Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GSMFABRICA Products > HYDRA TOOL
Old 12-05-2023, 10:37   #1 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 1,037
Dogle life 0 HYDRA Security Dongle Alert! [SOLVED]
I just try to use Hydra tool to flash an Mi 8 [ Deeper ] via Fastboot ( bootloader unlocked ). But:
Hydra Tool  Ver 2023.12.5.0
Windows 10 (Version 22H2, OS Build 19045.3693, 64-bit Edition)
AMD Ryzen 7 ... 8-Core Processor
AMD Radeon RX ...
Ram Installed : 32 GB
Windows Access Right : Admin
Software Run As Admnistrator
******* Dongle Info *******
Version    : Hydra Tool v 1.1
Serial     : 190300000561
Initialize : OKAY
Status     : Activated
Life       : 0 [10-0-0-0-0]
And nothing work, reset time, initialize dongle, update also:
=          U P D A T E  F I R M W A R E             =
Searching for Hydra Dongle . . .
Found : 74070100
=========== HYDRA Security Dongle Alert!!! ===========
ERROR    : LOCKED and NOT USABLE
TAKE NOTE
    ATTEMPT TO PLAYDONGLE/SEND WRONG INITKEY
    PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED [190300000561]
ERROR : NOT ALLOWED TO UPDATE
Probably due to wrong date on PC when started it, but even correct it to real one - same.
Changed USB port, removed other dongles - nothing
Any advice from developers?
BR, DebeliaMark, BG
Old 12-05-2023, 10:44   #2 (permalink)
Techy147's Avatar
Member: 2331209
Thanks Meter: 2,928
Hello , please click firmware update in configuration tab. you have 30 mins to do the card update.
Old 12-05-2023, 10:54   #3 (permalink)
Member: 4627
Thanks Meter: 1,037
tnx.
It work.
Activating Hyda Dongle [SUCCESSFULLY ACTIVATED]
Version    : Hydra Tool v 1.3
Initialize : OKAY
Status     : Activated
Life       : 0 [0-0-0-0-0]
Activating Module...
  - Main....> Ok
  - MediaTek....> Ok
  - Qualcomm....> Ok
  - Unisoc....> Ok
  - Propack One....> ERROR: PROPACK1 Module Not Activated, Please contact reseller for activation.
Done!!!
Updating Modules...
  - Main.... > Ok
  - MediaTek.... > Ok
  - Qualcomm.... > Ok
  - Unisoc.... > Ok
  - Propack One.... > ERROR: PROPACK1 Module Not Activated, Please contact reseller for activation.
Done!!
UPDATE DONE!!!!
Old 12-06-2023, 03:39   #4 (permalink)
Crazy Poster
Member: 1288857
Thanks Meter: 14
Hydra Tool  Ver 2023.12.6.0
Windows 10 (Version 1909, OS Build 18363.476, 64-bit Edition)
Intel(R) Core(TM) i3-6100U CPU @ 2.30GHz
AMD Radeon (TM) R5 M330
Ram Installed : 4 GB
Serial     : 190100000119
Initialize : OKAY
Status     : Activated
Found : 43350100
TAKE NOTE
    PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED [190100000119]
Old 06-25-2024, 15:41   #5 (permalink)
Member: 164422
Thanks Meter: 24
hydra security alert
Hydra Tool Ver 2024.6.18.1
Windows 10 (Version 22H2, OS Build 19045.4529, 64-bit Edition)
Intel(R) Core(TM) i5-7200U CPU @ 2.50GHz
Intel(R) HD Graphics 620
Ram Installed : 8 GB
Serial : 190300000595
Initialize : OKAY
Status : Activated
Found : 48070000
TAKE NOTE
PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED [190300000595]
Old 06-26-2024, 05:57   #6 (permalink)
Techy147's Avatar
Member: 2331209
Thanks Meter: 2,928
Initialize : OKAY
Status : Activated
Found : 48070000
TAKE NOTE
Hello please check your Inbox
Old 06-26-2024, 06:30   #7 (permalink)
Member: 164422
Thanks Meter: 24
hi i checked my inbox but i dnt see any mails.i tried updating today as well but same error.
Old 06-27-2024, 12:08   #8 (permalink)
Member: 104946
Thanks Meter: 33
Intel(R) Core(TM) i5-8265U CPU @ 1.60GHz
Intel(R) UHD Graphics 620
Ram Installed : 16 GB
Serial : 190400000673
Initialize : OKAY
Status : Activated
PreOperation Configuration
Brand : AUTO Model : AUTO Storage : Auto
Loader: Auto
Port : Auto
Searching for Qualcomm 9008 Device...Found
FriendlyName :Qualcomm HS-USB QDLoader 9008 (COM6)
SymbolicName :\\?\usb#vid_05c6&pid_9008#6&18ed4e32&1&4#{a5dcbf1 0-6530-11d2-901f-00c04fb951ed}
Driver Ver :05/29/2019,2.1.3.7
TAKE NOTE
Access violation at address 001B851A in module 'HydraTool.exe'. Write of address 00000003
Elapsed Time : 00:00:00
Old 06-27-2024, 17:03   #9 (permalink)
Member: 104946
Thanks Meter: 33
Mr Techy147 !Please check! i have the same problem! pm already to You!
Page generated in 0.20620 seconds with 8 queries
