Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GSMFABRICA Products > HYDRA TOOL
Old 08-06-2021, 16:47   #2341 (permalink)
Dipendra Pathak's Avatar
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,624
Realme 8 5G (RMX2341) Demo successfully removed by Hydra Tool
This Operation goes Flash Mode with COM Port
1. Run Hydra MTK module and choose "SOSC".
2. Tick "COM Port" at the TOP
2. Choose Brand and Module
3. Tick "Auto Loader", "Auto Broom Exploit" and "Enable UBL Loader"
4. Tick "Enable Auto Pre DUMP"
5. Go to "Service" -->"Tool" Tab.
6. Choose "Read System Info"
Note: This function tells you this device completely supports or not.
7. connect device to the computer with USB Data cable with Flash Mode
8. Wait until Hydra shows you all information on the screen.
9. choose "Factory Reset / Format User Data"
10. Choose "Erase user data" from "Method / Option"
11. Tick "Auto Reboot"
12. Click "Execute"
13. connect device to the computer with USB Data cable with Flash Mode
14. Wait until the process is completed.
Note: If you do not have boot file, you can make it from Hydra "EXPLOIT" Tab using "BROOM (dump Preloader Flash init)"
Screen Short:
Dipenda Pathak
Old 08-06-2021, 17:01   #2342 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,624
POCO M3 (Citrus) MIUI 12 successfully flashed by Hydra Tool
The manual goes this way:
1. Run Hydra Qualcomm Module and Sosc.
2. Choose Brand and Module.
3. Go to "Flash Tool" Tab.
4. Choose Flash file and its location.
5. Click on "Flash"
6. Disassemble the cellphone (device) and find its test point.
7. Short both testpoint using twiser or other tool.
8. connect device to the computer with USB Data cable
9. Wait until the process is completed.
Screen Short:
Dipenda Pathak
Old 08-06-2021, 17:11   #2343 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,624
Techno CD7 (Camon 15) bootloader successfully removed by Hydra Tool
1. Run Hydra MTK Module,
2. Select Brand and Model or AUTO
Note: If Auto boot and loader not supported, then, untick "Autoloader" and choose manual Da (download agent) and PERL (boot file).
3. Tick "Enable UBL Loader"
(Note: You can use this option if it the device does not boot properly by Hydra Tool)
4. click on "Read System Info"
5. Connect device to computer using USB Data Cable.
6. Wait Hydra Reads all device information properly.
6. Go to "Service"-->Tool
7. Choose "Bootloader"
8. Choose "Unlock Bootloader" from drop down menu..
9. Click on "Execute"
10. Wait until the operation is completed.
Screen Short:
Dipenda Pathak
Old 08-06-2021, 17:24   #2344 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,624
SAMSUNG GALAXY J600G/DS GOOGLE ACCOUNT SUCCESSFULLY REMOVE USING EMMC, NO NEED Flash!
SAMSUNG GALAXY J600G/DS GOOGLE ACCOUNT SUCCESSFULLY REMOVE USING EMMC, NO NEED Flash By Hydra
Video Prooft:
Dipenda Pathak
Old 08-06-2021, 17:31   #2345 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,624
Huawei Kirin 980 Huawei ID successfully removed by Hydra Dongle
Video Prooft:
Dipenda Pathak
Old 08-07-2021, 09:55   #2346 (permalink)
Member: 2199727
Thanks Meter: 217
wiko view prime imei repair ok.
Old 08-07-2021, 18:32   #2347 (permalink)
Gsm-Ahmed's Avatar
Member: 2944109
Thanks Meter: 670
Tecno Spark 6 Go (KE5) Ultra Power Option
Searching for MTK Device...Found
 Port Identification :Flashmode BROM
 FriendlyName :MediaTek USB Port_V1632 (COM6)
 Device       :6&12e3c9ed&0&1
 SymbolicName :\??\USB#VID_0E8D&PID_0003#6&12e3c9ed&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
 Driver Ver   :01/22/2015,3.0.1504.0
Handshaking...Ok
Identifying Hardware ID.....
Reading Device hardware info..
 hw code       : 0717MT6761 [6761]
 hw subcode    : 8A00
 hw version    : CA01
 sw version    : 0200
 Target config : E5
 SBC           : 01 (True)
 SLA           : 00 (False)
 DAA           : 04 (True)
 SWJTAG        : 04 (True)
 EPP           : 00 (False)
 CERT          : 00 (False)
 MEMREAD       : 20 (True)
 MEMWRITE      : 40 (True)
 CMD_C8        : 80 (True)
Exploiting BROM...
Exploit Sent..
Successfully Exploited..
Reading Flash Init...
Flash init Size 0x0610
Security Authorization....
