Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #61 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2015 Location: Pakistan Panjab in Dahranwala
Member: 2441094 Status: Offline Thanks Meter: 54 | my dongle is welldon problem is ok |
The Following User Says Thank You to muddssar For This Useful Post: |
![]() | #62 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2006 Location: Türkiye
Member: 395431 Status: Offline Thanks Meter: 453 | ******* Dongle Info ******* Version : Hydra Tool v 1.1 Serial : 191200002860 Initialize : OKAY Status : Activated Life : 0 [10-0-0-0-0] =========== HYDRA DONGLE ALERT =============== Error : LOCKED and NOT USABLE TAKE NOTE ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED ******* Dongle Info ******* Version : Hydra Tool v 1.1 Serial : 191200002860 Initialize : OKAY Status : Activated Life : 0 [10-0-0-0-0] =========== HYDRA DONGLE ALERT =============== Error : LOCKED and NOT USABLE TAKE NOTE ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED master reset or dongle update or registration not solve help plase |
![]() | #63 (permalink) | |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2018 Location: Ukraine / Harkov
Member: 2857401 Status: Offline Thanks Meter: 6,432 | Quote:
I just sent you pm, please check your inbox for fix your issue. Best Regards | Hydra Team | |
The Following User Says Thank You to Hydra Tool For This Useful Post: |
![]() | #65 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2011 Location: Ujmair Mobiles Hassanabdal Age: 36
Member: 1520256 Status: Offline Sonork: 100.1612582 Thanks Meter: 137 | Hydra team, help please Hydra MediaTeK Tool Ver 1.0.2 Build 14 Windows 10 (Version 10.0, Build 18362, 64-bit Edition) Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz NVIDIA GeForce GT 120 Ram Installed : 16 GB Windows Access Right Admin ******* Dongle Info ******* Version : Hydra Tool v 1.1 Serial : 190300000396 Initialize : OKAY Status : Activated Life : 1 [10-0-0-0-0] =========== HYDRA DONGLE ALERT =============== Error : LOCKED and NOT USABLE TAKE NOTE ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED I ALREADY UPDATED, CHANGED PC, REINSTALLED FRESH WINDOWS, DIRECT CONNECTED TO PC USB PORT, UPDATED MODULES USING HUM TOOL, INSTALLED DRIVERS FROM SUPPORT, FIXED PC DATE & TIME, UPDATED DATA BASE, I DON'T USE VPN, BUT PROBLEM REMAINS UNSOLVED. |
![]() | #66 (permalink) | |
Hello, I just sent you a pm, please check your inbox. Best Regards | Hydra Team | |
![]() | #67 (permalink) |
Member: 1520256 Status: Offline Sonork: 100.1612582 Thanks Meter: 137 | Very very quick response from hydra team Problem solved. Thank you so much HYDRA DONGEL TEAM. Problem solved in few minutes. Hats OFF |
The Following 2 Users Say Thank You to aliburhan1 For This Useful Post: |
![]() | #68 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2011
Member: 1643137 Status: Offline Sonork: josemetal123 Thanks Meter: 9 | ![]() help no activate Hydra Update Manager Tool Ver 1.0.1 Build 91 Windows 10 (Version 10.0, Build 19041, 64-bit Edition) Intel(R) Core(TM) i5-9400F CPU @ 2.90GHz AMD Radeon HD 7900 Series Ram Installed : 8 GB Windows Access Right Admin Software Run As Admnistrator Connecting to Hydra Server...3...Ok ******* Dongle Info ******* Version : Hydra Tool v 1.2 Serial : 200800007374 |
![]() | #69 (permalink) | |
https://forum.gsmhosting.com/vbb/f10...ution-2880398/ | |
![]() | #70 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2017 Location: Ukraine
Member: 2750401 Status: Online Thanks Meter: 134 | ******* Dongle Info ******* Version : Hydra Tool v 1.1 Serial : 190600001112 Initialize : OKAY Status : Activated Life : 0 [10-0-0-0-0] =========== HYDRA DONGLE ALERT =============== Error : LOCKED and NOT USABLE TAKE NOTE ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED |
![]() | #71 (permalink) | |
Just send you a pm, please check your inbox. Best Regards | Hydra Team | |
![]() | #72 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2010 Location: Bangladesh
Member: 1292009 Status: Offline Sonork: 100.1586379 Thanks Meter: 802 | what's the problem my hydra dongle just windows my pc what's the problem my hydra dongle just windows my pc plz solved this problem Hydra Update Manager Tool Ver 1.0.1 Build 89 Windows 10 (Version 10.0, Build 18362, 64-bit Edition) Intel(R) Core(TM) i5-9400 CPU @ 2.90GHz Intel(R) UHD Graphics 630 Ram Installed : 8 GB Windows Access Right Admin Connecting to Hydra Server...3...Ok ******* Dongle Info ******* Version : Hydra Tool v 1.2 Serial : 200800007048 =========== HYDRA DONGLE ALERT =============== Error : PC TIME ERROR TAKE NOTE ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED |
![]() | #73 (permalink) | ||
Hello, You have the PC TIME issue, Quote:
Best Regards | Hydra Team | ||
![]() | #74 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2009 Location: dhaka,uttara
Member: 962829 Status: Offline Thanks Meter: 51 | Hydra Update Manager Tool Ver 1.0.1 Build 89 Windows 10 (Version 10.0, Build 19041, 64-bit Edition) Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz Intel(R) HD Graphics Ram Installed : 8 GB Windows Access Right Admin Connecting to Hydra Server...3...Ok ******* Dongle Info ******* Version : Hydra Tool v 1.1 Serial : 190600001187 Initialize : OKAY Status : Activated Life : 0 [10-0-0-0-0] |
![]() | #75 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2016 Location: GSMPIONEER PHP
Member: 2623988 Status: Offline Sonork: 100.1678253 Thanks Meter: 226 | Hydra Update Manager Tool Ver 1.0.1 Build 95 Windows 8.1 (Version 6.3, Build 9600, 64-bit Edition) AMD Athlon(tm) II X4 640 Processor AMD Radeon HD 5500 Series Ram Installed : 8 GB Windows Access Right Admin Software Run As Admnistrator Connecting to Hydra Server...Server 2 - Other Country...Ok ******* Dongle Info ******* Version : Hydra Tool v 1.1 Serial : 191000002550 Initialize : OKAY Status : Activated Life : 0 [10-0-0-0-0] =========== HYDRA DONGLE ALERT =============== Error : LOCKED and NOT USABLE TAKE NOTE ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED NOT USING ANY USB HUB , MASTER RESET , ANY USB SNIFFERS STILL THE SAME |
