my dongle is welldon problem is ok thanks my *** thanks hydra team i am very happy today . thanks good good working team. |
******* Dongle Info ******* Version : Hydra Tool v 1.1 Serial : 191200002860 Initialize : OKAY Status : Activated Life : 0 [10-0-0-0-0] =========== HYDRA DONGLE ALERT =============== Error : LOCKED and NOT USABLE TAKE NOTE ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED ******* Dongle Info ******* Version : Hydra Tool v 1.1 Serial : 191200002860 Initialize : OKAY Status : Activated Life : 0 [10-0-0-0-0] =========== HYDRA DONGLE ALERT =============== Error : LOCKED and NOT USABLE TAKE NOTE ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED master reset or dongle update or registration not solve help plase |
I just sent you pm, please check your inbox for fix your issue. Best Regards | Hydra Team |
thanks hydra team good work my problem solve . |
Hydra team, help please Hydra MediaTeK Tool Ver 1.0.2 Build 14 Windows 10 (Version 10.0, Build 18362, 64-bit Edition) Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz NVIDIA GeForce GT 120 Ram Installed : 16 GB Windows Access Right Admin ******* Dongle Info ******* Version : Hydra Tool v 1.1 Serial : 190300000396 Initialize : OKAY Status : Activated Life : 1 [10-0-0-0-0] =========== HYDRA DONGLE ALERT =============== Error : LOCKED and NOT USABLE TAKE NOTE ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED I ALREADY UPDATED, CHANGED PC, REINSTALLED FRESH WINDOWS, DIRECT CONNECTED TO PC USB PORT, UPDATED MODULES USING HUM TOOL, INSTALLED DRIVERS FROM SUPPORT, FIXED PC DATE & TIME, UPDATED DATA BASE, I DON'T USE VPN, BUT PROBLEM REMAINS UNSOLVED. |
Hello, I just sent you a pm, please check your inbox. Best Regards | Hydra Team |
Very very quick response from hydra team Problem solved. Thank you so much HYDRA DONGEL TEAM. Problem solved in few minutes. Hats OFF |
No activate help no activate Hydra Update Manager Tool Ver 1.0.1 Build 91 Windows 10 (Version 10.0, Build 19041, 64-bit Edition) Intel(R) Core(TM) i5-9400F CPU @ 2.90GHz AMD Radeon HD 7900 Series Ram Installed : 8 GB Windows Access Right Admin Software Run As Admnistrator Connecting to Hydra Server...3...Ok ******* Dongle Info ******* Version : Hydra Tool v 1.2 Serial : 200800007374 |
https://forum.gsmhosting.com/vbb/f10...ution-2880398/ |
******* Dongle Info ******* Version : Hydra Tool v 1.1 Serial : 190600001112 Initialize : OKAY Status : Activated Life : 0 [10-0-0-0-0] =========== HYDRA DONGLE ALERT =============== Error : LOCKED and NOT USABLE TAKE NOTE ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED |
Just send you a pm, please check your inbox. Best Regards | Hydra Team |
what's the problem my hydra dongle just windows my pc what's the problem my hydra dongle just windows my pc plz solved this problem Hydra Update Manager Tool Ver 1.0.1 Build 89 Windows 10 (Version 10.0, Build 18362, 64-bit Edition) Intel(R) Core(TM) i5-9400 CPU @ 2.90GHz Intel(R) UHD Graphics 630 Ram Installed : 8 GB Windows Access Right Admin Connecting to Hydra Server...3...Ok ******* Dongle Info ******* Version : Hydra Tool v 1.2 Serial : 200800007048 =========== HYDRA DONGLE ALERT =============== Error : PC TIME ERROR TAKE NOTE ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED |
Hello, You have the PC TIME issue, Quote:
Hydra Update Manager Tool Ver 1.0.1 Build 89 Windows 10 (Version 10.0, Build 19041, 64-bit Edition) Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz Intel(R) HD Graphics Ram Installed : 8 GB Windows Access Right Admin Connecting to Hydra Server...3...Ok ******* Dongle Info ******* Version : Hydra Tool v 1.1 Serial : 190600001187 Initialize : OKAY Status : Activated Life : 0 [10-0-0-0-0] |
Hydra Update Manager Tool Ver 1.0.1 Build 95 Windows 8.1 (Version 6.3, Build 9600, 64-bit Edition) AMD Athlon(tm) II X4 640 Processor AMD Radeon HD 5500 Series Ram Installed : 8 GB Windows Access Right Admin Software Run As Admnistrator Connecting to Hydra Server...Server 2 - Other Country...Ok ******* Dongle Info ******* Version : Hydra Tool v 1.1 Serial : 191000002550 Initialize : OKAY Status : Activated Life : 0 [10-0-0-0-0] =========== HYDRA DONGLE ALERT =============== Error : LOCKED and NOT USABLE TAKE NOTE ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED NOT USING ANY USB HUB , MASTER RESET , ANY USB SNIFFERS STILL THE SAME |
