09-18-2021, 16:34 | #2566 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,619 | Xiaomi Redmi Note 8 (Begonia) formatting Persist successfully done by Hydra Tool Xiaomi Redmi Note 8 (Begonia) formatting Persist successfully done by Hydra Tool 1. Run MTK tool of Hydra Dongle. 2. Choose Correct Module and Brand. 3. Choose "Auto Broom Exploit", "Enable UBL Loader" Note: Please check screen short properly to check and uncheck them. 4. Click on "Boot / Info" and wait it reads all. 5. Go to "PM" Tab 6. Choose "Flash Mode" 7. Tick "Skip preloader" 8. Click on "Partition" button. 9. Now connect device to computer with Data Cable. 10. Wait it shows the different partition. 11. Choose "Presistent" 12. Click on "Erase" 13. Wait until the process is completed Screen Short: BR Dipendra Pathak |
09-18-2021, 16:40 | #2567 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,619 | Xiaomi Redmi 9 Prime (Lancelot) Mi Account successfully Removed Patched Method Xiaomi Redmi 9 Prime (Lancelot) Mi Account successfully Removed Patched Method 1. Run Hydra MTK Module and choose "Sosc" 2. Select Brand and Model 3. Tick "Com Port" 4. Sekect "Auto Broom Exploit", "Enable UBL Loader" and "Enable PrelDUMP" 5. Go to Service-->Tools-->Xiaoami 6. Choose "Remove Mi Account (Patch Method)" from "Method / Option" drop down menu 7. Execute and connect the device to the computer with data cable 8. wait until the process is completed. Screen Short: BR Dipendra Pathak |
09-19-2021, 14:21 | #2568 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,619 | Vivo Y11 (1906) Remove Lock without loss Data using EDL method by Hydra Tool Vivo Y11 (1906) Remove Lock without loss Data using EDL method by Hydra Tool 1. Run Hydra Qualcomm Tool. 2. Choose Module and Brand. 3. Go to "Service"--> "Vivo" 4. Choose "Factory Reset" from drop down menu. 5. Choose "Forced Erased" from Flash Menu. 6. Click "Execute" 7. Tick "Include FRP" 8. Connect Cellphone with your computer using data cable. 9. Wait until the operation is completed. Screen Short: BR Dipendra Pathak |
09-19-2021, 14:29 | #2569 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,619 | Huawei ATU L22 (Y6 2018) Flashing selected partitions successfully done by Hydra Tool Huawei ATU L22 (Y6 2018) Flashing selected partitions successfully done by Hydra Tool - Run Hydra Qualcomm Module - Select Model of your device (cellphone / mobile) - go to "Flash Tool" - Choose Flash file and its location manually. - Select Flashmode - Tick"Factory reset after flash" - Join the TP or Short the TP of Device (you need to disassemble the device). - Click "Flash" - Connect USB Cable and wait until the process is completed. - DONE Screen Short: BR Dipendra Pathak |
09-19-2021, 14:42 | #2570 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,619 | Xiaomi Redmi 6A (Cactus) Permeant Unlocked Bootloader done by Hydra Tool Xioami Redmi 6A (Cactus) Permeant Unlocked Bootloader done by Hydra Tool 1. Run Hydra MTK Module and Sosc. 2. Choose Brand and Module. 3. Select "Auto Broom Exploit", "Enable UBL Loader" and "Enable PrelDUMP" 4. Go to "Service"--> "Tool" Tab. 5. Choose "Bootloader". 6. Choose "Permeant Unlock Redmi 6/6A" 7. Click on "Execute" 8. connect device to the computer with USB Data cable 9. Wait until the process is completed. Screen Short: BR Dipendra Pathak |
09-19-2021, 14:53 | #2571 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,619 | Huawei DRA-LX9 (Y5P 2020) backed up selected partiton done by Hydra Tool Huawei DRA-LX9 (Y5P 2020) backed up selected partition done by Hydra Tool 1. Run Hydra MTK Module. 2. Tick "Brand" and "Module". 3. Tick "Comport" 4. Select "Auto Broom Exploit", "Enable UBL Loader" and "Enable PrelDUMP" 5. Choose "PM" Tab 6. Tick "Flash Mode" 7. Tick "Skip preloader" 8. Click "Partition" 9. Connect the device to the computer with USB Data Cable 10. Wait until it shows all partitions. 11. Choose the partitions you want to backup 12. Click on "Read" 13. Wait until the process is completed. Screen Short: BR Dipendra Pathak |
09-20-2021, 16:27 | #2572 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,619 | Xiaomi Edmi Note 8 (Ginkgo) Successfully Flashed using EDL mode by Hydra Tool Xiaomi Redmi Note 8 (Ginkgo) Successfully Flashed using EDL mode by Hydra Tool - Run Hydra Qualcomm Module - Select Model of your device (cellphone / mobile) - go to "Flash Tool" - Choose Flash file and its location manually. - Select Flashmode - Tick"Factory reset after flash" - Join the TP or Short the TP of Device (you need to disassemble the device). - Click "Flash" - Connect USB Cable and wait until the process is completed. - DONE Screen Short: BR Dipendra Pathak |
09-20-2021, 16:35 | #2573 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,619 | Samsun SM-A325M (A32 4G) selected partition successfully backed up by Hydra Tool Samsun SM-A325M (A32 4G) selected partition successfully backed up by Hydra Tool 1. Run Hydra MTK Module. 2. Tick "Brand" and "Module". 3. Tick "Comport" 4. Select "Auto Broom Exploit", "Enable UBL Loader" and "Enable PrelDUMP" 5. Choose "PM" Tab 6. Tick "Flash Mode" 7. Tick "Skip preloader" 8. Click "Partition" 9. Connect the device to the computer with USB Data Cable 10. Wait until it shows all partitions. 11. Choose the partitions you want to backup 12. Click on "Read" 13. Wait until the process is completed. Screen Short: BR Dipendra Pathak |
