Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GSMFABRICA Products > HYDRA TOOL
Old 07-14-2021, 02:15   #2206 (permalink)
Dipendra Pathak's Avatar
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,624
Xiaomi Redmi 6A (Cactus) remove Mi Account successfully done by Hydra Tool
1. Run Hydra MTK Module and choose "Sosc"
2. Select Brand and Model as "Auto"
3. Go to Service-->Tools
4. Chose "Xiaomi" from universal operation
5. Choose "Remove Mi Account (Erased Method) "Method / Option" drop down menu
6. Execute and connect the device to the computer with data cable
7. wait until the process is completed
Screen Short:
Dipendra Pathak
Old 07-14-2021, 11:04   #2207 (permalink)
ceza031's Avatar
Member: 1724862
Thanks Meter: 450
Redmi 8 olive IMEI Repair | No Unlock BL | No Root | No ENG ROM
Xiaomi Redmi 8 olive IMEI Repair, All MIUI and Android versions are supported.
Without Unlock Bootloader
Without Root
Without Flash ENG Rom
Full Network with 4G
  1. Run Qualcomm Module, Select Brand and Model
  2. Put your device EDL Mode by Testpoint
  3. From Service -> Partitions Tab Select Erase Security
  4. Power on device Enable Diag by Dial code *#*#717717#*#*
  5. Go to Repair Tab, Select Xiaomi RSA Method
  6. Fill IMEI 2 only and Repair
Note : Only 2nd imei supported this device.
Erase Security by EDL Mode :
Repair IMEI LOG :
Old 07-15-2021, 02:32   #2208 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,624
Xiaomi Redmi 6a (Cactus) safe format universal using Ultra power Option done by Hydra
3. Tick "Auto Broom Exploit" is for bypassing xiaomi auth. server.
4. Go to Service-->Tools
5. Choose "Ultra Power Option "Method / Option" drop down menu
Screen Short:
Dipendra Pathak
Old 07-15-2021, 02:44   #2209 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,624
Huawei ATU-L22 (Y6 2018) zero wipe FRP successfully removed by Hydra Tool
- Run Hydra Qualcomm Module
- Select Model of your device (cellphone / mobile)
- Go to "Service"--> "Universal"
- choose "Factory Reset protection"
- Select "Auto" from "Flash mode"
- Join the TP or Short the TP of Device (you need to disassemble the device).
- Click "Execute" button
- Connect USB data Cable between cellphone and computer.
- Wait until the operation is completed.
Screen Short:
Dipendra Pathak
Old 07-15-2021, 02:52   #2210 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,624
Oppo A15 (CPH 2185) safe format Universal successfully remove by Hydra Tool
1. Run MTK tool.
2. Choose Correct Module and Brand.
3. Go to "Service" -- > Tool"
4. Choose "Ultra Power Option"
5. choose "Auto" from "Method / Option" drop down menu
6. Click on "Execute"
7. connect device with computer using USB data cable.
8. Wait until the process is completed.
Screen Short:
Dipendra Pathak
Old 07-15-2021, 03:02   #2211 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,624
Oppo F17 Pro (CPH2119) Formatting user data successfully done by Hydra Tool
1. Run Hydra MTK Tool and choose "Sosc".
2. Choose Brand and Module.
3. Tick "Auto loader" and "Auto BROM Exploit"
4. Go to "Service"--> "Tool" tab
5. Choose "Factory format / reset userdata"
6. Choose "Erase User Data" from "Method / Option" drop down menu.
7. Click "Execute"
8. Connect device to computer with the help of data cable.
9. Wait until the operation is complete
Screen Short:
Dipendra Pathak
Old 07-15-2021, 15:05   #2212 (permalink)
sky73's Avatar
Member: 1876736
Thanks Meter: 740
nokia 2720 remove user lock by format with hydra tool
PreOperation Configuration
 Brand : NOKIA Model : 2720 Flip Storage : Auto
 Loader: Nokia2720.mbn
 Port  : Auto
 Searching for Qualcomm 9008 Device...Found
 FriendlyName :Qualcomm HS-USB QDLoader 9008 (COM3)
 SymbolicName :\??\USB#VID_05C6&PID_9008#5&15c311e1&0&10#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
 Driver Ver   :05/29/2019,2.1.3.7
Getting device info.....
Serial No.: 0x1CEC3969
HW_ID     : 000940E100420050
MSM ID    : 0x000940E1, MSM8905-Qualcomm Snapdragon 205
MODEL_ID  : 0x0050
OEM_ID    : 0x0042 - ALCATEL
PBL Ver   : 00000000
PK HASH   : 77101cea7db8958552addeb45de9e325904e89fb0cbee284399e54fc9c96aac5
Firehose Loader[Nokia2720.mbn]
  Header Type    : OLD
  TargetMSM      : 8909
  Tag            :
  Version        : 3
  Code_size      : 320
  Signature_size : 256
  fhVendor       : HMD
  Vendor         : ALCATEL
  OEM_ID         : 0042
  MODEL_ID       : 0050
  SW_ID          : 0000000000000003
  APP_ID         :
  pk_hash        : 77101cea7db8958552addeb45de9e325904e89fb0cbee284399e54fc9c96aac5
  OEM_VERSION    : bjfih028
  IMAGE_VARIANT  : DAADANAZA
  QC_VERSION     : BOOT.BF.3.1.2.C2.2-00016
SaharaBoot... Ok
Sending ...............Ok
Connecting to Firehose...
