05-10-2021, 19:31 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Albania,City Under The Castle Age: 47
Member: 388033 Status: Offline Thanks Meter: 693 | Redmi 9 Cattail Not boot correctly [SOLVED] Windows 10 (Version 10.0, Build 19042, 64-bit Edition) Intel(R) Core(TM) i5 CPU 660 @ 3.33GHz Intel(R) HD Graphics Ram Installed : 4 GB Windows Access Right Admin Software Run As Admnistrator ******* Dongle Info ******* Version : Hydra Tool v 1.1 Serial : 190300000564 Initialize : OKAY Status : Activated Life : 2 [0-0-0-0-0] ===================================== Searching for MTK Device...Found Port Identification :Flashmode BROM FriendlyName :MediaTek USB Port (COM33) Device :6&23c67e70&0&5 SymbolicName :\??\USB#VID_0E8D&PID_0003#6&23c67e70&0&5#{a5dcbf1 0-6530-11d2-901f-00c04fb951ed} Driver Ver :01/22/2015,3.0.1504.0 Handshaking...Ok Identifying Hardware ID..... Reading Device hardware info.. hw code : 0766MT6765 [6765] hw subcode : 8A00 hw version : CA00 sw version : 0000 Target config : E7 SB : 01 (True) SLA : 02 (True) DAA : 04 (True) Exploiting Device... Successfully Exploited... Handshaking...Ok Identifying Hardware ID..... Reading Device hardware info.. hw code : 0766MT6765 [6765] hw subcode : 8A00 hw version : CA00 sw version : 0000 Target config : 00 SB : 00 (False) SLA : 00 (False) DAA : 00 (False) FUSEID : 00000000 SECURE VERSION : 05 BL VERSION : FE NORMAL BOOT Preparing Download Agent.. DA : 6765_Xiaomi_wb.bin Agent: MTK_DOWNLOAD_AGENT -HYDRA Ver : MTK_AllInOne_DA_v3.3001.2020/03/17.ÉIIç10:04_497508 Init : Loader [1] Sending : Accepted Identifying Protocol... Protocol : New Synchronization...[ERROR]- NOT SYNC ============================================= Reasons why it fails due to the following" 1. Harware problem/issues 2. If you did Testpoint Kindly check the parts you Touch/TP 3. Powershortage, try to connect Battery 4. Check or replace usb cable and plug directly to your pc usb port. ============================================= SYNC Mode : brom Preloader Initialization... Parsing preloader_k65v1_64_bsp_cattail.bin PREL FILE NOT FOUND Elapsed Time : 00:00:11 |