09-20-2021, 16:45 | #2574 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,619 | OPPO A15S (CPH 2179) FRP Successfully Removed by Hydra Tool OPPO A15S (CPH 2179) FRP Successfully Removed by Hydra Tool 1. Run Hydra MTK Module. 2. Tick "Brand" and "Module". 3. Tick "Comport" 4. Select "Auto Broom Exploit", "Enable UBL Loader" and "Enable PrelDUMP" 5. Choose "service"-->"Tool" Tab 6. Choose "Ultra Power Option" 7. Choose "Erase User Data" from drop down menu 8. Click on "Execute" 9. Connect Cellphone to the computer using USB Data Cable. 10. Wait until the process is completed. Screen Short: BR Dipendra Pathak |
09-20-2021, 16:50 | #2575 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,619 | Samsung SM-A013F (A01 Core) FRP successfully removed formatting presistent by Hydra Samsung SM-A013F (A01 Core) FRP successfully removed formatting presistent by Hydra 1. Run Hydra MTK Module. 2. Tick "Brand" and "Module". 3. Tick "Comport" 4. Select "Auto Broom Exploit", "Enable UBL Loader" and "Enable PrelDUMP" 5. Choose "PM" Tab 6. Tick "Flash Mode" 7. Tick "Skip preloader" 8. Click "Partition" 9. Connect the device to the computer with USB Data Cable 10. Wait until it shows all partitions. 11. Choose the partitions you want to backup 12. Click on "Erase" 13. Wait until the process is completed. Screen Short: BR Dipendra Pathak |
09-21-2021, 17:51 | #2576 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,619 | Xiaomi Redmi 5A (Riva) Mi Account Successfully removed using ELD mode by Hydra Xiaomi Redmi 5A (Riva) Mi Account Successfully removed using ELD mode by Hydra 1. Run Hydra Qualcomm Tool 2. Go to "Service" --> "Xiaomi" 3. Choose "Mi Account" from Drop down menu 4. Choose "Mi Account Remove (New Method)" from Flash Mode 5. Disassembly device and find Test Point 6. Click on "Execute" 7. Connect Device with Computer using USB Data Cable 8. Short two test point using twiser. 9. Wait until the flashing process is completed. 10. Done Screen Short: BR Dipendra Pathak |
09-21-2021, 18:03 | #2577 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,619 | OPPO F9 Pro (CPH 1823) Formatting selected partition successfully done by Hydra Tool OPPO F9 Pro (CPH 1823) Formatting selected partition successfully done by Hydra Tool 1. Run Hydra MTK Module. 2. Tick "Brand" and "Module". 3. Tick "Comport" 4. Select "Auto Broom Exploit", "Enable UBL Loader" and "Enable PrelDUMP" 5. Choose "PM" Tab 6. Choose "Flash Mode" 7. Click "Partitions" 8. Connect cellphone to the computer using USB data cable. 9. Wait until you see all information about Partition. 10. Now, choose the partition you wan to format, and click on "Erase" 11. Wait until the process is completed. Screen Short: BR Dipendra Pathak |
The Following User Says Thank You to Dipendra Pathak For This Useful Post: |
09-21-2021, 18:20 | #2578 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,619 | Xiaomi REdmi 9 (Lancelot) Mi Account Successfully removed by Hydra Tool Xiaomi REdmi 9 (Lancelot) Mi Account Successfully removed by Hydra Tool 1. Run Hydra MTK Module and Sosc. 2. Choose Brand and Module. 3. Go to "Service"-->"Tool" Tab. 4. Choose "Xiaomi". 5. Click on "Remove Mi Account (Erased Method) + FRP" from drop down menu. 6. Click "Execute" button 7. connect device to the computer with USB Data cable 8. Wait until the process is completed. Screen Short: BR Dipendra Pathak |
09-22-2021, 13:35 | #2579 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,619 | Oppo F11 (CPH 1911) Backing all partition except user data by Hydra Tool Oppo F11 (CPH 1911) Backing all partition except user data by Hydra Tool 1. Run MTK Tool and choose "Sosc" 2. Choose Brand and Module. 3. Tick on "ComPort" 4. Tick on "Auto Broom Exploit", "Enable UBL Loader" and "Enable auto PreDUMP" 5. Go to "Service"--> "Tool" 6. Choose "Backup Partition" 7. Choose "Backup All by Partition except user data" drop down menu. 8. Connect device to computer using USB Data Cable. 9. Wait until the operation is completed Screen Short: BR Dipendra Pathak |
09-22-2021, 13:50 | #2580 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,619 | Samsung A107F (A10s) FRP successfully removed formatting Presisttance by Hydra TOol Samsung A107F (A10s) FRP successfully removed formatting Presisttance by Hydra TOol 1. Run MTK tool of Hydra Dongle. 2. Choose Correct Module and Brand. 3. Tick "COM Port" 4. Choose "Auto Broom Exploit" 5. Click on "Boot / Info" and wait it reads all. 6. Go to "PM" Tab 7. Tick "Skip preloader" 8. Click on "Partition" button. 9. Now connect device to computer with Data Cable. 10. Wait it shows the different partition. 11. Choose "Presistent" 12. Click on "Erase" 13. Wait until the process is complete Screen Short: BR Dipendra Pathak |
