01-16-2021, 06:13 | #1 (permalink) | |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | How to Install Hydra driver, run its Applications & facing problem while installing How to Install Hydra driver, run its Applications (Main, SPD, MTK, Qualcomm) & facing problems while installing 1. Download Alcor driver and install. Quote:
2. Connect Hydra Dongle and install its driver properly. 3. Download Hydra software and install ( Download Full Package): 4. Download all MTK, SPD, Qualcomm, Pre-loader and CDC Drivers and install them before we plug the device (Cellphone / Device) 5. Run Hydra HUM Tool. (If you get problem to run it, re-download it and run it again.) 6. You need to connect internet to register Hydra Tool. Please connect it before start registration. 7. Click on registration icon on the left column (MAN icon) 8. Fill your registration information like Name, Email, Password, country etc. 9. Click on "Activation" . After this, check the message "Activation is success!" 10. Update "DB" (Update database only), Update All and Update Module Files if necessary from top left side of HUM Tool. 11. Run Application MTK, SPD, Qualcomm etc. from left column (Crocodile / Alligator icon) 12. Update DB (Database) of each application bottom down (db icon). 13. If you face any problem something like .dll missing, install Visual Basic Run Time File : 13. Start Earning! Good Luck! BR Dipendra Pathak | |
The Following 7 Users Say Thank You to Dipendra Pathak For This Useful Post: |
01-19-2021, 04:02 | #2 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | How can I know about Server status of Xiaomi Devices How can I know about Server status of Xiaomi Devices (Cellphone/mobile) visit the link below: Note: Hydra Server will not reply if your phone has "Find Device On". That means, device only works if the status of "Find my device" is off status. |
01-19-2021, 04:06 | #3 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | Eltima Software Application Detected If "Eltima software application" is detected by Hydra Tool, you have to remove it manually. Otherwise you can not run Hydra Dongle. How to remove Eltima software ? Check the link below for this: You must do little bit exercise or you have to call technical support to remove such a malware to remove from PC. Good Luck! BR Dipendra Pathak |
01-19-2021, 04:16 | #4 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | Attempt to playdongle/send wrong initkey please stop or else your dongle will be bloc ATTEMPT TO PLAY DONGLE/SEND WRONG INITKEY, PLEASE STOP OR ELSE YOUR DONGLE WILL BE BLOCKED 1. This sometimes happns if your Computer time is not properly set up. So, check your computer /laptop date and time properly before you run Hydra Tool. 2. This might be using such a software that tries to find Hydra Securities. or other reason. We request you, do not use such software or application else you loose your dongle forever. If the reason is good or it blocked without unknown reason, you can post here to unlock/unblock the dongle: Quote:
The Following 3 Users Say Thank You to Dipendra Pathak For This Useful Post: |
01-20-2021, 05:32 | #5 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | Error....Application freezes.........."Please Update Database" Error.....Application freezes........."Please Update Database" Sometimes application (MTK, SPD, Qualcomm module etc.) freezes and it does not function. For this you have to update data base (DB). You can update data base (DB) two ways : 1. You can update data base from Hydra Humtool from where you had registered the Hydra Tool. Update "DB" (Update database only), Update All and Update Module Files if necessary from top left side of HUM Tool. 2. You can update data base from each application (MTK, Qualcomm, SPD etc applications). Update DB (Database) of each application bottom down DB icon. BR Dipendra Pathak Last edited by Hydra Tool; 01-20-2021 at 07:57. |
01-24-2021, 04:11 | #6 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | You can reach and know everything of Hydra Tool yourself - we are transparent! You can reach and know everything of Hydra Tool yourself - we are transparent! What is hydra Tool - visit the hyper link: Modules Hydra tool supports - visit the hyper link: Brands Hydra tool supports - visit the hyper link: Downloading Hydra Software - visit the hyper link: Manual of Hydra Tool - visit this hyper link: Drivers of Hydra Tool - visit the hyper link: Hydra Face Book site - visit the hyper link: Support of Hydra Tool - visit the hyper link: Reseller of hydra Tool - visit the hyper link: More support? you can send private message, e-mail to the supporters, managers etc. They love and ready to help you 7 days and 24 hours. BR Dipendra Pathak |
