Honor 20i (HRY-AL00TA) Frp Remove How to Remove FRP Huawei Kirin 710 and 980 by USB1 Testpoint (Note - You can use Harmony Cable directly so no need to dismantle device) 1. Disassemble your device and connect device using Test point. 2. You can find Testpoint at Help / Testpoint Area. 3. Your pc will attached COM 1.0 Driver, for Drivers you can check Hydra Tool Folder. 4. Run Main Module and from top select Hisilicon Tab. 5. Then from drop down menu in Service tab select Factory Boot. 6. Click on Initialize Factory mode and Hit Execute. 7. Once in Factory mode Goto Partition Manager Tab and select Factory/USB 1 and click Partitions. 8. Once the partitions are listed Backup Certification and oeminfo. 9. After backup successfull again goto to Service tab and from drop down select Factory Reset Protrection/Account and hit Execute. |