Sending Accepted
Handshaking...
 hw subcode    : 8A00
 hw version    : CA01
 sw version    : 0200
 Target config : 05
 SBC           : 01 (True)
 SLA           : 00 (False)
 DAA           : 04 (True)
 SWJTAG        : 04 (True)
 EPP           : 00 (False)
 CERT          : 00 (False)
 MEMREAD       : 00 (False)
 MEMWRITE      : 00 (False)
 CMD_C8        : 00 (False)
MEID : 0F7679D442A30905251FC2FA88B6F17C
Stage 1..[Size:232216]
 Sending :  Please wait.. Accepted
Identifying Protocol...
 Protocol : New
 Synchronization...SYNC
 Preloader Initialization...
 Parsing preloader_ke5_h6123go.bin
 Init : Accepted
 Executing : SYNC
Reading Device UniqueID, RAM and Flash Chip Info...
 UNIQUE ID  : 82B5775F0D9AD0BE08AC63DE49C61974
 ERAM Size  : 0x0000000000039000 -228 KB
 IRAM Size  : 0x0000000080000000 -2 GB
 eMMC BOOT1 : 0x0000000000400000 -4 MB
 eMMC BOOT2 : 0x0000000000400000 -4 MB
 eMMC RPMB  : 0x0000000000400000 -4 MB
 eMMC USER  : 0x0000000747C00000 -29.121 GB
 eMMC CID   : 15010051583633414203B9EBBC60C7D1 - QX63AB
 Executing : ACCEPTED...
Reading GPT-EMMC [0x00008000] 130 Items
Autobackup Partitions
-preloader[0x00000000]512 KB ->preloader.bin...Ok
   -> Renaming Preloader....  preloader_ke5_h6123go.bin
   Creating Scatter file... C:\Hydra Tool\\Backup\Auto\0717__080421102627\MT6761_Android_scatter.txt
-pgpt[0x00000000]32 KB ->pgpt.bin...Ok
-frp[0x01888000]1024 KB ->frp.bin...Ok
-nvdata[0x07022000]71.867 MB ->nvdata.bin...Ok
-persist[0x0B800000]48 MB ->persist.bin...Ok
-protect1[0x0E800000]8 MB ->protect1.bin...Ok
-protect2[0x0F000000]8 MB ->protect2.bin...Ok
-nvram[0x1B300000]64 MB ->nvram.bin...Ok
Done!!!
MTK Phone Loader is NOW RUNNING.
Operation : Auto
Processing...
ZeroWipe FRP Partition...
Safeformat Universal...
Action Result :  Ok
Rebooting Device [Reboot To Normal]
Reboot Done!!
Elapsed Time : 00:01:02
Old 08-07-2021, 18:35   #2348 (permalink)
Gsm-Ahmed's Avatar
Member: 2944109
Thanks Meter: 670
Oppo A5s (CPH1909) Formatting Userdata Flash Mode Done
 FriendlyName :MediaTek USB Port_V1632 (COM61)
 Device       :6&12e3c9ed&0&2
 SymbolicName :\??\USB#VID_0E8D&PID_0003#6&12e3c9ed&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
Opened handle..
Handshaking...Ok
 hw code       : 0766MT6765 [6765]
 hw subcode    : 8A00
 hw version    : CA00
 sw version    : 0000
 Target config : E5
 SBC           : 01 (True)
 SLA           : 00 (False)
 DAA           : 04 (True)
 SWJTAG        : 04 (True)
 EPP           : 00 (False)
 CERT          : 00 (False)
 MEMREAD       : 20 (True)
 CMD_C8        : 80 (True)
Exploiting Device...
Exploit Sent..
Successfully Exploited...
Handshaking...Ok
C:\Hydra Tool\Backup\Preloader_dump\prel.tmp
Handshaking...
 hw subcode    : 8A00
 hw version    : CA00
 sw version    : 0000
 Target config : 00
 SBC           : 00 (False)
 SLA           : 00 (False)
 DAA           : 00 (False)
 SWJTAG        : 00 (False)
 EPP           : 00 (False)
 CERT          : 00 (False)
 CMD_C8        : 00 (False)
MEID : DEBAAE437782A99E5E0FA7B8C122BB90
Stage 1..[Size:216440]
 Protocol : New
 Parsing prel.tmp
 Init : Accepted
 Executing : SYNC
 UNIQUE ID  : 7C51C60E1F5F9CBE6A77AA0B9F3B0BEA
 ERAM Size  : 0x0000000000038000 -224 KB
 IRAM Size  : 0x00000000C0000000 -3 GB
 eMMC CID   : 150100474436424D42011303D3A2C63F - GD6BMB
Reading System Info
  Vendor         : OPPO
  SDK            : 27
  Release        : 8.1.0
  ABI            : arm64-v8a
  CPU abilist    : arm64-v8a,armeabi-v7a,armeabi
  Locale         : en-US
  Description    : full_oppo6765_18511-user 8.1.0 O11019 1616154336 release-keys
  Security Patch : 2021-04-05
  StorageType    : mtp
  Userdata State : Encrypted
   -> Renaming Preloader....  preloader_oppo6765_18511.bin
   Creating Scatter file... C:\Hydra Tool\\Backup\Auto\0766__080721164507\MT6765_Android_scatter.txt
-frp[0x09E88000]1024 KB ->frp.bin...Ok
-nvdata[0x0BF88000]64 MB ->nvdata.bin...Ok
-protect1[0x11F88000]8 MB ->protect1.bin...Ok
-protect2[0x12788000]8.469 MB ->protect2.bin...Ok
-persist[0x13800000]48 MB ->persist.bin...Ok
-nvram[0x20000000]64 MB ->nvram.bin...Ok
Done!!!