Ping... Ok
Configuration......
Identifying Chip..........eMMC
Ok
Chip Configuration :
 MemoryName : eMMC
 MaxPayloadSizeToTargetInBytes : 1048576
 MaxPayloadSizeToTargetInBytesSupported : 1048576
 MaxPayloadSizeFromTargetInBytes : 4096
 MaxXMLSizeInBytes : 4096
 TargetName : 8909
 Version : 1
Protocol : Feature Phone
Running : Ok
Phone Information.....
  Brand          : Nokia
  Vendor         : HMD Global
  Model          : Nokia 2720 Flip
  SDK            : 23
  Release        : 6.0.1
  ABI            : armeabi-v7a
  CPU abilist    : armeabi-v7a,armeabi
  Locale         : en-US
  Description    : Nokia 2720 Flip-user 6.0.1 MMB29M 21.00.17.01 dev-keys
  Device         : Nokia 2720 Flip
  Board          : msm8909
  Display ID     : MMB29M dev-keys
  Security Patch : xxxx-xx-xx
  Platform       : msm8909
  FRPPST         : /dev/block/bootdevice/by-name/config
  Fingerprint    : Nokia/Nokia_2720_Flip/Nokia_2720_Flip:6.0.1/MMB29M/21.00.17.01:user/dev-keys
Reading GPT[1]
          Drive [0] 36 Items
Formatting Userdata...
Method :
Auto
Processing...
 - Formatting Userdata
Executing ...
 - Formatting Userdata  [Safe Format - eMMc] Failed
 - Formatting Userdata  [Zero Wipe] OkOkOk
Elapsed Time : 00:00:05
Old 07-16-2021, 00:48   #2213 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,624
Xiaomi Redmi Noe 7 (lavender) bypass Mi account successfully done by Hydra Tool
1. Run Hydra Qualcomm Tool.
2.Choose "Module" and "Brand"
3. Go to "Service"--> "Xiaomi" tab
4. Choose "Mi Account" from drop down menu.
5. Choose "Bypass Anti-Relock Method 1"
6. Tick “Include FRP" if you want to remove FRP.
7 Click on "Execute"
8. Short TEST POINT using tuiser or join two point with any tool
Note: You need disassemble device (cellphone) for this. Use google search,
to find the Test Point Picture.
9. Connect Device with Computer using USB Data Cable
10. Wait until the flashing process is complete.
11. Done
Screen Short:
Dipendra Pathak
Old 07-16-2021, 00:54   #2214 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,624
Vivo Y11 (1906) removing user data successfully removed by Hydra Tool
1. Run Qualcomm Tool and choose "Sosc"
3. Go to "Service"--> "Vivo"
4. Choose "Factory Reset" from drop down menu
5. Choose "Forced Erased" from Flash Mode
7. Connect device to computer using USB Data Cable.
8. Wait until the operation is completed.​
Screen Short:
Dipendra Pathak
Old 07-16-2021, 01:01   #2215 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,624
Xiaomi Redmi S2 (ysl) successfully flashed using Fastboot mode by Hydra Too
3. Go to "Flash" tab
4. Choose "File Type" and its location.
5. Choose "Flash Mode"
6. Tick “Autoback EFS, “Skip write security partitions”, “SetBootableStorage”, “Skip with security partition”, “Faxtory Reset After Flash” or one or two you like to do.
11. Done
Screen Short:
Dipendra Pathak
Old 07-16-2021, 01:08   #2216 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,624
Xiaomi Mi CC9e (Laurus) successfully flashed using EDL mode by Hydra Tool
Xiaomi Mi CC9e (laurus) successfully flashed using EDL mode by Hydra Tool
11. Done
Screen Short:
Dipendra Pathak
Old 07-16-2021, 01:15   #2217 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,624
Xiaomi Redmi Note 9 (merlin) erased user data successfully done by Hydra Tool
1. Run Hydra MTK module and SOSc.
2. Choose Brand and Module as auto.
3. Go to "Service"--> "Tool" Tab.
4. Tick "Ultra power option"
5. Choose "Erase User Data" from "Method / Option" drop down menu
6. click "Execute" button
7. connect device to the computer with USB Data cable
Screen Short:
Dipendra Pathak
Old 07-16-2021, 07:24   #2218 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 1,309
Hydra Unisoc Tool Ver 1.0.1 Build 4
Windows 8.1 (Version 6.3, Build 9600, 32-bit Edition)
Intel(R)Core(TM) i3-2330M CPU @ 2.20GHz
NVIDIA GeForce 410M
Ram Installed : 3 GB
Windows Access Right : Admin
Software Run As Admnistrator
Port : [Auto] Scanning...COM6
Opening Port...(COM6)Ok
Service_FRP_Flashmode...
