02-01-2021, 15:54 | #1 (permalink) | |
Freak Poster Join Date: Aug 2003 Location: lithuania ,kedainiai Age: 60
Member: 36262 Status: Offline Thanks Meter: 26 | redmi note 9 authorized file [Solved] i try flash. phone was be erased Quote:
thank you | |
02-01-2021, 16:30 | #2 (permalink) |
Product Manager Join Date: Aug 2018 Location: Ukraine / Harkov
Member: 2857401 Status: Offline Thanks Meter: 6,861 | Hello, You can follow this guide, https://www.hydra-dongle.com/help/ho...-of-xiaomi.php HOW TO SKIP AUTH OF XIAOMI ? How to Skip Auth of Xiaomi ? Download and Install Latest Package from Here Install Libusb Setup from " C:\Hydra Tool\bin\libusb-win32-devel-filter-1.2.6.0 " Run MTK Module, Select Brand and Model Tick Enable BROM Exploit and Run it. Screen Shot : Best Regards | Hydra Team |
The Following User Says Thank You to Hydra Tool For This Useful Post: |
02-02-2021, 11:27 | #3 (permalink) | ||
Member: 36262 Status: Offline Thanks Meter: 26 | hello, Quote:
The Following User Says Thank You to Jurgis For This Useful Post: |
02-02-2021, 19:04 | #8 (permalink) | |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | Quote:
I have 3.0 not sucess But 3.2 done sucessfully No need any boot da you can flash after successful connect to hydra tool Do like this pic . Select your model and tick enable bootrom exploit. no need any da boot.. | |
02-07-2021, 09:23 | #10 (permalink) | ||
thank you | ||
02-07-2021, 21:50 | #11 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | This module even supports IMEI repairing brother: https://forum.gsmhosting.com/vbb/f10...-tool-2945686/ Good luck! Br Dipendra Pathak |
02-10-2021, 03:47 | #13 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Please check the hyperlink brother : And success report which is already done: Good Luck! BR Dipendra Pathak |
02-10-2021, 15:12 | #14 (permalink) | |
Member: 36262 Status: Offline Thanks Meter: 26 | hello, thank you very much, preloader i repair, but for me MTK tool cant normal flash any device with sp flasher ok and i try repair imei Quote:
tomorrow i think wil be ok i dont now why with qualcome devices dont have any problem thank you | |
02-11-2021, 07:53 | #15 (permalink) | |
Member: 2857401 Status: Offline Thanks Meter: 6,861 | Quote:
Your IMEI is empty, You need fix that first, You can follow this guide for that, https://www.hydra-dongle.com/help/ho...-lancelot).php Then you can try repear imei repair procedure. Best Regards | Hydra Team | |
