08-11-2021, 09:14 | #1 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Realme 8 5G (RMX2341) Factory Format or format user data successfully done by Hydra Realme 8 5G (RMX2341) Factory Format or format user data successfully done by Hydra This Operation goes Flash Mode with COM Port 1. Run Hydra MTK module and choose "SOSC". 2. Tick "COM Port" at the TOP 2. Choose Brand and Module 3. Tick "Auto Loader", "Auto Broom Exploit" and "Enable UBL Loader" 4. Tick "Enable Auto Pre DUMP" 5. Go to "Service" -->"Tool" Tab. 6. Choose "Read System Info" Note: This function tells you this device completely supports or not. 7. connect device to the computer with USB Data cable with Flash Mode 8. Wait until Hydra shows you all information on the screen. 9. choose "Factory Reset / Format User Data" 10. Choose "Erase user data" from "Method / Option" 11. Tick "Auto Reboot" 12. Click "Execute" 13. connect device to the computer with USB Data cable with Flash Mode 14. Wait until the process is completed. Note: If you do not have boot file, you can make it from Hydra "EXPLOIT" Tab using "BROOM (dump Preloader Flash init)" Screen Short: BR Dipenda Pathak |
