Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1966 (permalink) | |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,599 | Xiaomi Redmi 9 Lancelot FRP successfully removed by Hydra Tool Xiaomi Redmi 9 Lancelot FRP successfully removed by Hydra Tool 1. Run Hydra MTK Module and choose "Sosc" 2. Select Brand and Model 3. Go to Service-->Tool 4. Choose "Factory reset protection FRP from universal menu. 5. Choose "Zero Wipe" from "Option / Method" drop down menu 6. Execute and connect the device to the computer with data cable 7. Click on "Execute". 8. wait until the process is completed. Screen Short: ![]() Logs: Quote:
Dipendra Pathak | |
![]() | #1967 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,599 | UMIDIGI A3 Factory Reset Protection (FRP) successfully removed by Hydra Tool UMIDIGI A3 Factory Reset Protection (FRP) successfully removed by Hydra Tool 1. Run Hydra MTK Module and choose "Sosc" 2. Select Brand and Model 3. Go to Service-->Tool 4. Choose "Factory reset protection FRP from universal menu. 5. Choose "Auto" from "Option / Method" drop down menu 6. Execute and connect the device to the computer with data cable 7. Click on "Execute". 8. wait until the process is completed. Screen Short: ![]() Logs: Quote:
Dipendra Pathak | |
![]() | #1968 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,599 | Cherry Mobile Flare S8 FRP successfully done by Hydra Tool Cherry Mobile Flare S8 FRP successfully done by Hydra Tool 1. Run Hydra MTK Module and choose "Sosc" 2. Select Brand and Model 3. Go to Service-->Tool 4. Choose "Factory reset protection FRP from universal menu. 5. Choose "Auto" from "Option / Method" drop down menu 6. Click on "Execute". 7. connect the device to the computer with data cable 8. wait until the process is completed. Screen Short: ![]() Logs: Quote:
Dipendra Pathak | |
![]() | #1969 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,599 | Huawei MED-L09 (Y6P) Remove Account is successfully done by Hydra Tool Huawei MED-L09 (Y6P) Remove Account is successfully done by Hydra Tool 1. Run Hydra MTK Module and choose "Sosc" 2. Select Brand and Model 3. Go to Service-->Tool 4. Choose "Huwei". 5. Choose "Remove Account" from "Option / Method" drop down menu 6. Click on "Execute". 7. connect the device to the computer with data cable 8. wait until the process is completed. Screen Short: ![]() Logs: Quote:
Dipendra Pathak | |
![]() | #1970 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,599 | Hisilicon Huawei HMA-L29 (Mate 20) Flashing with Fastboot done by Hydra Main Tool Huawei HMA-L29 (Mate 20) Flashing successfully done with Hydra Main Tool Screen Short: ![]() Logs: Quote:
Dipendra Pathak | |
![]() | #1971 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,599 | Huawei AGS2-L03 (Media Pad T5) Hisilicon removing FRP successfully done by Hydra Tool Huawei AGS2-L03 (Media Pad T5) Hisilicon removing FRP successfully done by Hydra Tool Screen Short: ![]() Logs: Quote:
Dipendra Pathak | |
![]() | #1972 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,599 | Hi Siicon Huwei VOG-TL00 (P30 Pro) Hisilicon Removing frp Fastboot mode done by Hydra Hi Siicon Huwei VOG-TL00 (P30 Pro) Hisilicon Removing frp Fastboot mode done by Hydra Screen Short: ![]() Logs: Quote:
Dipendra Pathak | |
![]() | #1973 (permalink) |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2018 Location: Ukraine / Harkov
Member: 2857401 Status: Offline Thanks Meter: 6,423 | OPPO A12 Sim Unlock (Direct Unlock) by Hydra Dongle OPPO A12 Sim Unlock (Direct Unlock) by Hydra Dongle OPPO Simlock Remove of MTK OPPO A12 by Flash mode with Hydra by USB only |
