Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GSMFABRICA Products > HYDRA TOOL
Old 01-13-2022, 07:48   #1 (permalink)
Member: 311347
Sonork: 100.1672192
Thanks Meter: 486
Honor 20i (HRY-AL00TA) Frp Remove
How to Remove FRP Huawei Kirin 710 and 980 by USB1 Testpoint
(Note - You can use Harmony Cable directly so no need to dismantle device)
1. Disassemble your device and connect device using Test point.
2. You can find Testpoint at Help / Testpoint Area.
3. Your pc will attached COM 1.0 Driver, for Drivers you can check Hydra Tool Folder.
4. Run Main Module and from top select Hisilicon Tab.
5. Then from drop down menu in Service tab select Factory Boot.
6. Click on Initialize Factory mode and Hit Execute.
7. Once in Factory mode Goto Partition Manager Tab and select Factory/USB 1 and click
Partitions.
8. Once the partitions are listed Backup Certification and oeminfo.
9. After backup successfull again goto to Service tab and from drop down select Factory
Reset Protrection/Account and hit Execute.
The Following 2 Users Say Thank You to gsmkolik For This Useful Post:
Page generated in 0.11723 seconds with 8 queries
