installed : 4 GB
12:44:34 : Windows Access Right Admin
12:44:34 : Software Run As Admnistrator
12:44:35 :
12:44:35 :
12:44:36 : ******* Dongle Info *******
12:44:36 : Version    : Hydra Tool v 1.1
12:44:36 : Serial    : 190300000452
12:44:37 : Initialize : OKAY
12:44:37 : Status    : Activated
12:44:37 : Life      : 0 [6-0-0-1-1]
12:44:37 : Hydra SpreadTrum Tool  Ver 1.0.0 Build 73
12:45:43 : Windows 10 (Version 10.0, Build 18362, 64-bit Edition)
12:45:43 : Intel(R)Core(TM) i7-3537U CPU @ 2.00GHz
12:45:43 : Intel(R) HD Graphics 4000
12:45:43 : Ram Installed : 4 GB
12:45:43 : Windows Access Right Admin
12:45:43 : Software Run As Admnistrator
12:45:45 : ******* Dongle Info *******
12:45:46 : Version    : Hydra Tool v 1.1
12:45:46 : Serial    : 190300000452
12:45:46 : Initialize : OKAY
12:45:46 : Status    : Activated
12:45:46 : Life      : 0 [6-0-0-1-1]
12:45:46 :
12:45:47 :
12:45:47 : *************  PRESS BOOT KEY *************
12:45:47 :  VOL + OR VOL - , OR Combination Vol - +
12:45:47 :  Feature Phone :  Call Button
12:45:47 :  Please hold boot key until second boot..
12:45:47 : *******************************************Found[COM35]
13:01:10 : TPortConnection.Create...(COM35)..Opening...Ok
13:01:10 : SCardTransmit failed with error code 0000045D (The request could not be performed because of an I/O device error.)
13:01:10 : Identifying...
13:01:10 : WriteFile function failed (Error: 433)Failed
13:01:10 : Phone Not Responding
13:01:10 :
13:01:10 : TPortConnection.Destroy.....Closing...Hydra SpreadTrum Tool  Ver 1.0.0 Build 73
13:03:00 : Windows 10 (Version 10.0, Build 18362, 64-bit Edition)
13:03:00 : Intel(R)Core(TM) i7-3537U CPU @ 2.00GHz
13:03:00 : Intel(R) HD Graphics 4000
13:03:00 : Ram Installed : 4 GB
13:03:00 : Windows Access Right Admin
13:03:00 : Software Run As Admnistrator
13:03:02 : ******* Dongle Info *******
13:03:02 : Version    : Hydra Tool v 1.1
13:03:02 : Serial    : 190300000452
13:03:03 : Initialize : OKAY
13:03:03 : Status    : Activated
13:03:03 : Life      : 0 [10-0-0-1-1]
13:03:03 :
13:03:03 :
13:03:03 : *************  PRESS BOOT KEY *************
13:03:03 :  VOL + OR VOL - , OR Combination Vol - +
13:03:03 :  Feature Phone :  Call Button
13:03:03 :  Please hold boot key until second boot..
13:03:03 : *******************************************Found[COM35]
13:05:15 : TPortConnection.Create...(COM35)..Opening...Ok
13:05:16 : =========== HYDRA DONGLE ALERT ===============
13:05:16 : Error    : LOCKED and NOT USABLE
13:05:16 : TAKE NOTE
13:05:16 :    ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY
13:05:16 :    PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED
13:05:16 : Identifying... Failed
13:05:16 : Phone Not Responding
13:05:16 :
13:05:16 : TPortConnection.Destroy.....Closing...Ok..
13:05:16 :
13:05:16 : Elapsed Time : 00:02:13
13:05:16 : Hydra SpreadTrum Tool  Ver 1.0.0 Build 73
13:05:47 : Windows 10 (Version 10.0, Build 18362, 64-bit Edition)
13:05:47 : Intel(R)Core(TM) i7-3537U CPU @ 2.00GHz
13:05:47 : Intel(R) HD Graphics 4000
13:05:47 : Ram Installed : 4 GB
13:05:47 : Windows Access Right Admin
13:05:47 : Software Run As Admnistrator
13:05:48 :
13:05:48 :
13:05:49 : ******* Dongle Info *******
13:05:49 : Version    : Hydra Tool v 1.1
13:05:49 : Serial    : 190300000452
13:05:50 : Initialize : OKAY
13:05:50 : Status    : Activated
13:05:50 : Life      : 0 [10-0-0-1-1]
13:05:50 :
13:05:50 : =========== HYDRA DONGLE ALERT ===============
13:05:50 : Error    : LOCKED and NOT USABLE
13:05:50 : TAKE NOTE
13:05:50 :    ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY
13:05:50 :    PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKEDHydra SpreadTrum Tool  Ver 1.0.0 Build 73
13:47:02 : Windows 10 (Version 10.0, Build 18362, 64-bit Edition)
13:47:02 : Intel(R)Core(TM) i7-3537U CPU @ 2.00GHz
13:47:02 : Intel(R) HD Graphics 4000
13:47:02 : Ram Installed : 4 GB
13:47:02 : Windows Access Right Admin
13:47:02 : Software Run As Admnistrator
13:47:03 :
13:47:03 :
13:47:04 : ******* Dongle Info *******
13:47:04 : Version    : Hydra Tool v 1.1
13:47:04 : Serial    : 190300000452
13:47:05 : Initialize : OKAY
13:47:05 : Status    : Activated
13:47:05 : Life      : 0 [10-0-0-1-1]
13:47:05 :
13:47:06 : =========== HYDRA DONGLE ALERT ===============
13:47:06 : Error    : LOCKED and NOT USABLE
13:47:06 : TAKE NOTE
13:47:06 :    ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY
13:47:06 :    PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED
just happened when i was trying to fix a phone can you unlock it
Hydra Tool 08-20-2020 07:05
12:44:35 :
12:44:35 :
12:45:46 : Life      : 0 [6-0-0-1-1]BLOCKED
Hello,
I sent you a PM, Please check your inbox for check your issue.