![]() | #1974 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,599 | Xiaomi Redmi Note 5A SE (Ugglite) successfully flashed by Hydra Tool Xiaomi Redmi Note 5A SE (Ugglite) successfully flashed by Hydra Too 1. Run Hydra Qualcomm Module and Sosc. 2. Choose Brand and Module. 3. Go to "Flash Tool" Tab. 4. Choose Flash file and its location. 5. Click on "Flash" 6. connect device to the computer with USB Data cable 7. Wait until the process is completed. Screen Short: ![]() Logs: Quote:
Dipendra Pathak | |
![]() | #1975 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,599 | Lenevo Tab 10 (TB-X103F) Zero Wipe FRP successfully removed by Hydra Tool Lenevo Tab 10 (TB-X103F) Zero Wipe FRP successfully removed by Hydra Tool 1. Run Hydra Qualcomm Module. 2. Select Brand and Model as "Auto" 3. Go to Service-->Universal 4. Choose "Factory reset protection" from drop down menu. 5. Choose "Zero wipe" from "Flash Mode". 6. Click on "Execute". 7. connect the device to the computer with data cable 8. wait until the process is completed. Screen Short: ![]() Logs: Quote:
Dipendra Pathak | |
![]() | #1976 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,599 | Huawei NEMo-L22 (Honor 5C) Hisilicon device Remove FRP successfully done by Hydra To Huawei NEMo-L22 (Honor 5C) Hisilicon device Remove FRP successfully done by Hydra To Screen Short: ![]() Logs: Quote:
Dipendra Pathak | |
![]() | #1977 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,599 | Vivo Y53 zero wipe successfully removed by Hydra Tool Vivo Y53 zero wipe successfully removed by Hydra Tool 1. Run Qualcomm Tool and choose "Sosc" 2. Choose Brand and Module. 3. Go to "Service"--> "Vivo" 4. Choose "Factory Reset" from drop down menu 5. Choose "Safa formet EMMC" from Flash Mode 6. Click on "Execute" 7. Connect device to computer using USB Data Cable. 8. Wait until the operation is completed. Screen Short: ![]() Logs: Quote:
Dipendra Pathak | |
![]() | #1978 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,599 | Huawei ATU-L22 (Y6 2018) Remove FRP successfully done by Hydra Tool Huawei ATU-L22 (Y6 2018) Remove FRP successfully done by Hydra Tool 1. Run Qualcomm tool. 2. Choose Correct Module and Brand. 3. Go to "Service" -- > "Huawei" 4. Choose "Factory Reset" tool from drop down menu 5. choose "Remove FRP" from Flash Mode. 6. Click on "Execute" and connect device with computer using USB cable. 7. Wait until the process is completed. Screen Short: ![]() Logs: Quote:
Dipendra Pathak | |
![]() | #1979 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,599 | Xiaomi Mi A1 (Tissot) successfully flashed by Hydra Tool Xiaomi Mi A1 (Tissot) successfully flashed by Hydra Tool 1. Run Hydra Qualcomm Module and Sosc. 2. Choose Brand and Module. 3. Go to "Flash Tool" Tab. 4. Choose Flash file and its location. 5. Click on "Flash" 6. connect device to the computer with USB Data cable 7. Wait until the process is completed. Screen Short: ![]() Logs: Quote:
Dipendra Pathak | |
![]() | #1980 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,599 | Vivo V9 Youth (PD1730BF) forced erased to remove FRP successfully done by Hydra Tool Vivo V9 Youth (PD1730BF) forced erased to remove FRP successfully done by Hydra Tool 1. Run Qualcomm Tool and choose "Sosc" Screen Short:2. Choose Brand and Module. 3. Go to "Service"--> "Vivo" 4. Choose "Factory Reset" from drop down menu 5. Choose "Forced Erased" from Flash Mode 6. Click on "Execute" 7. Connect device to computer using USB Data Cable. 8. Wait until the operation is completed. ![]() Logs: Quote:
Dipendra Pathak | |