Reading IMEI....
IMEI 1 : xxx
IMEI 2 : xxx
Reading System Info..
Vendor : LAVA
Model : LAVA LH9940
Android Ver : 8.1.0
Device : LH9940
Display ID : LAVA_iris_43_1_16_S105_INT_19F27
Security Patch : 2019-06-05
FRPPST : /dev/block/platform/soc/soc:ap-ahb/20600000.sdio/by-name/persist
Fingerprint : LAVA/LH9940/LH9940:8.1.0/OPM2.171019.012/25419:user/release-keys
ro_product_hardware : sc7731e_1h10_v1.1.0
sys_hardware_version : SC7731e_2_IRD_K_V1.1.0
Removing FRP...Ok
Elapsed Time : 00:00:04
The Following User Says Thank You to malka4u For This Useful Post:
Old 07-16-2021, 09:18   #2219 (permalink)
Gsm-Ahmed's Avatar
Member: 2944109
Thanks Meter: 670
Condor Plume H1 (SP620) Ultra Power Option
 Brand : CONDOR Model : Plume H1 Storage : Auto
 Loader: Mi_8953.mbn
 Port  : Auto
 FriendlyName :Qualcomm HS-USB QDLoader 9008 (COM42)
 SymbolicName :\??\USB#VID_05C6&PID_9008#6&12e3c9ed&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
 Driver Ver   :08/31/2015,2.1.2.0
Getting device info..Ok
Device MODE : Firehose
Ping.. Ok
Configuration......
Ok
 MemoryName : eMMC
 TargetName : 8953
 Version : 1
*** STORAGE DEVICE INFO ***
Memory Type         : eMMC
Block Size in Bytes : 512
Page Size           : 512
Manufacturer ID     : 144
Serial Number       : 934817224
Firmware Version    : 165
Product Name        : HAG4a2
Physical Partitions : 3
Total Logical Blocks:
          Drive [0]  30777344[14.676 GB]
          Drive [1]  8192[4 MB]
          Drive [2]  8192[4 MB]
Protocol : Universal
Running : Ok
Reading GPT[3]
          Drive [0] 48 Items
          Drive [1] 0 Items
          Drive [2] 0 Items
  Brand          : Condor
  Vendor         : SPA Condor Electronics
  Model          : Plume H1
  SDK            : 25
  Release        : 7.1.2
  ABI            : arm64-v8a
  CPU abilist    : arm64-v8a,armeabi-v7a,armeabi
  Locale         : en-US
  Description    : msm8953_64-user 7.1.2 N2G47H 2578 release-keys
  Device         : SP620
  Board          : SP620
  Display ID     : N2G47H release-keys
  Security Patch : 2018-03-01
  Emmc_size      : 16GB
  Platform       : msm8953
  Fingerprint    : Condor/SP620/SP620:7.1.2/N2G47H/SP620_V11.0_20170925:user/release-keys
Processing Auto....
 - Removing FRP
Executing ...
 - Removing FRP [Zero Wipe] OkOk
Executing ...
 - Formatting Userdata  [Safe Format - eMMc] OkOk
Action Result : Ok
Rebooting Phone.... Ok
Elapsed Time : 00:00:03
Old 07-16-2021, 09:20   #2220 (permalink)
Gsm-Ahmed's Avatar
Member: 2944109
Thanks Meter: 670
OPPO A37f Read Pattern
OPPO A37F Read Pattern
 Brand : AUTO Model : AUTO Storage : Auto
 Loader: Auto
 Port  : Auto
Ping.. Ok
Configuration.......
Ok
 MemoryName : eMMC
 MaxPayloadSizeToTargetInBytes : 16384
 MaxPayloadSizeToTargetInBytesSupported : 16384
 TargetName : 8916
 Version : 1
Running : Ok
  Brand          : OPPO
  Vendor         : OPPO
  Model          : A37f
  SDK            : 22
  Release        : 5.1.1
  ABI            : arm64-v8a
  Description    : msm8916_64-user 5.1.1 LMY47V eng.root.20190711.032745 release-keys
  Board          : msm8916
  Display ID     : A37fEX_11_190711
  Platform       : msm8916
Reading GPT[3]
          Drive [0] 40 Items
          Drive [1] 0 Items
          Drive [2] 4 Items
Operation : ScreenLock Security
Read Pattern
Processing...
Trying to search : gatekeeper.pattern.key
Trying to search :  personalpattern.key
Trying to search : cm_gesture.key
Trying to search : gesture.key FOUND
Gesture Data : 71890FAED57A325C08EB04BE0F4FD8C05845C972
Bruteforcing pattern hash..Please wait for few seconds
Pattern Code : 95487
1 2 3
4 5 6
7 8 9
Ok
Page generated in 0.29155 seconds with 9 queries
