07-27-2020, 14:31 | #1 (permalink) | |
No Life Poster Join Date: Jul 2007 Location: tr
Member: 539148 Status: Offline Thanks Meter: 2,174 | Xiaomi Redmi 6 Pro Mi Account Remove Success by Hydra Put your device to EDL Mode, From service tick Xiaomi, Select Remove Mi Account Erase Method and Click Execute, After it before you connect it wifi or mobile data enable ADB and dissable mi account by adb. Quote:
The Following User Says Thank You to dicle_gsm For This Useful Post: |
07-27-2020, 19:38 | #2 (permalink) |
No Life Poster Join Date: May 2011
Member: 1576733 Status: Offline Thanks Meter: 622 | Hello thank for sharing your report. But I had one query Mi Account Remove means Permanently removing Mi account from phone and you can use other account of your choice. But in this case you also mentioned that you Disable Mi Account adb method. As far I know you cannot add another Mi account in that phone. So in this case this is not remove its just kind of bypass to mi account In that case your title may misguide many other users over here. I am just telling No offence though. |
The Following User Says Thank You to diosa For This Useful Post: |
07-28-2020, 07:38 | #3 (permalink) |
No Life Poster Join Date: Jun 2016 Location: UK
Member: 2581848 Status: Offline Thanks Meter: 249 | hello i want buy this dongle But i have few question when i remove mi acount is Permanent or Just by pass and Disable Mi Account adb method when i reset the phone or update the phone the phone work without problem? Is there any solution to remove Permanent |
07-28-2020, 08:56 | #4 (permalink) | |
Product Manager Join Date: Aug 2018 Location: Ukraine / Harkov
Member: 2857401 Status: Offline Thanks Meter: 6,861 | Quote:
There is not solution for remove Permanent, After Factory reset it will back. Best Regards | Hydra Team | |
07-29-2020, 15:07 | #5 (permalink) |
No Life Poster Join Date: Aug 2005 Location: Here Age: 47
Member: 175183 Status: Offline Sonork: 0 Thanks Meter: 120 | "After it before you connect it wifi or mobile data enable ADB and dissable mi account by adb." How to do? By Hydra software? Wich option ? |
07-30-2020, 15:16 | #7 (permalink) |
Member: 175183 Status: Offline Sonork: 0 Thanks Meter: 120 | Thank you. Work very well with Tulip. Now I need same procedure to Ginkgo, but cant find ROM to downgrade to 8.1 Any way to downgrade Ginkgo to Android 8.1? |
