Hydra Tool MTK Module v1.0.3.30 [06.05.2021] - Mediatek Overtake Hydra Tool MTK Module v1.0.3.30 https://i.imgyukle.com/2021/05/05/Os8p7s.png [Added] - BROM Port-Dump Preloader Flash Init. *This function will fix booting issue, if assigned or automatic preloader is Denied during booting. [Added] - BROM Port-Dump Bootrom (Method 1 and Method 2) *For advanced user, analysis of bootrom [Added] - BROM Port-Brom exploit ByCpu Payload and Universal/Generic Payload [Added] - OPPO Android 11 / UFS 5G Chips Factory Reset [Fixed] - Protocol Supported Socs Brom Exploit (MT6261,MT6572,MT6580,MT6582,MT6735,MT6737,MT6739, MT6753, MT6755,MT6757,MT6761,MT6763,MT6765,MT6768,MT6771,M T6779, MT6785,MT6795,MT6797,MT6799,MT6873,MT6885,MT8127,M T8163,MT8173,MT8516,MT8695) Added Following Models "Without Auth" BROM Mode by USB
Added Following Huawei Models by USB or Testpoint Operations Read/Write Firmware, Repair IMEI, Reset FRP, Remove Huawei ID, Factory Reset(Format), Read/Write Dump, Partition Manager
Added OPPO Factory Reset for Following Models by USB Meta Mode
Added Following Models for Flash Mode Operations by USB Read/Write Firmware, Repair IMEI, Reset FRP, Factory Reset(Format), Read/Write Dump, Partition Manager
P.S : If you already has package no need re-download, Just Click Update All Button at HumTool ** Hydra Tool Offical Web Page ** You can check from official webpage supported models and functions Most models Supported Read Firmware, Write Firmware, Repair IMEI, Reset FRP, Factory Reset e.t.c HYDRA Tool - Powerful Advanced Complete https://i.ibb.co/TWY4mJk/download.png https://i.ibb.co/g9T9dVp/facebook.pnghttps://i.ibb.co/Xz21f2C/Telegram.pnghttps://i.ibb.co/SXwmXgv/Youtube.pnghttps://i.ibb.co/10LPM1v/Authorized-Dealer.png |
Mediatek Dump the Preloader by Hydra Tool |
Good job team keep it up.... |
vivo dump preloader very fast Code:
hi..xiaomi not booting in this update try 2 pic ===================================== How To Boot : Power off phone * BROM Mode : Press VOL + or Press VOL -+ * Preloader Mode : Just Insert cable Searching for MTK Device...Found Port Identification :Flashmode BROM FriendlyName :MediaTek USB Port (COM14) SymbolicName :\??\USB#VID_0E8D&PID_0003#5&15c64844&0&2#{a5dcbf1 0-6530-11d2-901f-00c04fb951ed} Driver Ver :01/22/2016,3.0.1504.0 Handshaking...Ok Identifying Hardware ID..... Reading Device hardware info.. hw code : 0813MT6785 [6785] hw subcode : 8A00 hw version : CA00 sw version : 0000 Target config : E7 SB : 01 (True) SLA : 02 (True) DAA : 04 (True) Exploiting Device... Successfully Exploited... Handshaking...Ok Identifying Hardware ID..... Reading Device hardware info.. hw code : 0813MT6785 [6785] hw subcode : 8A00 hw version : CA00 sw version : 0000 Target config : 00 SB : 00 (False) SLA : 00 (False) DAA : 00 (False) FUSEID : 00000000 SECURE VERSION : 05 BL VERSION : FE NORMAL BOOT Preparing Download Agent.. DA : Xiaomi_RedmiNote8Pro_6785.bin Agent: MTK_DOWNLOAD_AGENT -HYDRA Ver : MTK_AllInOne_DA_v3.3001.2019/12/14.17:56_491164 Init : Loader [1] Sending : Accepted Identifying Protocol... Protocol : New Synchronization...[ERROR]- NOT SYNC ============================================= Reasons why it fails due to the following" 1. Harware problem/issues 2. If you did Testpoint Kindly check the parts you Touch/TP 3. Powershortage, try to connect Battery 4. Check or replace usb cable and plug directly to your pc usb port. ============================================= SYNC ===================================== Elapsed Time : 00:00:41 |
always good update or best work |
Hello, Please mention the model and post a screen shot, its looking the timeout issue, try to change your usb cable and hub then try again. Best Regards | Hydra Team |
Team flying like a plain good work appreciate keep it up |
