Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GSMFABRICA Products > HYDRA TOOL
Old 09-05-2019, 07:45   #31 (permalink)
vetalcik's Avatar
Member: 358052
Thanks Meter: 80
When to expect stable server operation? It always does not work. You want to make a paid basis, but will the server work better than now? Thank.
Old 09-05-2019, 08:33   #32 (permalink)
Hydra Tool's Avatar
Member: 2857401
Thanks Meter: 6,861
Hello,
Just Xiaomi Authorized Server are Off,
We will try to up it as soon as possible.
Hydra Team
The Following 3 Users Say Thank You to Hydra Tool For This Useful Post:
Old 09-08-2019, 07:23   #33 (permalink)
Crazy Poster
Member: 201598
Thanks Meter: 3
update for this issue pls
Old 09-12-2019, 11:27   #34 (permalink)
Member: 164422
Thanks Meter: 24
redmi 7 mi account unlock
i have a redmi 7 mi account lock but allways getting this error and cannot unlock.seems ur server problem.
Hydra Qualcomm Tool Ver 1.0.1 Build 32
Windows 7 Service Pack 1 (Version 6.1, Build 7601, 32-bit Edition)
Intel(R)Core(TM) i5-2430M CPU @ 2.40GHz
Ram Installed : 2.74 GB
******* Dongle Info *******
Version : Hydra Tool v 1.1
Serial : 19030
Initialize : OKAY
Status : Activated
Selected Comport : Auto
Selected Loader : Auto
Searching Qualcomm 9008 Port[FOUND](COM3)
Getting device info..
Device MODE : SAHARA
Connecting to Firehose...
Ping.. Ok
Configuration.
Xiaomi Authentication needed...
Signature Request -> blob[AQAAAF0BAADc9yt-P1pS9VZmKhZN2CB5zN-V4g]
Hydra Xiaomi Server...
Waiting for server response....................
Server not responding..., please try again later
Unable to generate authkey...Failed
Running : Failed
Device is not in Firehose Mode
Elapsed Time : 00:32:15
Old 09-12-2019, 13:40   #35 (permalink)
Member: 2637068
Thanks Meter: 276
Update New
New More Update pls
Old 09-13-2019, 08:57   #36 (permalink)
Member: 450402
Thanks Meter: 14
redmi note 5 pro whyred no frp no flash always asking server not authorise
Old 09-13-2019, 11:07   #37 (permalink)
Hydra Tool's Avatar
Member: 2857401
Thanks Meter: 6,861
Please always select brand and model and for help post the screen shot.
Hydra Team
Old 09-14-2019, 03:17   #38 (permalink)
Member: 2077370
Sonork: 100.1616788
Thanks Meter: 268
Redmi note 7s mi ac other shop keeper flash redmi note 7 pro file set dead and after flash note 7 file baseband unknown what to do
I flash with note 7 file lavander india ver and globle ver but same basebend unknown
also i write qcn file but set not on proper go to recovry and show nv data crupt then again flash with hydra dongle set on but basebend unknown
Sent from my Lenovo A7020a48 using Tapatalk
Old 09-14-2019, 08:53   #39 (permalink)
ceza031's Avatar
Member: 1724862
Thanks Meter: 448
note 7 mi account not possible by any tool, its relased by android 9 version,
for fix unknown baseband when flash by hydra untick skip security partitions
Old 09-14-2019, 13:55   #40 (permalink)
Member: 2637068
Thanks Meter: 276
Lyf F120B Format Done
Intel(R) Celeron(R) CPU G550T @ 2.20GHz
Ram Installed : 3.372 GB
Serial     : 190300000278
Initialize : OKAY
Status     : Activated
Searching Qualcomm 9008 Port[FOUND](COM23)
Getting device info.......
Serial No.: 0x13A37793
MSM ID    : 0x000940E1
PBL Ver   : 00000000
PK HASH   : 911B8F01C36F8A876A5C0A75595102EE
            09708CA73EA62AFBE301C0110307CEC6
Firehose Loader[prog_emmc_firehose_8909_ddr_1.mbn]
Sending ..............Ok
Ping... Ok
Configuration......Ok
Chip Configuration :
 MemoryName : eMMC
 MaxPayloadSizeToTargetInBytes : 1048576
 MaxPayloadSizeToTargetInBytesSupported : 1048576
 MaxPayloadSizeFromTargetInBytes : 4096
 MaxXMLSizeInBytes : 4096
 TargetName : 8909
 Version : 1
Running : Ok
Phone Information.....
Model       	:	F120B
Brand       	:	LYF
Android Ver 	:	6.0.1
Manufacturer	:	Jio
Device      	:	msm8909_512
Board       	:	msm8909
Display ID  	:	LYF-F120B-001-02-16-080419
Security Patch  	:	xxxx-xx-xx
Platform    	:	msm8909
Kernel ID    	:	xxxx-xx-xx
FRPPST   	:	/dev/block/bootdevice/by-name/config
Formatting Userdata...
Format Safe method Ok
Format Done!!
All Done
Old 09-14-2019, 14:25   #41 (permalink)
Member: 164422
Thanks Meter: 24
not happy hydra team
Serial : 19030
Initialize : OKAY
Status : Activated
Ping.. Ok
Configuration.
Running : Failed
so far i never had any success with hydra dongle.i bought it with lot of hopes.but all the mobiles i tried failed.including oneplus 5t imei repair
Old 09-16-2019, 10:18   #42 (permalink)
oldcoyoteinc's Avatar
Member: 204211
Thanks Meter: 41
mi 8 lite (platina) needs authentication but you said that doesn't need
The Following User Says Thank You to oldcoyoteinc For This Useful Post:
Old 09-16-2019, 14:16   #43 (permalink)
Hydra Tool's Avatar
Member: 2857401
Thanks Meter: 6,861
Hello,
Its doesnt need auhtorized server, if you are select brand and model,
if you got any error please open new a theread with screen shot and logs,
then we will try help you and more understand the issue,
if you need guides you can check Guides & Helps Folder at Hydra Support Area folder.
Hydra Team
The Following 2 Users Say Thank You to Hydra Tool For This Useful Post:
Old 09-21-2019, 20:30   #44 (permalink)
Member: 450402
Thanks Meter: 14
Hydra tool is not proper setup system its a poor setup
Old 09-24-2019, 08:58   #45 (permalink)
vetalcik's Avatar
Member: 358052
Thanks Meter: 80
Lenovo TB-X304 LTE FRP ERROR
Page generated in 0.21524 seconds with 9 queries
