redmi note 5 flashing. [SOLVED] hi, team pls how to flash this using firm,ware from support, i already download the file from support but theres noting happen when i click flash. problem of my phone mi account android 9 muiu 11 i download downgrade fimware from support |
Reading GPT[4]Ok Phone Information..... Model : Redmi Note 5 Brand : xiaomi Android Ver : 9 Miui Ver : V11 Manufacturer : Xiaomi Device : whyred Mod_device : whyred_global Display ID : PKQ1.180904.001 Security Patch : 2019-11-05 Kernel ID : 2019-11-05 Fingerprint : xiaomi/whyred/whyred:9/PKQ1.180904.001/V11.0.3.0.PEIMIXM:user/release-keys ro_product_hardware : sys_hardware_version : ====================================== Reading GPT[4]Ok Operation : MiAccount Remove MiAccount[Erase Method] Processing... Backing up Partition for safety...Ok Scanning Patching address... > Patching address detected [PATCHED] > Patching address detected [PATCHED] > Patching address detected [PATCHED]Done!! Total Items patched : 3 Successfully patched address..Ok All Done ====================================== Elapsed Time : 00:00:30 |
Hello, Android 9 Not supported for disable mi account, You need to downgrade it to Android 8, After Patch Mi Account by EDL, Enable ADB and Connect USB cable, Do not Connect Wifi or Mobile Data From the top right of the exe Select Connection: ADB, and Disable Mi Account by ADB Best Regards | Hydra Team |
i mean boss how to flash using hydra and firmware from support i need to downgrade it to remove account. |
hi sir theres no option on raw xml custom and write patch on build 67 qualcom tool |
Once updated both modules and update base as well as extra files, we enter the qualcomm module, flash tool section and we have two options: 1. Auto Scan Raw / Patch XML (we look for the firmware folder that we want to flash and it automatically looks for us or finds the rawprogram.xml and the patch.xml). 1. https://i.postimg.cc/d0g9hMzz/1.png 2. Manual Select Raw / Patch XML (you must manually select the raw and patch.xml). 2. https://i.postimg.cc/XJcy4T3K/2.png |
this the file hthat i download from support unlock bootloder firmware file. whyred_images_V9.5.22.0.OEICNFA_20180626.0000.00_8 .1_cn_49a8c2738f whe i extract there is no xml file. |
https://www.androidfilehost.com/?fid...26312261807051 |
thank u so much flash done.. Fastboot Flashing... -storsec(storsec.mbn) Ok -storsecbak(storsec.mbn) Ok -rpm(rpm.mbn) Ok -rpmbak(rpm.mbn) Ok -hyp(hyp.mbn) Ok -hypbak(hyp.mbn) Ok -pmic(pmic.elf) Ok -pmicbak(pmic.elf) Ok -cmnlib(cmnlib.mbn) Ok -cmnlibbak(cmnlib.mbn) Ok -cmnlib64(cmnlib64.mbn) Ok -cmnlib64bak(cmnlib64.mbn) Ok -abl(abl.elf) Ok -ablbak(abl.elf) Ok -devcfgbak(devcfg.mbn) Ok -devcfg(devcfg.mbn) Ok -tz(tz.mbn) Ok -tzbak(tz.mbn) Ok -mdtpsecapp(mdtpsecapp.mbn) Ok -mdtpsecappbak(mdtpsecapp.mbn) Ok -keymaster(keymaster.mbn) Ok -keymasterbak(keymaster.mbn) Ok -bluetooth(BTFM.bin) Ok -xbl(xbl.elf) Ok -xblbak(xbl.elf) Ok -misc(misc.img) Ok -dsp(dspso.bin) Ok -mdtp(mdtp.img) Ok -splash(splash.img) Ok -persist(persist.img) Skipped -modem(NON-HLOS.bin) Ok -boot(boot.img) Ok -recovery(recovery.img) Ok -cache(cache.img) Ok -system(system.img) Ok -vendor(vendor.img) Ok -cust(cust.img) Ok -userdata(userdata.img) Ok All Done -------------------------- Elapsed Time : 00:04:45 |