Reading System Info
  Vendor         : OPPO
  SDK            : 27
  Release        : 8.1.0
  ABI            : arm64-v8a
  Locale         : en-US
  StorageType    : mtp
Operation : Erase Userdata
Processing...
Formatting Userdata...
Action Result :  Ok
Reboot Done!!
Elapsed Time : 00:00:47
The Following User Says Thank You to Gsm-Ahmed For This Useful Post:
Old 08-07-2021, 18:36   #2349 (permalink)
Gsm-Ahmed's Avatar
Member: 2944109
Thanks Meter: 670
Condor TFX-708G Read Pattern Done
 Port Identification :Flashmode Preloader
 FriendlyName :MediaTek PreLoader USB VCOM_V1632 (Android) (COM62)
 SymbolicName :\??\USB#VID_0E8D&PID_2000#6&12e3c9ed&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
Opened handle..
Reading System Info
  Brand          : Condor
  Vendor         : SPA Condor Electronics
  Model          : TFX-708G
  SDK            : 19
  Release        : 4.4.2
  ABI            : armeabi-v7a
  Description    : hf3_726_ts_condor_mipi-user 4.4.2 KOT49H eng.zhuyongjian.1435837233 release-keys
  Device         : TFX-708G
  Board          : hf3_726_ts_condor_mipi
  Display ID     : HF3.KK.726.TS.CONDOR.B1.WXGA.8G.1G.MIPI.0702.V3.09
  Fingerprint    : Android/TFX-708G/TFX-708G:4.4.2/KOT49H/1435837233:user/release-keys
  StorageType    : mtp
  Userdata State : Not Encrypted
Operation : Read Pattern
Processing...
Searching PatternKey : . Found
Gesture Data : FFEC1E70D113B0B96C7E6CB2B33460E24407A96E
Bruteforcing pattern hash..Please wait for few seconds
Pattern Code : 12369
1 2 3
4 5 6
7 8 9
Action Result :  Ok
Reboot Done!!
Elapsed Time : 00:00:02
Old 08-08-2021, 04:31   #2350 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,624
Xiaomi Mi Play (Lotus) unlock bootloader successfully done by Hydra Tool
Screen Short:
Dipenda Pathak
Old 08-08-2021, 04:40   #2351 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,624
Xioami Redmi 9 (Lancelot) unlock bootloader successfully done by Hydra Tool
Screen Short:
Dipenda Pathak
Old 08-08-2021, 05:04   #2352 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,624
Xiaomi Redmi 5 (Rosy) unlock bootloader successfully done by Hydra Tool
6. Go to "Service"-->Xiaomi
7. Choose "Bootloader" from drop down menu.
8. Choose "Unlock Universal Auto".
Screen Short:
Dipenda Pathak
Old 08-08-2021, 05:14   #2353 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,624
Xiaomi Redmi Note 9 (Merlin) unlock bootloader successfully done by Hydra Tool
Screen Short:
Dipenda Pathak
Old 08-08-2021, 05:26   #2354 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,624
Xiaomi Redmi Note 8 Pro (Begonia) unlock bootloader successfully done by Hydra Tool
Screen Short:
Dipenda Pathak
Old 08-09-2021, 02:10   #2355 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,624
Xiaomi Redmi 9 Prime (Lancelot) Mi Account and FRP successfully Erased by Hydra Tool
1. Run Hydra MTK Module, Select Brand and Model
2. Go to Service-->Tools-->Xiaoami
3. Choose "Remove Mi Account Erased Method" from Method / Option
4. Execute and connect the device to the computer with data cable
5. wait until the process is completed.
Note: VPN software only needs for MTK Devices, not Qualcomm. VPN software install after removing MI Account and before connecting WIFI or Data. VPN software necessary for the device who has above android version 8 XXX (not for 8).
Hydra does not need server! Does not need Credit! Does not need yearly activation! Does not need need any extra cost.
Screen Short:
Dipenda Pathak
Page generated in 0.41228 seconds with 9 queries
