Redmi Note 9T 5G (cannong) Helo i am facing problem with hydera mtk module pleas guide where i am mistaking . i am unlocking bootloader i have remove RSA Resister and flash with CM2 but hydera gives me DA error Hydra Tool Ver 2023.6.30.0 Windows 7 Service Pack 1 (Version 6.1, Build 7601, 64-bit Edition) Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz Intel(R) HD Graphics 4600 Ram Installed : 8 GB Windows Access Right : Admin Software Run As Admnistrator ******* Dongle Info ******* Version : Hydra Tool v 1.1 Serial : 190400000769 Initialize : OKAY Status : Activated Life : 0 [0-0-0-0-0] - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Service Function Bootloader Unlock Bootloader - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Searching for MTK Device...Found MTK Port Type : Flashmode BROM FriendlyName : MTK USB Port (COM7) Device : /6&2cc348b0&0&2 SymbolicName : \\?\usb#vid_0e8d&pid_0003#6&2cc348b0&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Driver Ver : 01/05/2012, 2.0000.0.1 Service : usbser Openning Port [COM7] Ok Handshaking...Ok HwCode : 0996 {MT6853} Hwver : 0000 Target config : 00 SBC : 00 (False) SLA : 00 (False) DAA : 00 (False) SWJTAG : 00 (False) EPP : 00 (False) CERT : 00 (False) MEMREAD : 00 (False) MEMWRITE : 00 (False) CMD_C8 : 00 (False) Connection : BROM HW Subcode : 8A00 HW Subcode : CA00 SW Ver : 0000 ME_ID : DDC9AB1131E3A272A176770705D141D5 SOC_ID : 7E5629838C0E6DF223E0AEDEDE366DD88FDAD23782E7206FFA AFC6ECB78485C2 Exploiting Device... Successfully Exploited.. Handshaking...Ok Dumping Preloader from Bootrom.. Seeking preloader address..Found @ 0x00200BC4 Starting to dump... Prel Size : 0x0005B9B4 Successfully dump preloader.. [D:\GSM\Hydra\Hydra Tool v2023.1.6.1\Boot\PreloaderDump\preloader_cannong.b in] Target config : 00 SBC : 00 (False) SLA : 00 (False) DAA : 00 (False) SWJTAG : 00 (False) EPP : 00 (False) CERT : 00 (False) MEMREAD : 00 (False) MEMWRITE : 00 (False) CMD_C8 : 00 (False) Connection : BROM Preparing Download Agent..[MTK_AllInOne_DA_5.2152.bin] Patching da2 ... Ok Uploading Stage 1.... Successfully uploaded stage 1, jumping .. Executing JUMP_DA Address @ 0x00200000 Jumping to 0x00200000 Ok ---------------------------------------------------------------- Please select compatible DA Device is secured and unable to execute your Download Agent(DA) You can also Testpoint to enable BROM Port ---------------------------------------------------------------- Action Result : Ok Elapsed Time : 00:00:06 |
First select model and keep press boot info >> for new security phone need test point. |
1 Attachment(s) Quote:
Thanks in advance |
Here is the pcb photo 1 Attachment(s) Here is the pcb photo |
cmastar |
Hydra Tool Ver 2023.6.30.0 Windows 7 Service Pack 1 (Version 6.1, Build 7601, 64-bit Edition) Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz Intel(R) HD Graphics 4600 Ram Installed : 8 GB Windows Access Right : Admin Software Run As Admnistrator ******* Dongle Info ******* Version : Hydra Tool v 1.1 Serial : 190400000769 Initialize : OKAY Status : Activated Life : 0 [0-0-0-0-0] - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Service Function Bootloader Unlock Bootloader - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Searching for MTK Device...Found MTK Port Type : Flashmode BROM FriendlyName : MTK USB Port (COM7) Device : /6&2cc348b0&0&2 SymbolicName : \\?\usb#vid_0e8d&pid_0003#6&2cc348b0&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Driver Ver : 01/05/2012, 2.0000.0.1 Service : usbser Openning Port [COM7] Ok Reading Partition Table .. ERAM Size : 0x0000000000070000-448 KB IRAM Size : 0x0000000100000000-4 GB UFS MID : 0x4B UFS FWVer : 0x2302 UFS Blocksize : 0x0000000000001000-4 KB UFS LU0 Size : 0x0000000000400000-4 MB UFS LU1 Size : 0x0000000000400000-4 MB UFS LU2 Size : 0x0000001DCB000000-119.172 GB UFS ID : 5 UFS CID : 4B4D355638303031444D2D423632320000000000 HW-CODE : 0x996 HWSUB-CODE : 0x8A00 HW-VERSION : 0xCA00 SW-VERSION : 0x0 CHIP-EVOLUTION : 0x1 DA-VERSION : 1.0 Speed : high-speed Partition Count : 62 --------------- Reading build.prop content --------------- Product : cannong Marketname : ro.product.systemRedmi Note 9T ID : QP1A.190711.020 SDK : 29 Release : 10 ABI : arm64-v8a CPU abilist : arm64-v8a,armeabi-v7a,armeabi Locale : en-GB Description : cannong-user 10 QP1A.190711.020 V12.0.6.0.QJEMIXM release-keys Display ID : QP1A.190711.020 Security Patch : 2021-01-01 StorageType : mtp --------------- end of build.prop content --------------- Reading IMEI........ IMEI1 : Unable To decrypt Unknown Keys[5G] IMEI2 : Unable To decrypt Unknown Keys[5G] ------------------------------- Bootloader Status... Bootloader : Locked ------------------------------- ------------------------------ Bootloader Operation.. ------------------------------ ------------------------------- Bootloader Status... Bootloader : Locked ------------------------------- Unlocking Bootloader Please wait, processing..... Status error: Wrong magic Access violation at address 010E7514 in module 'HydraTool.exe'. Read of address 00000000 Action Result : Failed Elapsed Time : 00:00:04 cmastar |