The Following User Says Thank You to Dipendra Pathak For This Useful Post: |
01-26-2021, 15:16 | #7 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | How to fix Camera, BT, Wifi e.t.c with Hydra Tool How to fix Camera, BT, Wifi e.t.c with Hydra Tool Just flash "Presist" and "presistbak" files manually to fix Camera, Bluetooth, wifi etc. just like below : Screen Short: Note: This is an example of repairing camera, bluetooth, wifi etc. of Redmi Note6 pro (tulip) device. BR Dipendra Pathak |
01-26-2021, 15:40 | #8 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | What should I do, if program is not run, respond or can not upgrade data base (DB) ? What should I do, if program is not run, respond or can not upgrade data base (DB) ? You can turn off windows firewall and antivirus before run any program. 1. Turn off windows firewall and network protection a) Domain network - OFF, b) Private network- OFF, c) Public network - OFF, 2. Windows security a) Virus ad Thread protection - OFF, b) Firewall and network protection- OFF, 3. Microsoft defender firewall- OFF 4. Antivirus (All types) - OFF BR Dipendra Pathak |
01-28-2021, 15:58 | #9 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | can't download file from support area of Hydra Tool? Can't download file from support area of Hydra Tool? This is not a problem or issue. You need to do "double click" to download the file. BR Dipendra Pathak |
01-28-2021, 16:06 | #10 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | faced or Got error such as "Excuting Exploit..." If you faced an error such as "Excuting Exploit..." The minimum requirement to run Hydra Tool is to install windows 7 with SP 2. If you are using windows 7 with SP (Service Pack 1), you will face error such as "Executing Exploit" etc. So, we recommend you to install windows 10 or equivalent of this. BR Dipendra Pathak |
The Following 2 Users Say Thank You to Dipendra Pathak For This Useful Post: |
01-29-2021, 03:40 | #11 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | Does not match the Preloader (Preloader Initialization... Parsing preloader.......) Does not match the Preloader (Preloader Initialization... Parsing preloader.......) If you see such message like Preloader Initialization... Parsing preloader....... This is not the problem of Hydra Tool. This is mismatch of Preloader. You can get the preloader from the device's firmware. That means you need to download the flash file of particular device (cellphone/mobile) firmware and extract the preloader from the firmware and use the preloader using our Hydra Tool. Good Luck! BR Dipendra Pathak |
01-31-2021, 15:47 | #12 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | How to take device into meta mode or Broom Mode? How to take device into meta mode/ Broom Mode? 1. Press and hold + (plus) volume button and - (minus) volume button together and insert USB cable into device (Cellphone / Mobile). 2. You can see Meta mode on device screen. Good Luck! |
02-01-2021, 14:56 | #13 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | How to take device into Preloader mode? How to take device into Preloader mode? Just insert the USB cable to the device (Cellphone / mobile) |
02-01-2021, 15:41 | #14 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | How to Enable FastBoot Mode of any device How to Enable FastBoot Mode of any device 1. Power of / Turn off device (cellpone / mobile) 2. Press Volume Plus (+) and Power button together 3. Hole it On few second. That's All. Note: You can disable fastboot mode just pressing power button 15 seconds. |
02-10-2021, 03:45 | #15 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | Solution for "Please filter the device.....and run exploid again". Solution for "Please filter the device.....and run exploid again". 1. Please tick "Enable BROM exploit" on the top near Auto Loader. Do not forget this one. 2. Second step is not (don't) to disconnect device (cellphone /mobile) from computer or laptor (PC), and notice that is detected as "MTK Preloader Device(or MTK USB Port)". 3. Now, go to the folder--> Hydratool/lib/libusb filter installer. 4. Install it and open it as for filter device. 5. Select MTK USB port once again. 6. And close it. 7. Reconnect the device (cellphone / mobile) once again and try. 8. Good Luck! BR Dipendra Pathak |
The Following 6 Users Say Thank You to Dipendra Pathak For This Useful Post: |