osom1234 09-10-2020 19:42
Hydra Qualcomm Tool Ver 1.0.2 Build 14
Windows 10 (Version 10.0, Build 10586, 32-bit Edition)
AMD FX(tm)-8120Eight-Core Processor
AMD Radeon HD 5450
Ram Installed : 3 GB
Serial : 191100002753
Initialize : OKAY
Status : Activated
Life : 0 [10-0-0-0-0]
TAKE NOTE
cecogsm 09-17-2020 09:57
TAKE NOTE
cecogsm 09-17-2020 17:11
18:55:56 : Hydra SpreadTrum Tool Ver 1.0.0 Build 82
18:56:04 : Windows 10 (Version 10.0, Build 19041, 64-bit Edition)
18:56:04 : Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
18:56:04 : NVIDIA GeForce GT 420
18:56:04 : Ram Installed : 8 GB
18:56:04 : Windows Access Right Admin
18:56:06 : ******* Dongle Info *******
18:56:06 : Version : Hydra Tool v 1.1
18:56:06 : Serial : 191100002794
18:56:06 : Initialize : OKAY
18:56:06 : Status : Activated
18:56:06 : Life : 1 [10-0-0-0-0]
18:56:06 :
18:56:07 : =========== HYDRA DONGLE ALERT ===============
18:56:07 : Error : LOCKED and NOT USABLE
18:56:07 : TAKE NOTE
18:56:07 : ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY
18:56:07 : PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED
3cellcare 09-18-2020 08:57
bro full detail not show dongle key ?????????
cecogsm
TAKE NOTE
br
hydra team
cecogsm 09-19-2020 10:08
br
hydra team
18:56:06 :
muddssar 09-20-2020 09:51
please helpe me
13:44:48 : Hydra MediaTeK Tool Ver 1.0.2 Build 3
13:44:48 : Windows 10 (Version 10.0, Build 18362, 32-bit Edition)
13:44:48 : AMD A6 PRO-7400B R5, 6 Compute Cores 2C+4G
13:44:48 : AMD Radeon R5 Series
13:44:48 : Ram Installed : 3 GB
13:44:48 : Windows Access Right AdminHydra MediaTeK Tool Ver 1.0.2 Build 3
13:44:49 : Hydra MediaTeK Tool Ver 1.0.2 Build 3
13:44:49 : Windows 10 (Version 10.0, Build 18362, 32-bit Edition)
13:44:49 : AMD A6 PRO-7400B R5, 6 Compute Cores 2C+4G
13:44:49 : AMD Radeon R5 Series
13:44:49 : Ram Installed : 3 GB
13:44:49 : Windows Access Right Admin
13:44:49 :
13:44:49 :
13:44:50 : ******* Dongle Info *******
13:44:50 : Version : Hydra Tool v 1.1
13:44:50 : Serial : 190900002342
13:44:51 : Initialize : OKAY
13:44:51 : Status : Activated
13:44:51 : Life : 0 [10-0-0-0-0]
13:44:51 :
13:44:53 : =========== HYDRA DONGLE ALERT ===============
13:44:53 : Error : LOCKED and NOT USABLE
13:44:53 : TAKE NOTE
13:44:53 : ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY
13:44:53 : PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED
muddssar 09-20-2020 09:59
any one sulotion hydra dongle team
Hydra Tool 09-21-2020 08:32
13:44:49 :
13:44:49 :
13:44:51 :
Hello,
Sent you a PM, Please check your inbox.
muddssar 09-21-2020 14:10
sir tell me about this problem sir
i hope you help me sir
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.17726 seconds with 6 queries