Oppo A31 (CPH 2015) Formatting user data successfully remove by Hydra Tool 1. Run MTK Tool and choose "Sosc" 2. Choose Brand and Module. 3. Go to "Service"--> "Tool" 4. Choose "Ultra Power Option" 5. Choose "Format / Erase" from drop down menu 6. Click on "Execute" 7. Connect device to computer using USB Data Cable. 8. Wait until the operation is completed. Screen Short https://i.ibb.co/VL5wqQc/Oppo-A31-CP...ool-edited.jpg |
Need unlock bootloader xiami mtk and qualcomm |
Something wrong with Build 30 Hydra MediaTeK Tool Ver 1.0.3 Build 30 Windows 7 Service Pack 1 (Version 6.1, Build 7601, 32-bit Edition) Intel(R) Core(TM)2 Duo CPU E4500 @ 2.20GHz NVIDIA GeForce GT 710 Ram Installed : 3 GB Windows Access Right Admin Software Run As Admnistrator Brand : AUTO Model : AUTO Connection : Flash Mode ===================================== How To Boot : Power off phone * BROM Mode : Press VOL + or Press VOL -+ * Preloader Mode : Just Insert cable Searching for MTK Device...Found Port Identification :Flashmode BROM FriendlyName :MediaTek USB Port_V1632 (COM18) SymbolicName :\??\USB#VID_0E8D&PID_0003#5&94b8c27&0&8#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Driver Ver :01/22/2015,3.0.1504.0 Device port is not yet filtered... **************************************** Please run software as administrator... **************************************** ===================================== Elapsed Time : 00:00:02 Hydra MediaTeK Tool Ver 1.0.3 Build 29 Windows 7 Service Pack 1 (Version 6.1, Build 7601, 32-bit Edition) Intel(R) Core(TM)2 Duo CPU E4500 @ 2.20GHz NVIDIA GeForce GT 710 Ram Installed : 3 GB Windows Access Right Admin Software Run As Admnistrator Brand : OPPO Model : Realme 3 (RMX1821) Connection : Flash Mode ===================================== How To Boot : Power off phone * BROM Mode : Press VOL + or Press VOL -+ * Preloader Mode : Just Insert cable Searching for MTK Device...Found Port Identification :Flashmode BROM FriendlyName :MediaTek USB Port_V1632 (COM18) SymbolicName :\??\USB#VID_0E8D&PID_0003#5&94b8c27&0&8#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Driver Ver :01/22/2015,3.0.1504.0 Handshaking...Ok Identifying Hardware ID..... Reading Device hardware info.. hw code : 0788MT6771 [6771] hw subcode : 8A00 hw version : CA00 sw version : 0000 Target config : E5 SB : 01 (True) SLA : 00 (False) DAA : 04 (True) #Executing Exploit.. #SUCCESS.. Handshaking...Ok Identifying Hardware ID..... Reading Device hardware info.. hw code : 0788MT6771 [6771] hw subcode : 8A00 hw version : CA00 sw version : 0000 Target config : 00 SB : 00 (False) SLA : 00 (False) DAA : 00 (False) FUSEID : 00000000 SECURE VERSION : 00 BL VERSION : FE NORMAL BOOT Preparing Download Agent.. DA : [Not Exist] Trying Default 6771.bin Agent: MTK_DOWNLOAD_AGENT -HYDRA Ver : MTK_AllInOne_DA_v3.3001.2018-09-18.13:22_452898 Init : Loader [1] Sending : Accepted Identifying Protocol... Protocol : New Synchronization...SYNC Mode : brom Preloader Initialization... Parsing Realme_3_preloader_oppo6771_18601.bin Init : Accepted Execute Secondary Loader Init : Loader [2] Executing : SYNC Reading Device UniqueID, RAM and Flash Chip Info... UNIQUE ID : 9D614A908357CCA69713D45A608460F8 ERAM Size : 0x0000000000040000 -256 KB IRAM Size : 0x00000000C0000000 -3 GB eMMC BOOT1 : 0x0000000000400000 -4 MB eMMC BOOT2 : 0x0000000000400000 -4 MB eMMC RPMB : 0x0000000000400000 -4 MB eMMC USER : 0x0000000747C00000 -29.121 GB eMMC CID : 150100474436424D420137A4D268B525 - GD6BMB DA Speed : high-speed Reading GPT-EMMC [0x00008000] 130 Items Reading System Info ID : QP1A.190711.020 SDK : 29 Release : 10 ABI : arm64-v8a CPU abilist : arm64-v8a,armeabi-v7a,armeabi Locale : en-US Description : full_oppo6771-user 10 QP1A.190711.020 08805472cb0b87b3 release-keys Display ID : QP1A.190711.020 release-keys Security Patch : 2021-03-05 StorageType : mtp Userdata State : Not Encrypted ===================================== Elapsed Time : 00:01:10 |
Good Update Hydra Team,,,,,,,,,,,,,, |
This is what we call update grate thanks team |
