Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 11 / iPhone 11 Pro / iPhone 11 Pro Max
Old 09-11-2022, 02:13   #1 (permalink)
Member: 2093958
Thanks Meter: 82
apple iphone 11 pro 11 pro max disassembly motherboard schematic diagram service ways
apple iphone 11 pro 11 pro max disassembly motherboard schematic diagram service ways ic solution u
device part
Other solutions contact softrif
518564207-Apple-iPhone-11-Pro-.pdf
iPhone 11 Pro Max (820-01508) PCB Layout.pdf
iPhone 11 Pro Max (820-01682) PCB Layout.pdf
iPhone 11 Pro Max (D42,D43_MLB_TOP_AVUS) Schematic.pdf
iPhone 11 Pro Max PCB Teardown.pdf
Other solutions contact softrif\iPhone 11 Pro Impedances Guideness (Baseband_MB).pdf
Other solutions contact softrif\iPhone 11 Pro Impedances Guideness (Logic_MB).pdf
Other solutions contact softrif\iPhone 11 Pro PCB Teardown.pdf
Other solutions contact softrif\iPhone 11 Pro Power Button ON.OFF Points.jpg
Other solutions contact softrif\iPhone 11 Pro Schematic Diagram.pdf
device part\Touch FPC Connector Port Onboard for iPhone 1111 Pro11 Pro Max Ori 20Pin.jpg
device part\U4020,3539, Backlight IC for iPhone 6S6S PlusSE77 Plus... Ori 16Pin ‫‬.jpg
device part\U4020,3539, Backlight IC for iPhone 6S6S PlusSE77 Plus... Ori 16Pin.jpg
device part\USB Charging FPC Connector Port Onboard for iPhone 11 Pro11 Pro Max 56Pin.jpg
device part\3D Touch FPC Connector Port on Flex Cable for iPhone 1111 Pro11 Pro Max Ori 20Pin.jpg
device part\338S00411 Small Audio IC for iPhone XXRXS Max1111 Pro11 Pro Max ‫‬.jpg
device part\338S00411 Small Audio IC for iPhone XXRXS Max1111 Pro11 Pro Max.jpg
device part\1612A1 Charging IC for iPhone 88 PlusX1111 Pro11 Pro Max Ori ‫‬.jpg
device part\1612A1 Charging IC for iPhone 88 PlusX1111 Pro11 Pro Max Ori.jpg
device part\5765 Intermediate Frequency IC for iPhone 1111 Pro11 Pro Max Ori ‫‬.jpg
device part\5765 Intermediate Frequency IC for iPhone 1111 Pro11 Pro Max Ori.jpg
device part\Back Camera FPC Connector Port Onboard for iPhone 1111 Pro11 Pro Max Ori 22Pin.jpg
device part\Battery FPC Connector Port Onboard for iPhone 1111 Pro11 Pro MaxSE 2020 Ori.jpg
device part\Front Camera FPC Connector Port Onboard for iPhone 11 ProXS11 Pro Max Ori 18Pin.jpg
device part\Front Camera FPC Connector Port Onboard for iPhone 1111 Pro11 Pro Max Ori 10Pin.jpg
device part\LCD FPC Connector Port on Flex Cable for iPhone 11 Pro11 Pro Max Ori 36Pin.jpg
device part\LCD FPC Connector Port Onboard for iPhone 11 Pro11 Pro Max Ori 36Pin.jpg
device part\Nand Flash Hdd IC for iPhone 11 Pro11 Pro Max Ori(Third Party Packaging) 256GB ‫‬.jpg
device part\Nand Flash Hdd IC for iPhone 11 Pro11 Pro Max Ori(Third Party Packaging) 256GB.jpg
device part\Power Button FPC Connector Port Onboard for iPhone 11XSXS Max11 Pro11 Pro Max Ori 12Pin.jpg
device part\SN2611 Charging IC for iPhone 11 Pro Max1111 Pro1212 Pro Ori ‫‬.jpg
device part\SN2611 Charging IC for iPhone 11 Pro Max1111 Pro1212 Pro Ori.jpg
https://www.youtube.com/watch?v=w24I...ture=*********
The Following User Says Thank You to softrif For This Useful Post:
Old 04-14-2023, 17:03   #2 (permalink)
Member: 3026695
Thanks Meter: 4
thanks for the infos. Really need these
Page generated in 0.11972 seconds with 8 queries
